Tags:
  1. Tim_Auckland
    Tim_Auckland New Member
    Auckland
    The following is a quote from the YouTube comment referencing a Prius gen 3 knocking problem.
    "This problem what is come from the valve lifter. Open the head of engine, check the valve lifter, one of them was bad (not compress then release). Just change that one, it will be solved. It happened to my car, I changed many things, then I found out this is the main problem."
    Has anyone that a problem with a valve lifter? Know how to troubleshoot this issue? In the above comment does open head just mean "remove valve cover" ?
    52,814
    doesn't sound familiar. have you cleaned the egr circuit and intake manifold?
  3. ChapmanF
    18,998
    The Gen 3 does have hydraulic valve lifters. They adjust their own clearance by having engine oil pumped into them, and they have little check valves to keep the fluid inside so they are stiff enough to open the valves. If one gets leaky, it may make a tapping noise. You can replace it with a new one (or sometimes just clean it well in clean oil and it will work again). There's a test for it in the repair manual, with a little pin-like service tool to push on the check ball.
    Just think how much simpler this is than Gen 1 or Gen 2, where the only way to correct valve clearance if it gets off is to buy replacement lifters in different sizes (35 different sizes, and 16 lifters in the engine). Gen 3, there's just one lifter part number (even the same for intake and exhaust side!), and if one is stuck, you clean it or put in a replacement.
    Still, I doubt there's any way you can sneak them out and back in without removing the camshafts, so it's a fairly involved operation. You'll want the details in the repair manual.
    -Chap
    Mendel Leisk and Tim_Auckland like this.
  4. Tim_Auckland
    Auckland
    Great info thanks. The manual seems to calls them valve lashers. I think the above comment I was looking at from YouTube might be a bit of a troll.
  5. ChapmanF
    18,998
    I think it calls them valve lash adjusters. The "lash" is another word for the clearance, or the amount of motion that happens before the valve is pushed open. By filling with oil and expanding, the adjusters keep the lash very close to zero, keeping the wasted motion and tapping noises at bay.
    Hydraulic lifters, or lash adjusters, are not a new idea; my 1988 Mazda had them, as did a friend's 1965 Ford. A clever thing Toyota has done is put them at the other end of the rocker arm, so their mass does not have to move up and down with the valve. They just sit there. :)
    -Chap
    Tim_Auckland likes this.
  6. Tim_Auckland
    Auckland
    Yes, I'm quite a long way down the list but I don't really want to start a thread on that just yet.
