Using the battery cooling fan to cool the car and the HV battery
Discussion in 'Gen 2 Prius Accessories & Modifications' started by FirstFlight, Jun 8, 2012.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I had a thought today and if anyone has tried this please let me know. I made a custom PCB to control the battery fan, which has proven to be very useful.
    Scangauge II mounting location and battery fan modification PCB | PriusChat
    One thing I've noticed is that if the windows are open a little and the fan is on, it sucks the air from the outside into the car, through the fan, over the batteries and out the back of the car. Not only does it cool the car but it also cools the batteries as well.
    I have four user programs to control the battery fan and one of those programs will run the fan during the day while the car is out in the heat. Right now I'm experimenting with running the fan every hour for 30 seconds for 8 hours. I have some heat sensors coming but I suspect that if the OAT is 95 degrees and the sun is out, running the fan for 30 seconds will help but 10 minutes later I'm pretty sure the temp inside the car would get back to "very hot."
    Running the fan at full speed for eight hours would pretty much kill the battery. Running it at slower speeds would help but again I'm concerned about the battery health. So I had these two ideas that I'm going to try. But, instead of reinventing the wheel, someone let me know if they've tried this or have a better idea.
    My first thought was to buy a battery, like a 9 Amp hour, SLA, 12V battery. I would have a quick disconnect connector on it and mount the battery in right, rear corner of the Prius with one of those rubber straps with an S hook. So removing the battery and taking it inside to charge it would be quick and painless.
    My thought is that I can use my custom board to control the fan and automatically know if the additional battery is installed. If the additional battery is installed, the program could automatically double the time, speed or whatever I need to run the fan. If it doesn't see the extra battery, the program reverts back to the "power saving" program. I could also use the Prius to recharge the SLA battery or I had this thought too.
    What about if I used the additional SLA battery and also install a 5W solar panel. When I'm not using the fan, the solar panel can recharge the SLA battery and/or the Prius 12V battery as well. This helps keep the battery cool but the interior is definitely kept cooler as well.
    Do I sound crazy or is this something worth making?
    pjc and dave77 like this.
  2. alekska
    alekska Active Member
    435
    138
    Atl
    I feel that it's too much work for very little benefit. You will never be able to cool the car below outside air temperature. And to achieve the goal of having car at ambient air temperature you just need to park it in the shade. Or, if you _need_ to park at direct sun, just cover it with white fabric car cover.
    Thanks,
    - Alex
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    What a revelation.o_O The only way to cool the car below OAT is with air conditioning.
    I agree with parking it in the shade, however, it's not always possible. The majority of time it's not possible.
    So you think carrying around a white fabric car cover in your car is easier than using a 7 pound battery that you would take in at night to charge and put in you car in the morning?
    Lets say I had to travel to three places during the day in the summer. With your idea, each time I stop I have to get out the car cover and cover my car. Each time I get back into the car I have to remove the cover. With the battery fan, I press and hold the button for four seconds and I'm done. I can't see how pushing a button is more work than covering and removing a car cover up to three times a day.
  4. alekska
    435
    138
    Atl
    FirstFlight,
    my wife's car is 2010 prius with solar roof... and i myself wanted something similar for my 2005 prius. But, after some consideration I abandoned the idea, as for me (I park only once at work, and sometimes can find a shaded place) the trouble is bigger than benefit.
    I used to ride a motorcycle to work, and I would always put a cover on it when park. It only took me 10 seconds. That's why I thought car cover would be ok.
    If you want to pursue the fan idea I think you can use the car's 12V battery, and charge it with solar panel. This way you do not need to install additional battery. If the sun is out, solar panel would charge car's 12V battery, and you can use it to run the fan. No sun = no charging, and controller should stop running the fan.
    Good luck,
    - Alex
  5. mrbigh
    3,686
    699
    Long Island, NY
    I tried the HV battery cooling thingy 6 years ago and it was a waste of resources.
    In one way or the other, the most cumbersome solution is the most simpler. A tyvek "car Top" vehicle cover is what I adopted and really worked for the last 4 years.
    Now is the time to replace it.
  6. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Unfortunately a 5watt solar panel will not do the job. A reasonable estimate to run the battery fan takes 5amps multiply this by the battery voltage 13v = 65watts with reasonable losses 15 hrs of charging to run the fan for 1 hr.
  7. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I know a solar panel won't run the fan directly. I was talking about intermittent operation and charging the battery inbetween. Or, at a slower speed.
    I had an idea years ago to put automatic shades that would come down on the insides of all the windows. That would be great for so many reasons. I never got around to really trying it. New Jersey doesn't allow tinting for both the front and back windows. I don't want to use a car cover.
    While the car cover would work, I'm lazy and like things that are automatic. I need to explore the battery fan idea more thoroughly, perhaps including something else like a shade.
    I've used the battery fan cycling throughout the day for the past two days and when I got in the car at the end of the day the temperature of the battery was 2-3 degrees above ambient. Does anyone know how much the battery temperature would normally increase on a hot day if the windows are up and the sun is out?
    This mod also had me thinking about the winter.
    Scenario: 20 degrees F and 5am. Wouldn't running the fan at a slow speed drag warm air over the battery help with FE or is it pretty much negligible?
  8. PaulHS
    PaulHS Member
    200
    SE PA
    The Prius does have a "shade" for the hatch area; the tonneau cover. And it hardly takes a minute to put a sunshade up for the windshield.
    alekska likes this.
  9. richard schumacher
    7,663
    1,038
    United States
    Ditto that. Park facing south and use a Sunshade for the windshield. It works in TX, it'll work in NJ.
  10. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Can't I just try the hardest thing first?;)
    My car didn't come with the tonneau cover but I'm buying one off of E-bay this weekend. For some reason I didn't think about the foldable shade in the front. Using the foldable shade, tinted windows, the tonneau cover (although that doesn't stop the UV rays from entering the car) and the fan on occasion, I should be good.
    PaulHS and dave77 like this.
  11. PaulHS
    PaulHS Member
    200
    SE PA
    Actually, I think your idea is original. Somewhere in the archives I participated in a thread proposing a preheat scheme for the HV battery in the winter!
  12. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    An original piece of crap! ;)
    I'm going to get the variable speed working with my board this weekend. That will allow me to do a lot more with the fan. I have a ton of more ideas. I'm going to make a board with 20-something outputs. I want to control everything with one button! Maybe I'll add an LCD screen too.
    Now, where do I attach the wings to this thing......
    dave77 likes this.
  13. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    Things to consider:
    1) That fan motor (likely) has brushes and will wear out. It's only intended to be run when the battery temperature is getting higher than its threshold. If you run the fan much more than this, you'll wear out the fan motor more quickly.
    2) As you noted, that fan sucks air from the car, over the batteries, and out. Are you sure you want to heat up your batteries constantly while your car is sitting in the sun?
    I'd be concerned with the impact to the longevity of your fan motor and, more importantly, your traction battery.
  14. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Possibly. However, I'm sure the fans that are installed in the southern US run frequently. I'm not running the fan very frequently. (30 seconds, once an hour, for 8 hours a day). If I do decide to run it more, a used cooling fan can be had for $40 if it does fail.
    I don't agree. If your car is in the sun, the interior temperature will always be higher than OAT. If you're pulling air through the RIGHT REAR window, you are pulling cooler air into the fan than what exists inside the car.
    Fan possibly, battery, no. In fact, now way in hell this would negatively impact the traction battery. If you leave your windows closed in the sun, eventually everything in the car rises to the temperature of the car interior. Any air that is pulled from the outside will cool anything inside the car.
