Vacuum Line for 2nd gen Prius
Discussion in 'Newbie Forum' started by PS07, Mar 18, 2017.
  1. PS07
    PS07 Junior Member
    Los Angeles
    Four Touring
    Good evening! I've known Priuschat for some time now and now how important it is. Today is my first post so I hope you can me out!
    I've looked around online but couldn't find answers to locate the vacuum line for the 2nd gen Prius. Does anyone know where to locate it? Thanks
    52,876
    welcome!
    idk, but if you don't get an answer here, you can sign in at toyota tech info, and find it in the literature for $15.
    all the best!(y)
  3. ChapmanF
    19,041
    Which vacuum line? What is it you're trying to do?
    Mendel Leisk and Raytheeagle like this.
  4. Mendel Leisk
    42,361
    Yes. Any modern car tends to have a lot of different vacuum lines, different diameters, locations. And chances are a generic automotive retailer would be able to sell you something compatible, by the foot.
  5. PS07
    PS07 Junior Member
    Los Angeles
    Four Touring
    Lol my bad. Was in a rush last night that I forgot to punch on the details.
    I'm in the process of doing a proper seafoam treatment and needed to know where the vacuum line for the brake booster is.
    Pics would be great! If you need more info let me know
  6. Mendel Leisk
    42,361
    At the brake booster? (n)
    Raytheeagle and bisco like this.
  7. PS07
    PS07 Junior Member
    Los Angeles
    Four Touring
    Or any "vacuum line that services all of the cylinders". I need to get this seafoam in the engine somehow
  8. ChapmanF
    19,041
    Happy Prius driving! The brake booster uses an electric pump for pressure. No vacuum line. (There might be times when the engine isn't running, but you'd like to use the brake anyway.)
    Maybe you can get your seafoam in using the nipple for the evap system purge line, or the PCV valve.
    Does your car seem to need a seafoam treatment?
    -Chap
    Raytheeagle and Mendel Leisk like this.
  9. PS07
    PS07 Junior Member
    Los Angeles
    Four Touring
