Featured Utility Pole Charging
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by El Dobro, Dec 30, 2021.
  1. El Dobro
    El Dobro A Member
    7,103
    3,282
    Now this is interesting. Since the poles are already there, installation costs are reduced.
    And a follow up.
    52,821
    i've seen where some cities have brought the power to ground level in parking spaces
  3. hill
    9,026
    By 1968 nearly all new /planned communities were doing away with power poles & opting to go underground. Many light poles are 277v. Some EVSE's will deal w/it but beware. Underground power? good luck trying to tap into your local transformer
  4. El Dobro
    El Dobro A Member
    7,103
    3,282
    I live in an old town and the electric is over the poles, so this setup would work out pretty good.
    #4 El Dobro, Dec 31, 2021
    bwilson4web likes this.
  5. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    The wiring to the homes may be underground, but the transformers are usually at ground level.
  6. hill
    9,026
    Good luck tapoing 240v off of a 25-30 KVA residential Transformer.
  7. RRxing
    2,563
    1,842
    NEPA
    Still have to step it down somewhere aboveground.
  8. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    This won't work anywhere with a sizeable demographic of people who vandalize anything within arm's reach. Los Angeles is a good example. You can't even have concrete benches or picnic tables outside because people will knock them over or break them. In one area we had to custom fabricate trash dumpsters because people would push them quite a distance to roll them over the side of the road and into a gulley. I don't mean this would happen once in a while. I mean this would happen every two or three days.
