UV A/C Dye contamination
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wendellroadside, Jul 1, 2026.
  1. wendellroadside
    wendellroadside New Member
    United states
    Hello i recently purchased a 2015 ct200 that had been in a fender bender and replaced the condenser, i rented a vacuum and guage set from autozone and attempted to fill the Freon. After about 15 minutes of slow filling I got the compressor to kick on and the high side started filling up faster to 95 which it then stopped filling, the low side pressure keep fluctuating down to 20 when I close the valve for the r134a can, but fills back up to 90 for a about 7 seconds when I open the valve, the low side is consistently fluctuating back and forth but the high pressure seems to be stuck at 95-100 range and I can not possibly get it to go higher than that after 2 hours of attempted filling. Compressor was engaged and running constantly. Low pressure line felt ice cold to the touch a couple times I checked but was not staying cold. A/C still blowing warm. After I took off the Low pressure coupler I noticed the Low pressure port is covered in U/V Dye, after reading online I have heard that this can cause compressor failure and needs a full flush and compressor, condenser, and drier replacement, I also read somewhere else that it just needs to be evacuated with vacuum again and filled this time with non contaminated. I am not sure what my next steps should be as there is not much discussion online of this topic. I am unsure if the A/C was operational before the crash but I believe it was. Any and all advice will be appreciated thank you.
  2. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    It'd be awesome if we could get lots of commenters on this thread from @Tombukt2 @ChapmanF @Mendel Leisk and others. We used to have lech auto air conditionin | PriusChat helping us at length but he's been gone for more than two years and we really need a thread about DIY AC that has some substance to it.
    I'm going to start reading through his old posts and posting some of his quotes here. Hopefully I can learn how to help you with your situation, which will help me as I'm likely soon to be in your situation.
    wendellroadside likes this.
  3. PriusCamper
    13,452
    5,430
    Also Prius is a variable pressure system so its done by weight, not pressure....
  4. ASRDogman
    ASRDogman Senior Member
    8,060
    4,085
    That dye is horrible for any a/c system.
    The Prius a/c system is completely different than other system.
    And there are several articles/post about the a/c. Just gotta search. I know, it could be a pain.
    I seem to remember reading the best/proper way to fill the system is by weight, not by gauges.
    I don't remember how much, it might be on the sticker under the hood, but I'm not certain.
    I'll use 1lb as an example, 1 can, whatever it is.
    You can use a bucket of warm water to put the can in to force out the freon, or whatever you wish to call it.
    And it's very picky, 1 or 2 ounces too much or little, it won't work properly.
    Did you change the expansion valve also? And the receiver/dryer?
  5. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    But you say it this 95 number or whatever we're talking about here you're making cold the fat silver line is cold that means the freon is getting pumped and it is doing its job. So when it stops making the cold something must be happening the compressor is now not running you should be able to feel and hear that thenyou need find out why on a 95° day you're looking for 37 or so on the low side pretty consistently and the high side is going to be in the 200s I do believe .
  6. wendellroadside
    United states
    I bought the condenser from a premium I believe it comes with a new receiver built in, I did not change the expansion valve though, is it possible to remove it from the front through the firewall or do you need to remove the dash
  7. wendellroadside
    United states
    It was about 70° F out so I think the high side was like 55 to low but it would not take anymore, I could hear the sound of the compressor running the whole time and the sound never stopped, it was decently loud which I assumed was because it was low as I was filling it and I had the ac on max
    #7 wendellroadside, Jul 2, 2026
  8. Tombukt2
    13,853
    2,515
    Durham NC
    It seems you may be pumping but you're not pumping enough to make the cycle happen properly you're EXTREMELY low on his side . So lo side cannot stabilize . it'll just sit there and run forever . But not be correct .
  9. Tombukt2
    13,853
    2,515
    Durham NC
    The dye isn't going to hurt anything at all it's the bad oil that causes the problem so if you use dye with the correct oil and injected to gen2 system it will have no effect except the visibility you looking for.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,083
    6,944
    Texas Hill Country
    UV dye is no problem. R134a with oil or sealer is a problem on a Prius with high voltage running through the refrigerant cooled compressor.
    The system only requires 16 oz of refrigerant when completely empty.
    Assuming all bad parts have been replaced:
    Remove existing refrigerant.
    Pressurize with nitrogen and check for leaks.
    Vacuum and test that it holds within a couple hundred microns.
    Inject proper electric compressor oil if major parts were replaced or a large leak released oil.
    Fill with ac off using can in liquid mode. Most of 16 oz will fill in seconds.
    Start the ac and charge the remainder of the 16 oz as vapor or with short bursts of liquid.
    The sight glass will be clear.
    The actual charging might take 2 minutes.
    In reality the steps to recover, test for leaks, add oil so the compressor doesn't burn up and properly charge without adding air and moisture are best done by an experienced ac tech with proper tools.
    At the end you should have close to 40f air supplied to the cabin and a car that can cool down on a 95f day in 5 minutes.
  11. wendellroadside
    United states
    Okay, if there could have been trace amounts of conductive oil on the guage set I used would you recommend flushing the system, also is it possible to flush the gen 3 system without replacing most of the components?
  12. rjparker
    11,083
    6,944
    Texas Hill Country
    Trace oils will be acceptable but not desired. There is no way to flush a compressor or a dryer of oil contamination so you just hope it was a trace and not a r134 can with oil, sealant or "cooling enhancers" that could throw a high voltage code or cause acid formation.
    A bigger problem with gen3 is water or antifreeze in the low voltage connector when it is disconnected. That often becomes new compressor time.
    #12 rjparker, Jul 4, 2026
