Vaccine provocation
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Nov 11, 2025.
  1. bwilson4web
    16,533
    Sorry, forgot the units. Good thing I’m not calculating Mars trajectories.
  2. fuzzy1
    10,706
    I hope that Mars blunder was not in your court. But that error was by a factor of 'just' 4.5, the difference between pounds and newtons. This CPAP units difference is by a factor of about 70.
  3. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Nope. Mine's set by prescription to less, but have awoken to find (with no pressure leaks or discomfort whatsoever) that the machine has compensated to 12 (my face... interface? is nasal-only, which means it has two screens on either side to bleed excess pressure during exhalation). But tbh, a single roll in bed to break seal temporarily just once during the night, can cause this in my machine.
    Speaking of vaxes: had a weird, roundabout adventure today, to arrive at 'boy am glad my flu vax worked'...
    So journaled in my thread no one reads called 'Bodywork'... that R knee were really flaring up, like just as bad as week 1 after injury. Workouts had been I'd say 85 - 90% effective 3 mos nearly, walking, climbing and later doing balance exercises. All went to pot yesterday, as nothing I did as a bodyworker would get the knee to not be painful and 'trick'. Even walking were exhausting -- new since first week.
    So dejected, tried to rest by not working out, just wash / wax the car... again, nothing but draining pain and hobbling around max 0.75m/sec. Got home, did chores (CPAP cleaning, which is only slightly less annoying w/ my cobbled DeWalt drill + cut-up bottle-brush-on-long-spring) and went to bed hrs before normal bedtime -- which isn't me but damn, felt drained deep into the red. Add the fact acute pancreatitis twice in 15 mos the last Year of the Snake, from decades of drive-thru diet... had me worrying about the onset of another attack -- which I couldn't nail why, but also couldn't ignore the symptoms.
    Woke at 0418. Looked on my CPAP app, I'd slept 8hrs, 34 mins. I've gotten by on half that 20 yrs, and only when it dropped into the 3-hr range, did I seek help. But holy shite, felt great. Even the knee. So wanted to get my day going... without eating breakfast, tho (in case were actually on the edge of panc).
    [When you get idiopathic pancreatiitis, they have no idea why it's happening, that's what 'idiopathic' means. Usually when people roll into an ER / A&E screaming in pain and doubled over w/ lipase and amylase thru the roof, they're alcoholics. Mine were different diagnostic levels... so practically the only way you can get panc w/o being alcoholic, is thru extremely high levels of serum triglycerides. My blood was so loaded w/ these lipids first ER visit... the nurse showed me how sick I was, by simply shaking one of the blood vials: separated into a grey foam and brick red blood -- that grey was all fat, from rupturing the molecular capsules that permit it to travel to muscles in the bloodstream, called chylomicrons. My Tri levels were 1865mg / dL of blood. Normal, is 150... and treatment is to starve you for 6 days on a saline drip, painkillers and water / ice chips, so the GI tract can turn off and heal. You can get this way with a low metabolism + high simple carb / sugar / fat intake... and genetics from my cane worker ancestors, which for generations reinforced keeping triglycerides in serum rather than store it as abdominal fat, for quicker muscle access to fuel.]
    It wasn't panc, thank god. But did do some working out -- instead of vertical laps, walked up the ramps to the 4th-level -- which felt fine, and none of the gimping from Sunday. Did redo some aligning in the knee... and with an audible pop, my knee was actually taking load, w/o pain. Sore and tight in other areas of the knee... but that main one, on the inside condyle of the femur... was gone.
    Did just one round, up and down again. Then drove to another spot and walked a bit further, then to another. Each spot had zero climbing, just length of ~1/2 mile, not long. Huh -- so why in the hell do I feel so... normal today? When yesterday felt like toughing out the flu? Because I probably were...
    This flu season's rough, I hear. Was sure to get flu vaxxed as soon as. Reaction to being infected, which in really rough years the vax gives a thumbnail version of it, must've been why I felt so weak and inflamed. The proof's in my knee -- today walked about a mile in total, yet not even half the pain, and none of the weakness.
    But thanks, whomever had the flu and wasn't vaxxed. About convinced me 1) was about to get panc again, and 2) my knee was a basket case. Go take a long walk off a short effing pier :cautious:
  4. fuzzy1
    10,706
    12 what? psi? cmH₂O? mmHg? kPa? bar? torr?
    I'd think that 8 or 12 psi into the lungs to be exceeding painful, at minimum.
