Using the Primes 120v Charger at 240 Volts, Cost $20 !!!
Discussion in 'Prime Plug-in Charging' started by Rob43, Mar 16, 2019.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    LOL! I’m sure it will.
    iPhone ?
    Rob43 likes this.
  2. Toolisaurus
    Toolisaurus New Member
    New York
    2020 Prius Prime
    Curious if anyone's has tried this the other way - instead of creating an adapter for the household outlet to be used in the 240V outlet - what about cutting off the household outlet from the EVSE and splicing on a 240V plug - simpler and safer (no risk of someone putting a regular 120v plug in).?
  3. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    You lose the capability to charge from a 110 volt outlet.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I've read that there's a temperature sensor in the plug. Cutting it off is likely to prevent the EVSE from working. I haven't opened mine to confirm. And if the adapter is kept connected to the EVSE rather than the wall outlet, then no one can plug a 120V device into the outlet.
    fuzzy1 likes this.
  5. 1x1
    1x1 Member
    147
    45
    Anyone seen Rob43 around or have his paypal contact info? I want to order an adapter. Thanks.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    Just tag him. He'll get notified. Never mind. I'll do it. ;) Hey @Rob43, @1x1 is looking for you. :D
    1x1 likes this.
  7. jjs357
    jjs357 Junior Member
    50
    Near Philadelphia PA
    2020 Prius Prime
    Haven't seen @Rob43 around the forums lately. Does anyone know if he is till in the 240V pigtail business?
  8. tjay
    tjay New Member
    usa
    2020 Prius Prime
    hello @Rob43 - sent you a PM...
  9. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    @tjay - I haven't been posting much this year except the last month of so, but I also haven't seen any new posts from Rob in that time either. You might want to look around in some of Robs other posts or in his profile for another way to contact him.
    Or maybe someone else that knows Rob will see this and PM you or contact Rob and let him know about your PM.
    @Rob43 I hope you are well. I and I'm certain a lot of others here at PC miss reading your posts.
    #249 vvillovv, Sep 11, 2020
  10. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    It's not Rocket Surgery building these 'Not to Code, somewhat illegal, kind of unsafe Adapters'.
    Anyone that can strip a wire and turn a screw driver can do it.
    Two connectors, a foot or two of 12 or 10 ga. wire, from a trip to the Depot and Bob's your Uncle!(y)
    Maybe Rob wised up to his legal 'exposure'....:whistle:
  11. vvillovv
    4,321
    1,510
    NY
    I've seen a lot of worthwhile projects fall pray to the safety issue. Much like the Thomas Edison - Nikola Tesla controversy early on during the industrial revolution, many good / great ideas are lost to history due to controversial media attention and/or unscrupulous litigation. How much is it worth.
    I sure hope Robs' protected from such. allowing him to provide those that want his customized solution to have him provide it to them.
  12. Bill Norton
    2,152
    734
    MONW, Ks.
    How much?
    The cost of an actual L2 EVSE. In other words, not much. $175 - -
    (amazon link no workie...)
    And while your at it, open that dusty old billfold a little bit more and buy a 40A L2. Future Proofing!
    The Prime will not be your last EV!!
  13. vvillovv
    4,321
    1,510
    NY
    Ah. $50 or $200 let me do some quick calculations. Then I'll add the 40 amp service cost in my situation.
    Sure I could get a new service box and subpanel. Got an estimate for me?
  14. Bill Norton
    2,152
    734
    MONW, Ks.
    No estimate.
    I need an estimate too.
    I just bought a Bolt which is capable of using 40A EVSE.
    Alas, I'm going to live with two 3.3kW / 20A EVSE's in the garage because,,,
    I'm cheap and don't want to open my dusty old billfold and buy a proper 7.2 kW / 40A EVSE.
    Even though I'm capable of running my own 240V / 40A service to the garage.
    cheep cheep.....:p
  15. vvillovv
    4,321
    1,510
    NY
    funny I was just going to lookup a 25' 200amp stranded copper down wire this morning, but I had too many other things already scheculed for today. me too Bill cheap cheap ... lol
    Besides I have to submit receipts in triplicate for the double entry bookeeper. arrrr
    #255 vvillovv, Sep 15, 2020
  16. Bill Norton
    2,152
    734
    MONW, Ks.
    I assume you mean The Boss.;)
    You're lucky. I'm in an old 100 Amp house.
    Do I want to run the AC, Dry a load of clothes and Charge at 32 Amp? Probably not.....:(
    vvillovv and jerrymildred like this.
  17. jerrymildred
    11,517
    14,152
    Tampa, FL
    Same here. I even had to add a sub panel for charging since the original was full. The water heater breaker was bigger than it needed to be so I used that to feed the sub and then used the sub for the water heater and the charging outlet. The extra 16A for the L2 charger didn't hurt anything and I was already pulling similar current with the L1, but I suspect that a 32A charger might be pushing it. I should check sometime when the wife is running the dryer and hot water at the same time as the AC is running. (Or check them one at a time sometime when I'm simultaneously bored and ambitious. :D)
  18. Paul Rekow
    Paul Rekow Junior Member
    32
    Spencer, IA
    Hi Jimbo, I have a 30 amp 240v breaker in my electrical panel in my garage. I also have a second charger that came from my first Pip that got hit by a deer and totaled. My plan is to buy a 240 plug to put on the end of my old charger. A couple of questions. 1) is the 30 amp breaker heavy enough to handle the 240v plug on the end of the charger? 2) Is there a wiring diagram showing how to wire the 240v plug on the charging cord?
    Thanks,
    Paul Rekow
    (new prime owner as of last week, haven't figured out how to change my tag below:()
  19. fuzzy1
    10,452
    A 30 amp circuit is fine, even 20 amps is enough. But don't cut off the old plug to replace it with new, because (at least some) Toyota charge cords have a necessary temperature sensor inside. If you want to charge from 240V, a different solution may be needed.
    vvillovv likes this.
  20. Paul Rekow
    32
    Spencer, IA
    I went to Menards today to buy supplies to make an adapter and found a RV adapter (picture attached). Any reason why this wouldn't work.
    Thanks,
    Paul
