Variable exhaust valve
Discussion in 'Gen 3 Prius Technical Discussion' started by Mrpcar, Feb 16, 2013.
  1. El Dobro
    El Dobro A Member
    7,106
    3,282
    Yep, got that. Now where is the "main muffler" that it mentions? If it's the one at the back, then it's not the valve that the OP is talking about.
  2. bwilson4web
    16,535
    The OP misidentified the coolant heater as an "exhaust valve." Prius exhaust valves are mounted in the cylinder head and are operated by the overhead cam.
    There is a spring-loaded, by-pass valve in the muffler at the rear of the car. The OP insists on calling an exhaust by-pass valve as an "exhaust valve."
    • "exhaust valve" - a poppet valve located in the cylinder that is operated by the cam to let the very hot, glowing exhaust gasses out. It looks very similar to the intake, poppet valve.
    • "by-pass valve" - a spring operated valve that opens in the muffler to reduce back pressure at high gas-flow rates (aka., power settings.)
    • "exhaust coolant heater" - the part the original poster photographed that simply speeds up engine warm-up
    mtbiker53 likes this.
  3. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Bob,
    Just semantics, everyone knows what an exhaust valve is. Like everyone calling a 30 round semi-automatic rifle magazine a "clip".
    If makes you happier then we will just call it muffler by-pass valve
  4. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    Call it what you will...:rolleyes: Not everyone knows everything, just yet.
    Just a newbie learning here with interest as to what makes our cars go... and not having my "teacher" overlooking over my shoulder to describe what is explained as he is at work at the moment. I'm still in Hybrid Engine 101...;)
    Mrpcar likes this.
  5. bwilson4web
    16,535
    An engineer by training and habit, I tend to get a little persnickety about labels used for technology. Sad to say, the title "variable exhaust valve" remains somewhat misleading which is what first caught my eye. But there is history in tweaking the exhaust valve duration.
    There has been some literature on exhaust valve duration being extended to increase the exhaust gas recirculation (EGR) to mitigate high power, exhaust temperatures. However, the higher temperatures inside the cylinder leads to a knock problem in spark ignition engines. This is why Toyota's 'cooled EGR' allows a higher ratio without inducing knock. In a diesel, EGR temperature is not a problem since ignition occurs with fuel injection timing.
    Please understand I'm more interested in making sure we're all on the same sheet of paper. Shoot, I'm an older guy and am well aware of having 'a senior moment' when the precise term escapes me.
    mtbiker53, OceanEyes and Mrpcar like this.
  6. Mrpcar
    542
    253
    Chino Hills, CA
    Bob,
    No worries, I think in a long run it's better we all use the right term and terminology to describe all these new advance technology. So thank you for the correction for everyone's sake.
    Huntsville, you work for NASA? I used to visit Huntsville often when I lived in Atlanta. Heck, I even bought my Mercedes in Huntsville. Better deal there.
  7. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Correct. The OP was showing the exhaust heat recovery unit, which is right after the cat. The "variable exhaust valve" is part of the "main muffler". The main muffler is near the end of the exhaust pipe. Note that the engine also has variable exhaust valve timing (the poppet valves in the head).
    And Bob is correct in insisting on using the correct name. This thread is a perfect example of this requirement as it has nicely confused the three "valves". There are -three- things that could be called an "exhaust valve" or "variable exhaust valve" so correct naming is necessary to keep them straight.
    Note that one reason the GIII got the 1800cc engine is it has better "variable cam timing" or "variable exhaust valve timing" than the 1500cc engine. This allowed better control of the engine parameters for better power and fuel economy in the "Atkinson" configuration and hybrid system.
  8. Mrpcar
    542
    253
    Chino Hills, CA
    Side note, it's a full time job keeping up with all the new manufacturer specific terminology on their technology.
    Porsche - PSM - Porsche Stability Management, Variocam - Their variable valve timing, Variable exhaust - Well, not to be confused with exhaust valve. Basically is their version of a variable muffler
    Ferrari - Variator - Their version of variable valve timing. Variable exhast - again I am talking about the muffler here.
    See now why I called is a variable exhaust? Should have just titled it "variable exhaust".
    bwilson4web likes this.
  9. bwilson4web
    16,535
    LOL!
    Like GM calling their Belt-AsSisted (BAS) hybrids a hybrid. The more appropriate term was Belt-AsSisTed And RetArDed (BASTARD) hybrid.
    Still, having studied Latin, French, and Japanese, I am sympathetic to the problem of language and finding an accurate translation.
    OceanEyes likes this.
  10. OceanEyes
    527
    424
    A Gaelic translation might be a wee bit more of a challenge...;)
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    A Flux Capacitor, I know one when I see it! :D
    Mrpcar, OceanEyes and pichner like this.
  12. bwilson4web
    16,535
    You could say it but you couldn't speiligeadh.
  13. OceanEyes
    527
    424
    Go Bob!!! In my world it is all about "Saoirse."
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    My TDI had an electrically controlled flapper valve in the middle of the exhaust system. It was there to force exhaust gases back through the EGR system. That's what I was thinking of when the OP thought there was a valve in the middle of the exhaust.
