Using PIP As A Generator
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by El Dobro, Oct 29, 2012.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    El Dobro on the 1500W model you bought at Home Depot, do you think the next model down at 1000W is as good?
  2. El Dobro
    El Dobro A Member
    7,102
    3,282
    Not if you like toast. :D
    wjtracy likes this.
  3. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    +120
    Ground
    Data
    Proximity/connect sensor
  4. mrbigh
    3,686
    699
    Long Island, NY
    I will add some more information and correcting an snafu
    Pin assignment:
    #1- 120 VAC -L1
    #2- 120 VAC - L2
    #3- Ground
    #4- Data (PILOT)
    #5- Proximity/connect sensor
  5. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
  6. mrbigh
    3,686
    699
    Long Island, NY
    He made it to the news!!! and where was his Prius Chat promotional sticker????:sneaky:
  7. lensovet
    2,615
    496
    Burlington, NJ
    100 watts? Surely that's a typo.
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
  9. El Dobro
    El Dobro A Member
    7,102
    3,282
    Would this work in reverse where power can be tapped?
  10. hill
    9,014
    anytime you go from gas to battery there is a loss of efficiency. So a prius goes from gas to battery to inverter to your house. Generator goes straight from gas to your house. Realistically everybody has different price ranges and different 'emergency' prep need
    SGH-I717R ? 2
  11. techntrek
    techntrek Member
    263
    84
    MD
    The smaller 1-2 kw Honda inverter gensets are as efficient as a Prius (which can output 3 kw). Roughly 0.1-0.2 gallons per hour on average. A regular genset is nowhere as efficient, a gallon or two or more if you are talking the big guys.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    By your numbers, the Honda generators are about 30% efficient, while hte Prius averages about 36%. Pretty darn good, but not Prius like ;)
  13. mrbigh
    3,686
    699
    Long Island, NY
    I guess yes, while the connections on the proper ends match and NOT in the way the are right now form the manufacturer plant.
    Now, the pilot signal will have to be modified in order to have the proper handshake, but certainly will work.
  14. El Dobro
    El Dobro A Member
    7,102
    3,282
    This is the connector that Toyota will use for power. That's what made me wonder if it was just a change of wiring to tap the car for power or if was an actual change of components in the car.
  15. mrbigh
    3,686
    699
    Long Island, NY
    Man, where you got that picture from? certainly will be another tech information that can be disseminated from it.
    Might it be from a prototype vehicle?
    Also, the interconnect wire is very thin..............
  16. El Dobro
    El Dobro A Member
    7,102
    3,282
  17. CharlesH
    2,798
    1,166
    Roseville, CA
    And at this time anyway, this is for the Japanese market only.
  18. El Dobro
    El Dobro A Member
    7,102
    3,282
    Hopefully, some Japan based members can tell us all about it.
  19. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Until someone puts it in a box and ships it then it's for the US market.
  20. CharlesH
    2,798
    1,166
    Roseville, CA
    What good is a 100V 50Hz power source going to do in the U.S. or Canada? And that is assuming that the interface to the J1772 socket on the U.S. version of the PiP even supports this (either the control logic or the hardware).
