Valve stems
Discussion in 'Gen 3 Prius Main Forum' started by mjones12, Jan 23, 2013.
  1. mjones12
    mjones12 Member
    115
    26
    North Carolina
    Unless you have fingers the size of a child's, the valve stem caps are almost impossible to get off without removing the wheel covers. I had to use a pair of needle-nose pliers just to get my caps off today, and I have small hands. What a ridiculous design flaw for a car that depends on proper tire inflation for the best mpg.
    pichner likes this.
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    If it is a real problem, You can stop by a auto parts store and buy extensions, they are cheap.
    WE0H likes this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,916
    Herefordshire England
    Another alternative when you change tyres have longer valves fitted.
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
    +1 better than my option, but a little more expensive. :)
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    The stems are part of the TPMS sensor. It will be expensive to lengthen.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    True, kind of forgot about that, my bad.
  7. Britprius
    5,194
    1,916
    Fair comment running a gen2 I do not have that problem. However when fitting new TPMS valves is this not an option "just wondering". TPMS systems seem to be a money maker for dealers and tyre fitters. Why can't they be made sepperate to the valve and screw into the rim externally so they could be serviced "battery change" and even changed from rim to rim for summer to winter tyres. Yes I know the answer "no profit".
    John (Britprius)
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    Customer friendly, Never!
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    This is what CAN be replaced on a TPMS.
    TPMS Rebuild Kits
  10. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    See this thread for a good solution - you don't need to take these off to check the tire pressure or add air.
    I looked into getting them from the source in that thread, not a bad deal at $2 each - but the shipping would have been almost $11! I ended up buying a box of 50 from another source, and so I have some extras. If anyone wants them I can do a few sets at $8 for four, free shipping in the USA. PM me if interested.
  11. retired4999
    2,652
    625
    Eau Claire, Wi.
    Thats like nothing! :eek:
  12. retired4999
    2,652
    625
    Eau Claire, Wi.
    Thats just what they need great job! (y)
  13. hlunde
    hlunde Member
    419
    74
    All vehicles rely on proper inflation pressures, for both fuel economy and safety.
  14. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    I have never had an issue removing the valve stem caps, and I have huge fingers.
    iPhone ?
  15. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    OP, valve extensions were a good suggestion. ;)
    Or, you can do what I did. Ditch the wheel covers, I have no problem accessing the valve covers on my naked wheels. :D
    Corwyn likes this.
  16. mjones12
    mjones12 Member
    115
    26
    North Carolina
    So am I understanding correctly that the simple extensions would have no harmful effect on the sensor system? Thanks.
    No argument there. My point was that a vehicle specifically designed, on many levels, to provide high gas mileage should - more than other vehicles - make it easier to access to the valve stem caps. The Prius is all about gas mileage. Many other vehicles are not.
  17. xliderider
    7,872
    3,116
    Honolulu, HI
    TPMS sensors measure the pressure inside the wheel. Putting valve extensions on the valve stem will have no effect on the TPMS sensor.
  18. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Extensions no; I was commenting on since the valve stem is part of the TPMS assembly, replacing it with a longer one means replacing the TPMS assembly.
  19. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Hmm, my wheel covers have no effect on access to the valve caps. I guess that's because they are hanging on the garage wall. ;)
  20. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I just purchased some valve stem caps at WalMart and noticed the cheap black plastic ones are marked TPMS safe, and the fancy metal ones are not.
    A little research online indicated TPMS do not like metal caps, because dissimilar metal electrolysis can produce a current big enough to damage the sensor.
    Word to the wise, do not put metallic caps or extensions on TPMS valves...