  15. wjtracy
    wjtracy Senior Member
    11,315
    3,588
    Northern VA (NoVA)
    ...I was sort of thinking along these lines but simpler maybe using an Arduino and some small PC cooling fans to bring air in ...not sure where from but I guess the battery vent. Then a small solar PV could run it.
  16. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I thought about that too except I thought about using those small remote vehicle fans (the RPM's are extremely high) and running a pipe directly to the output side of the OEM fan. I haven't thrown away the idea completely but it's more complex than using the OEM fan. The major reason why I haven't thown away the idea completely is due to the current consumption of the OEM fan. Using a smaller motor can save lots of power.
    dave77 likes this.
  17. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Now that my 2 other projects are coming to fruition , I was thinking of moving on to the cooling of the HV battery in my Prius.
    I have covered parking , sometimes at work but I am conerned about cooling the battery when I get home after driving 1 hr in 95 deg weather.
    I have done the mind game thing and was thinking of modifying the air handler at the output of the OEM Fan to add a flapper valve to stop backflow towards the fan and an additonal small fan . I was thinking of using a DC Brushless Squirrel fan with Tachometer feedback to control the fan speed using a NTC sensor and a PIC.
    Modeling of the air handler section is being examined as to how to justifythe cost of a modeling tool and software. I guess I could join my friends and family who are looking at the tool also. They already have the modeling software ( ProEng). An IGES file for the existing handler would be useful but I could create a 3D model using a Laser Modeling device.
  18. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    This is the biggest reason to have a controller for the fan after the car is powered down. The fan will not operate and in once instance I saw my battery temperature rise more than 20 degrees after I shut the car off. So far it's been working well. I'm finding that somewhere around 3 minutes is enough to keep the battery temperature from rising higher than a few degrees, although we haven't seen the hottest part of the summer yet. I may adjust it as the summer progresses.
    At work we have A/C units with fresh and closed air vents. I thought about doing that but one thing hinders me at this point. I'm not very good mechanically as my background is in electronics, so cutting holes in the car or finding a good way to mount an additional tube for the air is something I have apprehensions about. The reason why I thought this would be a great idea is that you can have OAT and IAT sensors. If the OAT is less than the IAT, the valve opens and uses air from the outside. If the reverse is true, the valve closes and uses the air inside the car. Then you can include calculations for wind speed and humidity as well, which will allow you to factor in a wind chill component.
    My 10 year old daughter sits on the side where the vent is and she either complains about it being too cold or she complains about the noise from the fan. The latter I can rectify with the speed of the fan but the former is more difficult and why using the air outside the car would be beneficial. I do open the window to help force the air into the fan but if she is back there, trying to do that driving 70 MPH isn't going to happen.
    I was thinking that cutting a hole (and using a filter) just behind the passenger right, rear door would be really useful. The hole would be parallel to the car so most of the air flow can be captured and it would kind of look like the machine gun port on a military jet, something like this:
    Not only would you be able to use the cooler air (if that's the case), the air flow itself at highway speeds (I think) would cool the battery down even if it was 95 degrees. You would also save battery power because you wouldn't need to run the fan at higher speeds or at all. So perhaps doing some calculations with wind speed, humidity and temperature in the tube would allow the system to be 100% automatic. I can do all of the programming but that hole worries me.
  19. Britprius
    5,194
    1,912
    There are two vents you could use already in the area. If you take out the small storage box out of the boot (sorry trunk) on the drivers side of the car (for you) and look down you will see a plastic vent to outside air the other vent is on the other side of the car down low just in front of the 12v battery. You should be able to take cool air in from one side and vent the warmed air out the other. Hope this helps.
    John.
  20. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Good info, thanks. It certainly helps and seems like an easier solution. It may be the best solution. The only problem is not much air will be forced into the tube because the hole is facing down and not forward, if I understand you correctly. I guess I could throw a pipe in there and angle it but I'm wondering if I'll get extra heat from the engine, since it's on the bottom of the car and not the side.
