Using the parking brakes
Discussion in 'Gen 3 Prius Technical Discussion' started by Friar Tuck, Sep 29, 2010.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    All of my early cars were manuals. I've also professionally driven trucks, tractors, and heavy equipment, all with manual transmissions. I can state categorically that I have *never* shifted to N and applied the parking brake while waiting at a light. I have never known any other drivers to do it either. That isn't to say that none do, but I wouldn't make your sweeping statement that the practice is typical.
    What I typically did, and most other drivers that I know, was shift to N and hold the service brake with my right foot, assuming that the wait was long enough to warrant shifting.
    Tom
  2. Friar Tuck
    Friar Tuck Member
    47
    uk
    Teakwood. It is good driving practice to automatically stop, handbrake on, engage neutral as part of normal driver training.
    I am an advanced driver and am also currently undergoing training to be an advanced driving instructer.
    I can assure you that stopping with your foot on the brake with clutch down will result in a repremand from your driving instructer (for long stops at lights for example). You would probably get a minor fault against you during your test as well.
    Also sitting on the clutch pedal wears out the throw out spring/bearing.
    Good practice seems to be different here.
  3. qbee42
    18,058
    3,081
    Northern Michigan
    Good driving practices very by location. The UK and Australia teach drivers to use the parking brake in this manner. Likewise they teach the use of the parking brake for starting on hills. This is not common practice in the U.S., as most manual drivers are taught to use a quick foot shift from the service brake to the accelerator to avoid rolling backward on hills.
    As for the clutch throw out bearing, I agree with you. Others, however, will argue that sitting in N puts you in a position where you can't quickly react to an emergency. Using the parking brake further aggravates this line of argument.
    Tom
  4. Tideland Prius
    16,675
    Clearly it's not a North American practice then (and I don't blame you. Your traffic lights are not designed with the manual driver in mind and give little chance for the driver to prepare to engage first gear and get ready to go unlike other countries :) ).
  5. Friar Tuck
    Friar Tuck Member
    47
    uk
    Tideland. Interesting point. Our traffic lights go through amber before green giving the opposing traffic time to clear the junction and you(the driver) time to engage gear and drive away.
    Not sure about the hill start tehnique...especially in san francisco. We feed the clutch in slowly with extra revs whilst slowly letting off the hand brake. Trying the quick foot change technique could result in roll back, stalling or shooting off up the hill and back ending someone.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Not sure Eropean models are equipped with Hill Start Assist?
    Anybody has an idea?
    Have to check this!
  7. Friar Tuck
    Friar Tuck Member
    47
    uk
    Hill start assist is standard on T3, T4, T spirit
  8. vday
    vday Member
    312
    Israel
    Giora
    Yes we have it in Israel and Europe
    Press the brake hard and you will see
    I beleive this is what you are referring to:)
  9. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    It occurs to me after seeing all the mentions of Hill Start Assist in this thread that you could probably use it for this purpose too; it will keep the brakes applied for up to about 2 seconds, or until you start pressing the gas pedal. So if somebody rear-ends you, it will presumably keep braking - and it'll brake on all four wheels, not just the two rear ones like a parking brake would.
  10. qbee42
    18,058
    3,081
    Northern Michigan
    If you know how to do it, it's not hard to shift your foot without stalling or rolling back. If you don't know how, it can be embarrassing at best.
    Tom
  11. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I had a manual until this year when I got the Prius and have had one constantly for almost a decade before getting rid of it. I'd often take it out into neutral while at a light but always relied on just the foot brake, not the hand brake, even on hill starts--and even on very steep hills. Only exception if a car very close behind (like right up my...). A good manual driver really doesn't need to use the handbrake and will have only minimal roll back :). I didn't like keeping the clutch pedal in @ long lights and especially after replacing a slave cylinder a couple of times I felt like keeping the system under pressure could potentially speed its wear, hence the N (plus just less effort!).
  12. RKIRKI
    RKIRKI Member
    31
    32
    Chicago NW Suburbs, IL
    Parking Brake in Winter
    Here are some newbie questions about use of the parking brake in cold weather. In the 2010 owner's manual there is a section on "Winter Driving Tips" (Page 262) which advises,
    "Park the vehicle and push the "P" position switch without setting the parking brake. The parking brake may freeze up, preventing it from being released. If necessary block the wheels to prevent inadvertent sliding or creeping."
    Do those of you experienced Prius drivers who live in cold climates specifically avoid using the parking brake in the winter? Have any of you ever encountered the parking brake freezing up, and if so, at what temperature?
    Thanks for your comments!
  13. qbee42
    18,058
    3,081
    Northern Michigan
    Re: Parking Brake in Winter
    I avoid using the parking brake in any weather, unless conditions suggest its use. I use it when parking on inclines, and in any parking situation where roll could be catastrophic.
    By this selection criteria, in the winter I still use the parking brake, as the outcome of freezing is less damaging than the outcome of rolling off a hill.
    Tom
  14. Tideland Prius
    16,675
    No but I do avoid applying the parking brake after a car wash... it definitely sticks! (and results in a loud bang in order to release it)
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Most of us here in the UK drive a manual like teakwood, except the "Advanced" :blah::lalala: drivers who drive in their own advanced world, displaying their big IAM badge on the front of their cars. :eek:hwell: :lol:
