V Subframe Replacement - New Aftermarket or Used OEM
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by madmax21, Jan 1, 2025.
  1. madmax21
    madmax21 Junior Member
    16
    Minneapolis
    Hi all, my wife's 2012 V needs a new subframe. I replaced the control arms last year, and turbo buggered the driver side as the original control arms were rusted to the control arm bolt. This also broke the attached nut/threads in the subframe. Long story short, I put in a temporary fix and now it's let loose. Rattles galore over bumps - so - time to fix my mistake!
    Looking on ebay - there are either new Aftermarket subframes or Used OEM subframes - I'm leaning towards the aftermarket since new=no chance for rust and also a better chance for the additional layer of rustproofing paint followed by Fluid Film to stick to everything nicely.
    Anyone have any insight/input? Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,490
    6,577
    Texas Hill Country
    I would get a used subframe from a southern state like Texas. No rust and no fit problems.
    Of course I am already in Texas and have no rust and no fit problems. Plus local access to used parts and a good independent shops run by a hard working guy. He does an engine swap a week and usually drops the subframe. He can replace an engine in a day.
    madmax21 likes this.
  3. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    I would vote for used OEM subframe.
    As RJ mentioned, purchase from a "sunny" state.
    The OEM could be expertly prepared by you before installing and should fit 100% with no modification.
    Good luck with your decision.
