Valve Stem Caps
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ClydeSDale, Dec 3, 2021.
  1. ClydeSDale
    ClydeSDale Junior Member
    North of St. Paul, MN
    2017 Prius v wagon
    Checking tire pressure on our 2017 level 4 is really a pain because the stems and the caps are deeply recessed in the wheel covers. It's was really difficult to get my fingers into that little space to remove and replace the caps. I solved the problem by using a nylon hose barb, 1/4" pipe threads X 1/2" hose, to reach into the opening and slide over the cap to friction grip it so it can be easily worked with.
    gromittoo likes this.
