Variable valve timing solenoid broken connector changed p0010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tommy West, Nov 29, 2022.
  1. Tommy West
    Tommy West Junior Member
    51
    In a Prius
    I definitely had a broken wire on the variable valve timing solenoid. I changed the connector. The code is still showing p0010 after changing the broken connector. Does it take a while for the computer to remove the code. I tried clearing it but it remains.
  2. Mr. F
    Mr. F Active Member
    386
    253
    Washington
    You've got a permanent DTC. Since you've most likely fixed the problem, you can make the code go away for good by obtaining a normal judgement during 3 consecutive driving cycles.
  3. ChapmanF
    17,349
    Some scan tools will show a permanent DTC as such, so it won't be confused with a current one. But maybe not all of them are that helpful.