  5. ChapmanF
    19,019
    Or would it just make motorboat noises on your face?
  6. fuzzy1
    10,706
    Maybe that, after considering that such pressure would lift the mask off the face.
  7. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    D u n n o about that -- might've heard which units after the sleep study, but iirc, it's psi. The numbers are what's prescribed with my machine, and nothing in the ResMed app allows access to the prescribed settings - so no idea how to confirm units w/o calling the provider.
    My setting (if psi) feels actually a bit weak. The machine has a feature that lowers pressure to 3 (if psi) when it senses exhalation, and I have that enabled, set by the provider. Often gone as high as 12 (if psi), but doesn't always need to go there; frequent spot is 8 - 9. If the machine drops to 3 psi during exhale tho I wouldn't feel discomfort, and certainly wouldn't be hurt by it, using daily since May. Remember the mask has exhaust ports open at all times to prevent overpressure situations; the machine is designed to take this into account.
    Chappy has a point re: farting on face -- my veteran friends in Y2Ks waved me off CPAP, as back then all the VA had were F-16-fighter-like full face masks on machines that set pressure so high that it'd literally face-fart, if you moved at all. But this modern machine, as frustrating as cleaning it is, isn't anything like those contraptions from 15y ago. Closest thing is if I roll too much and physically pull the nasal mask crooked, then it makes a bit of whooshing noise... or switching off and leaving the hose connected after waking up, and going to the bathroom. When I get back sometimes the machine'll blow full pressure thru the whole kaboodle for some reason; other days nothing. So no Bronx cheers - do not know <-- this is hilarious, 'do not know', gtfoh, about others who actually need the full masks, tho. Better to ask them.
  8. ChapmanF
    19,019
    As already covered in #60 upthread, those numbers will be centimeters water column. A pressure of 12 cm H₂O is enough to hold up a 12-centimeter-high column of water in a vertical tube.
    A pressure of 12 psi will blow the water out of the tube, unless the column is 28 feet tall.
    futurist and fuzzy1 like this.
  9. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Interesting. So 12cm = 4.724 in. Enough pressure, to hold a not-quite 5" column of water in a vertical tube? And what's the diameter of this tube, to know how much water that is? Is there a standard for this? At any rate, doesn't seem like the same pressure I feel when it's hits that on the ResMed.
    My main hose has an inner diameter of 15mm. With the hose still attached, I've unwisely tried in past to sanitise the hose w/ hypochlorous acid, w/o unplugging it -- which means it can randomly decide to energise and blow scrip pressure (6.0).
    When the hose forms bends lower than the rest of it, the sanitiser can collect in the loop, enough to block all 15mm. This forms maybe 1" - 1.5" of actual blockage... but this has also blown nearly the entire amt (12 pumps in each end, or ~ a tablespoon) out the free end of the hose, much to my soaking wet dismay; yep let's not do that again :p
    So if dbl that pressure only holds up 5x that amt of water (the hypo acid solution is mostly saline), in some graduated standard tubing used to measure it... how does half blow a fifth of that, out a tube 15mm wide and 3 ft long, with enough force to need a towel?
    Not disputing if ResMed indeed uses that unit to measure what's on my machine's display, that's what it is. Just doesn't make much sense when explained that way.
  10. ChapmanF
    19,019
    The diameter of the tube doesn't matter; here's why: say the vertical tube has circular cross-section, its area is π(diameter÷2)² and that's also the end area of the cylinder of water within it. The volume of that water is its height (12 cm) ✕ the end area. Its weight is that volume ✕ the density of water.
    Now, pressure is force ÷ area. The pressure is the downward force (weight of the water column) divided by the area. Remember the weight is the height of the column times its area. So pressure ∝ column height ✕ area ÷ area. The area cancels, so the diameter of the tube doesn't matter (nor even whether it is circular or has some other cross-sectional shape).
    That's why water column height (whether cm of water or inches of water) is a valid way of specifying pressures, and why passable water-tube manometers for measuring pressure aren't hard to build, using whatever kind of tube is lying around.
    Without watching that happen, it sounds like you weren't holding the tube in the style of a manometer
    Your prescription pressure would just support, against gravity, 6 cm of water raised in a vertical tube. In practical terms, that means the pressure can push the water down one leg of a U until there is a 6-cm difference in height between legs. (The total amount of water in the U tube doesn't matter, just the height difference between the legs.)
    [​IMG] Image credit
    If your pressure is high enough to push all the water to the other side of the U, you'll just have a bubbling device, not a manometer anymore. ;)
    futurist likes this.
