Using Synthetic Motor Oil?
Discussion in 'Prius c Technical Discussion' started by Oldwolf, Apr 14, 2012.
  1. Thad
    Thad New Member
    Well, all you guys have just discovered how little these service advisors actually know...
    I've used M1 for years on other cars and have had excellent luck with it. With the Prius, I use only the Toyota branded oil. I've actually had it analyzed by Blackstone and found it's chemical composition to be completely different than the 0-20 M1. It has considerably more Molybdenum in it than any other oil I can find, including M1 (any viscosity range). "Moly" as it's called, is an additive that adds considerable expense to an oil, but bonds with the metallic surfaces to reduce friction. It's what makes the Toyota oil different (superior?) to M1 and other synthetics. It may be blended to Toyota specifications by Mobil, and may use M1 as the "base" oil, but it's definitely different in composition. This isn't opinion, I've actually done the analysis of both oils (same viscosity, 10K miles each) and the numbers don't lie...they are not the same product.
    Bluegrassman likes this.
  2. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    I think that was true for the SM Toyota oil. The Toyota SN tests similarly to the Mobil 1 SN oil. Did you test the SM or SN?
  3. runnyeggs
    runnyeggs Junior Member
    31
    NV
    I am not sure there's anywhere online you can get the Toyota dealer besides the dealershipships.
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    Not sure what you are saying. I have ordered Toyota parts from dealers selling on Amazon and from dealers selling online.
  5. major_worls
    major_worls Junior Member
    Ramsey, NJ
    If anything, it's probably because WalMart is so huge, buys mountains of everything, and has enormous leverage over suppliers.
  6. strategy400
    strategy400 New Member
    25
    Victorville, CA.
    2015 Prius c
    I had a honda del sol running conventional oil. Did a valve adjustment regularly and always had to adjust a few. Switched to M1 synthetic and after that taking the valve cover off was a waste of time. The clearances never moved again. I swear it completely stopped any wear of the valve train.
