Valve lash adjuster procedure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Richard, Aug 31, 2021.
  1. Daniel Richard
    49
    26
    I
    Can someone please link the “valve lash adjuster procedure” to this post. I tried searching for it, but could not find it. Thanks!!
  2. ChapmanF
    15,563
    What procedure do you want exactly? 2010 Prius valve lash adjusts itself.
    Are you thinking you have a bad adjuster? If so, you just replace it, but I don't know if I've ever heard of one going bad. If you have to replace it, you're looking for the valve train disassembly/reassembly procedure from the repair manual (more info).
  3. Daniel Richard
    49
    26
    I
    It’s an inspection procedure on the lash adjusters.
  4. Mendel Leisk
    38,706
    That’s a cylinder head removal instruction lol. 3rd gen Prius has automatic, hydraulic adjustment, using oil pressure.
    Coming from years of Hondas, I used to do the adjustment, but with 3rd gen Prius no adjustment is needed, or possible.
  5. ChapmanF
    15,563
    There is a procedure for testing the adjusters, involving immersing them in oil, and a skinny tool to poke the check ball. It's included in the cylinder head overhaul instructions. Presumably anybody who is looking for that procedure already has the valve train apart on a bench.