  11. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    First, appreciate having the presence of mind not to flame me just for asking questions as a junior member here -- often my objections and requests for clarification on other forums (sadly car forums) usually go the least-effort path of expletives / jokes at my expense. And that was a great explanation I'd no trouble digesting -- again thanks Chappy :notworthy:
    Re: way of holding the main hose -- wasn't plumb-vertical, but was sitting with the U under my big toe... so pretty close. Had to change my uniform and wipe down screen and keyboard :confused:
    I'd been so distracted by the mild acid solution in my eyes :p didn't think to look at the ResMed display for what pressure was being pushed thru... so technically can't guarantee the pressure spiked was 6 or 12 cm/H₂O... but have zero access to any settings that can take my scrip pressure higher (the machine has to decide that itself, and assuming that has regulated limits too). Max seen on other days was 12, so assuming that's what gave me a bath :p
    You'd think... with the interior of the main hose 1) not being totally smooth, 2) not totally vertical, as has a couple of bends from sitting in packaging on a shelf months if not years (had just been replaced when this happened), that I'd not be soaked... that the pressure would've just puffed thru and the solution dribbling around the edges of the pressure differential, using the spiral surface of the hose interior as purchase to help do this. Nope, right in my face... could I have pulled the hose taut when this happened? Don't remember... but man, may think about a 19mm original hose rather than this slimline 15mm one, if it avoids that again -- let's see a tablespoon of water puff out of 3 ft of hose 4mm bigger inside :cautious:
  12. ChapmanF
    19,019
    When a manometer is being a manometer, its behavior is a hydrostatics exercise. Nothing is flowing, the fluid is just sitting there, filling the bottom of the U fully and a bit up both sides, with a certain pressure on each side.
    If the fluid amount is small enough to not keep the U bottom filled when the pressure is applied, there's a fluid dynamics exercise instead. Acid spritzer, anyone?
  13. bwilson4web
    16,533
    COVID
    Vaccinated for both living in North Alabama.
    futurist and bisco like this.
  14. bisco
    52,847
    it's been mild around here so far. i hope it stays that way until we leave for florida
    bwilson4web likes this.
  15. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Vaxxed for this season. Took me down enough pegs getting immunity; hope fewer tourists from LA and CO decide to visit -- I like our 'low' rating despite tourism being 80% of our economy... let's hope it stays there after the NY...
  16. ETC(SS)
    7,548
    If the vaccinations are effective, you should hope (as I do!) that MORE tourists would come......
  17. bwilson4web
    16,533
    Not very likely now: US could ask tourists for five-year social media history before entry
    Tourists from dozens of countries including the UK could be asked to provide a five-year social media history as a condition of entry to the United States, under a new proposal unveiled by American officials. The new condition would affect people from dozens of countries who are eligible to visit the US for 90 days without a visa, as long as they have filled out an Electronic System for Travel Authorization (ESTA) form.
    Since returning to the White House in January, President Donald Trump has moved to toughen US borders more generally - citing national security as a reason. Analysts say the new plan could pose an obstacle to potential visitors, or harm their digital rights. Asked whether the proposal could lead to a steep drop-off in tourism to the US, Trump said he was not concerned.
    "No. We're doing so well," the president said on Wednesday.
    I understand Nero played a fiddle while Rome burned.
    Bob Wilson:
  18. bwilson4web
    16,533
    Good news for vaccine skeptics: https://www.reuters.com/business/healthcare-pharmaceuticals/fda-probes-possible-link-between-covid-vaccines-related-deaths-across-age-groups-2025-12-09/
    Dec 9 (Reuters) - The U.S. health regulator is investigating deaths potentially related to COVID-19 vaccines across multiple age groups as part of a safety review, a spokesperson for the Department of Health and Human Services said on Tuesday. . . .
    Health Secretary Robert F. Kennedy Jr. has sharply changed government policy on COVID vaccines, limiting access to people 65 and older as well as those with underlying conditions.
    Kennedy, a longtime vaccine skeptic, has made far-reaching changes to the U.S. vaccine policy, which include dropping a long-standing recommendation for the hepatitis B birth dose, cutting funding for mRNA vaccines and, contrary to established science, linking vaccines to autism.
    Any results will be suspect as it is likely RFK Jr. will assign a vaccine skeptic to "do the study."
  19. fuzzy1
    10,706
    The international tourists who are not coming, are likely staying away for entirely different reasons.
  20. bisco
    52,847
    how does one gather their social media records?
