Vampire power drain?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Cybergooch, Aug 6, 2024.
  1. Cybergooch
    Cybergooch Junior Member
    North Bend, Oregon
    About 4 years ago I got a new 12 v battery. For the last few months, I'm having an issue where my car will not start if it's been sitting idle for a week or more, and I have to put a charger on the battery. (I work from home, so the car sits for periods of a week or more on a regular basis.)
    I have an appointment tomorrow for a new battery, but I'm also wondering if this is a standard problem
    The only thing that's using any power is the little red flashing light that shows the alarm is on. Is that enough to drain the battery? Is something else going on?
    52,785
    there is a constant drain on the 12 volt when the car is off from electronics.
    if you aren't going to drive more, put a battery maintainer on it.
  3. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    It's a fairly standard problem. It's worse if you keep your smart keys near the car, because the computer can get faked into thinking you are getting ready to depart, which wakes up a few other circuits and thus draws more power, at least for a few minutes until it realizes you aren't getting in and going somewhere.
    You can always hook up an ammeter and check the actual draw, but if you aren't driving much you'll likely want to invest in a battery maintainer.
  4. Cybergooch
    North Bend, Oregon
    Thanks for the replies, I'll look into a battery maintainer.
    Brian1954 likes this.
