Using the Primes 120v Charger at 240 Volts, Cost $20 !!!
Discussion in 'Prime Plug-in Charging' started by Rob43, Mar 16, 2019.
  1. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Since these receptacles are on a common breaker, you are limited by your breaker rating, which is 20 amps. If you charge the Prime (12 amps) and put a full load on the 120V side of the receptacle, you can trip the breaker. That's not a flaw, just an observation.
    If you want to be able to draw full load on each side, then run additional conductors to a separate 1 pole 20 amp breaker for the 120V side.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    This is a good point/thought, though I might still keep things the way they are based on mveras1972's 12 AWG wire purchase.
    Rob43
    #122 Rob43, Aug 20, 2019
  3. fuzzy1
    10,413
    Another discussion pointed out that the Prime charges at 16 Amps from 240V. That is the maximum long term load allowed on a 20 Amp breaker, leaving nothing left over for continuous loads such as Christmas lights. Though 4 Amps remains available for short term loads, such as common power tools not running continuously.
    The snow blower simple can't run at the same time as a Prime charging at full rate, so it needs to be either time-shifted or put on a different breaker.
    The Prime can be set to a reduced charging rate of 8 amps. This would allow additional load on the 120V side of the outlet / circuit, including just the smallest snow blowers.
  4. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I think that current is for an L2 charger, and that the rate through the OEM EVSE is max 12 amps. When charging on 240 L2, the charge time is 2 hours. When charging on 240 stock EVSE, the charge time is 2.5 hours.
    It's not clear that the OP was running an electric snowblower, although that may be the case. I assumed the power was for the electric start.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    ....honestly, there's nothing wrong with time shifting "maybe" 3 or 4 times in a year.
    Rob43
  6. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Thanks for the feedback, guys. And yes I am aware of the 20A limit. I do not expect to exceed that since whenever I charge the Prius at night, I won't be plugging anything else to the 120V outlet. In the unlikely event I need to use my electric snowblower, I won't be charging the Prius at the same time. I say 'unlikely' in reference to how climate change is making snow storms less frequent in the last few years. Besides I have another 120V outlet in the porch from another circuit that I can connect an extension to. This is how I charged the Prius today. As for Christmas lights, these days LED lights draw so little power that I am not concerned about exceeding the amp limit. Last time I measured a 200-light string with my Kill-A-Watt it was just about a measly 10 watts!
  7. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    With this information, your planned installation should work fine. Typically, you are charging the Prime in the middle of the night, and not running the snowblower until morning; so these likely won't conflict with each other. The Prime will be charged by the time you run the snowblower.
  8. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Right.... and because it will be at 240V the charge should complete before I even go to sleep. :D
    jb in NE likes this.
  9. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Hey Rob, as a gesture of gratitude for all you've helped me, I would like to buy one of your custom made adapters. I could build it myself, but you probably have more practice than I do by now. As you've probably noticed, I will be using a 6-20R socket, and of course the EVSE has the 5-15P plug. I need the dongle to be as waterproof as possible since it will be sitting outdoors when charging. Let's chat over PM for details.
    Rob43 likes this.
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You may want to consider using a timed charge so the vehicle gets fully charged just prior to use. Per the manual this helps reduce battery capacity loss.
    mveras1972 likes this.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Installing two 240v outlets was smart ! That was a great way to "Future Proof" any long term EV needs.
    Enjoy your new adapter, it will serve you well for a very long time.
    Rob43 (y)
  12. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    50,000 !!!
    Rob43
  13. ed4271
    ed4271 Member
    107
    64
    US
    I use a charge point ev transfer . It is funny calling it a charger while it is not a charger. Tge charger is within the Prime. But I degress. I had a Electrician install a 40 amp breaker and the electric cable 50 amp max. Did that just incase I get an all electric car. Since my power is on a dedicated circuit I have no problem with power. 20181229_114922.jpeg
  14. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Curious, Why did you pick a NEMA 6-50R as you receptacle ?
    Rob43
  15. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Coming soon to my driveway: 240V charging! Here’s my new outlet I installed right next to where I park. It is a dual voltage outlet. It’s not live yet. Still working on it. Rob43 is making me a pigtail.
    iPhone ?
    Rob43 and Salamander_King like this.
  16. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    IMG_2495.jpg Just got the pigtail connected to my new 240V outlet (thank you so much @Rob43). As soon as I connected it went pufff! (just kidding) and nothing strange happened. The light came on as normal on the EVSE and a couple seconds later the familiar click when the car begins to charge. I won't get a sense of a full charge yet since my car was already almost fully charged from yesterday. When it got to 100% I got notified on my iphone that the car finished charging. Next time I deplete the battery I will check how long it takes to charge.
    Earlier today I finished installing the wire to my electrical panel and the 2-pole GFCI breaker and couple of hours later the post office delivered the pigtail. Since the outlet is dual voltage, I tested both 120V and 240V and both worked as expected.
  17. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    A couple of pictures of my panel during the install... The new breaker is in position 12 and 13.
  18. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    New installation how the new 240V wire comes out from the basement...
  19. Rieuk
    Rieuk Member
    103
    Pasadena
    I have also received a pigtail cable from @Rob43 (thank you!) and it is working pretty good! Was previously connecting to a standard outlet at work and I recently found a spot in the parking lot close to one of the warehouse garage doors which is great since just inside is a L6-30 receptacle supplying higher power. See the picture for the current hookup!
    I now need to just wall mount the EVSE to be safe from water and find some kind of holder for the charger plug. The car now charges in around 2h 30m.
    One thing that was frustrating is that there is no way to see what charge level the car is at unless you disconnect the charger, *close the port* and then get in the car and turn the car on to check the miles. What gives? I wanted to measure precisely what the new charge rate was since I'm not sure exactly what voltage the supply is giving me.
    The charge rate is one of:
    1. 3.8kW @ 240V, 16A
    2. 2.9kW (75% of 1) @ 240V, 12A
    3. 2.5kW (65% of 1) @ 208V, 12A
    4. 1.4kW (38% of 1) @ 120V, 12A
    Obviously not 4 since I upgraded from that.
    Rob43 likes this.
  20. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Based on your Prime charging in 2 1/2 hours, your answer is 100% number 2.
    You could always buy a cheap, or borrow a Volt meter to see your exact ~240 voltage.
    Congrats on your new fast & FREE charging success !!!
    Rob43
