Vampire hunting
Discussion in 'Environmental Discussion' started by Celtic Blue, Feb 19, 2009.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I don't, and wouldn't, b/c I'm afraid and have no idea what I'm doing around high voltage stuff. But I doubt it would surprise me...I just prefer to pretend it isn't happening.
    Like I said, it stays unplugged and in a room she rarely wanders into, so the risk is small...and her fingers are getting bigger.
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    One other option is to buy stuff that has insignificant load. Before buying something, maybe a quick quiz on PC might make a difference. Let me make the first volley.
    Any recommendation for a cordless house phone?
    (The old one is good for a constant 4W drain, but is getting flakey with some of the keys having too much liquid and food dumped on them.)
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Aw, ya big sissy, geez. It's only split phase with a maximum possible 240 vac.
    And even if worse comes to worse, and you happen to drop a wrench across the bars and the main breaker faults closed, I'm pretty sure the recloser will sense the dead short and pop open
    Just keep in mind that most reclosers are programmed to close again after about 20-60 secs. Hence, "recloser"
    Ah, denial. That works for me too, that way I can pretend the world is a nice place, people are good, etc etc
    I'm keeping my fingers crossed that if we plot a graph of a constant - the width of the shredder opening - and the diameter of her smallest pinkie, the growth curve will very soon intersect the horizontal paper shredder width line
  4. jayman
    13,439
    641
    Winnipeg Manitoba
    Sorry, can't help you there. As far as I'm concerned, all cordless phones equally suck. Let's not forget that when the power fails, so does the cordless phone
    Oh sure, you could plug the cordless phone base station into a UPS, but it's kind of silly.
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    I'm glad I read through that again - I missed the A/C thing the first time round
    A lot of outdoor A/C compressors have a crankcase heater. It's usually pretty easy to notice, peek down from the top where the coil fan is. If you see the compressor down below covered by a blanket of sorts, it probably has a crank heater
    The purpose of the crank heater is to prolong the life of the compressor, especially if it can be programmed to priority dehumidifaction in damp climates.
    That means the A/C usually has a variable speed air handler inside the house, and a two speed Scroll compressor outside. On a day that is too cool for regular A/C, say 60-75 F, the system can run with the indoor air handler at the lowest possible speed to dehumidify
    It really works well. You can barely feel air coming out the registers, but on a damp day the indoor humidity will be 40-45% tops
    When running a compressor below 70 F, the oil can be a bit viscous. This can cause rapid wear of the compressor, and can even cause the reed valves to break. The crank heater helps keep the oil warm
    The crank heater on my A/C sucks up 60 watts. I only keep the A/C breaker on during the actual cooling season, the rest of the year it's turned off. I also have programmed the system to lock out the compressor once the outdoor temp is <55 F
    Warning: the first time you apply power to the A/C breaker, wait at least 2 hours before attempting to run the compressor. Give the heater time to warm up the oil
  6. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Yep, I did the same thing for the same reasons until a few months ago when the kids were finally old enough that a lecture and demonstration made it clear this was not a toy. Related tip for winterizing: the socket safety covers help seal drafts from the actual sockets on external walls. I had a couple of sockets that were blowing a surprising amount of cold air in until I safety capped them.
    Interestingly, looking back on it I was immobilizing the shredder for the kids the wrong way. I was leaving the heavy transformer plugged in, but disconnecting the little circular power jack into the shredder (and tucking it out of sight.) That was easiest of course, but it was wasting energy as the transformer is where the losses come from, not the actual device, if I understand correctly. (I have not actually checked this with my Kill-a-watt...I've got another test running at the moment.)
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Geez, you'd be surprised how many homes don't have proper vapor barrier installed (Seams tuck-taped, acoustic sealant at the sill and top plate, etc). Of course, if you feel a little breeze blowing in, that also means a lot of condensation is happening inside the wall cavity
    Condensation + cellulose = mold. Lot's and lot's of mold
    Those little transformers are really wasteful. All those little bricks used for computer speakers, inkjet printers, cell phone chargers, etc
  8. Celtic Blue
    2,224
    139
    Midwest
    I've done a retest now, and as expected the transformer is pulling power if it is plugged into the socket even when not connected to the shredder itself.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Maybe I missed this, but how much? I'd guess 7-10 watts? I have a large brick transformer for an older HP inkjet that reliably sucks up 10 watts even if the printer is unplugged from it
  10. jayman
    13,439
    641
    Winnipeg Manitoba
  11. Celtic Blue
    2,224
    139
    Midwest
    It's pulling about 4 watts. It's got a hefty enough brick, with claimed 15 V dc and 20 watt output, but it runs relatively cool.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    Ah. That HP one I mentioned runs pretty hot even with the printer unplugged from it
  13. patsparks
    10,664
    567
    Adelaide South Australia
    Move to Australia and replace all your current stuff with Aussie compliant stuff, you will never look back. It's incredible how 240 volts 50 hertz can change your life, the sun shines brighter, there is less paranoia, people walk on the streets at night even if they aren't in a gang, etc. Not joking.
  14. jayman
    13,439
    641
    Winnipeg Manitoba
  15. Celtic Blue
    2,224
    139
    Midwest
    Time to add another vampire measurement:
    2nd (larger, 1/2 hp) garage door opener draws 5W while idle as compared to 3W for the smaller one (1/3 hp). Even with incandescents and being operated twice a day, about 75% of the power use of these doors is just sitting there idle.
    Garage door openers would be a good candidate for Energy Star rating. Perhaps the new ones use less standby power (anyone measured?) It should be possible to get rid of over 75% of their typical energy use just by converting them to CFL's and minimizing the standy receiver load. Of course I'm comparing to 90's vintage, so perhaps they've already been made more efficient.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Nope, I checked my Chamberlain opener, which is 5 years old, and it also draws 4-5 watts. The transformer inside that thing doesn't look very efficient, it feels very warm to the touch
  17. Celtic Blue
    2,224
    139
    Midwest
    Found another vampire...okay...this one was an oversight: the portable stereo, 2 watts idle. I have an old CD boombox in the garage that I use when I'm hammering away at the heavy bag (110 lb water bladder w/foam exterior so that I can drive into the punches properly without developing various boxing injuries.) I had been leaving it plugged in since there was no external transformer block and it was not showing a display or anything. I was treating it like a toaster. Mistake! It's been sucking on the main while I'm asleep.
    The good news is that this has prompted a bit of backlash by me against vampires that I had been tolerating/meaning to get to later. I drove a stake through the heart of 10 watts total today. There are some more complicated ones that I've not yet addressed.
  18. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    So that's what you do after you Prius Chat sessions. (I have no idea if I'm serious or not.)
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    I use meth-mouth hillbillies and losers. Much, MUCH more satisfying ...
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    One of my pet vampires is the cable TV box. That sucker is as hot as a toaster even when idle. I can't conveniently cut its power, since it takes hours to completely reset after a power outage. On the other hand, there is no reason it needs to run so hot when idle.
    The problem is that that cable boxes are owned by the cable TV company. What do they care if they use your electricity.
    Tom
