VCS no codes
Discussion in 'Gen 2 Prius Technical Discussion' started by William Lowe, Feb 21, 2017.
  1. William Lowe
    William Lowe New Member
    Raleigh
    I have checked the forums but I am not seeing a similar issue.
    I purchased a 04 Prius 3 months ago with 89k miles on it. It now has 93k as I had to move to a new state for a job so I added some miles to it.
    After moving I changed the oil. Before I did, I had a red exclamation point come on, check engine light, mx required and also vcs.
    I changed the oil and the lights never went off so I took it to auto zone. Autozone told me it had to do with the oil and reset my lights for me. They also checked for any codes but no codes were found.
    Since that day my vcs light has been coming off and on randomly when I drive. When I drive the car for 10 min it comes on.
    Could this be the 12 v?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The oil change had nothing to do with the lights. If I read your post correctly, the lights were on before the oil change. Even if not, an oil change should not cause error lights as long as the correct amount of oil was used in the refill.
    If the red triangle, check engine and vsc lights were on then there were codes triggered that triggered the lights. If Autozone did not use a Prius-specific code reader it may have only read the check engine light code.
    A low 12V can cause random codes to be triggered. The battery voltage should be 12.5-12.9V after sitting overnight. If less than 12V it can result in random codes and should be replaced.
    bisco and valde3 like this.
  3. William Lowe
    Raleigh
    I tested the battery and it was at 12.6 when I did a system check it was all blue accept audio h/u that said check.
    When I turned the car on to test the battery there was no vcs warning light. When I drive home today i will let you know if it comes back on. As I said, it only comes on driving for about 10 min. Also my pump works as I have turbulence in the coolant. I called Toyota and they want to charge me 130 dollars just to look at it and I don't have the funds for that right now :/
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    You do not want the car on when testing the battery. You will be reading the battery charging voltage which should be 13.5V+. You want to read the voltage after the car has been off for a few hours and with the engine and everything off.
    If possible read the battery voltage at the battery terminals.
    If the lights come back on drive to Autozone and see if they can read any codes.
  5. bisco
    52,532
    welcome!
    if you don't have the funds to have it repaired, are you going to diy?
  6. William Lowe
    Raleigh
    Yes if I have to. But I want to make sure the lights are not turning on because the red exclamation mark is still on. On my way home I never got the vcs message. It was a 45 min drive on high way and main roads. Also in rush hour. Do you think that could cause the light to turn on?
    Btw when I tested the battery the car was off no engine running
  7. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    As mentioned in post #2, Autozone probably used a generic reader that cannot read many of the proprietary codes the Prius uses. You really need to buy the right scanner or pay someone who has one. Many of us here use the Mini VCI which only costs about $20 (but needs an old 32-bit Win 7 laptop).
    By the way, it's VSC, not VCS, for vehicle stability control. Without codes from the VSC ECU, we're just guessing what the problem might be. Take another look at the 12 V after the car sits overnight, as that appears to be the most common cause of a VSC issue.
    I'm surprised Autozone cleared your codes. I heard they aren't supposed to do that. They really didn't do you any favors there, since you lost the information that the right mechanic with the right tools could have used to diagnose the car.
    A red warning light, like the exclamation mark and brake light, means something bad or dangerous is happening and you shouldn't drive the car--stop in a safe place and get a tow. Flashing yellow means a bad problem but you can keep driving, and get to a shop right away. Steady yellow means it needs your attention but you can take your time to schedule it.
  8. William Lowe
    Raleigh
    has anyone had these symptoms before if so what was the outcome?
  9. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Nothing that you’re describing is specific enough that anybody can give you any real info. Just get the codes read. If you want to do it yourself get Mini-VCI (and a laptop). If not just take it to place that can read all codes from Toyota hybrid.
    MTL_hihy likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    There are lots of possible outcomes from these lights, William. You'll never get it fixed without reading the codes and you won't know all the codes without a Prius capable code reader as has already been mentioned by @andrewclaus. Autozone is exceedingly unlikely to help you. The lights just tell you there's a problem they don't say what the problem is.
  11. bisco
    52,532
    start with a cheap digital multimeter and read your 12v to make sure that isn't the issue. do it after the car has been off for several hours, preferably overnight. you can check it at the jump point under the hood. if it's 12.5 or better, buy a mini vci and old laptop. research the threads here on how to use them to diagnose your car properly.
    diy on a prius takes some time and learning, even if your experienced with non hybrids.
    all the best!(y)
  12. ChapmanF
    18,716
    There are some codes in a Prius that can only be read with the proper scantool, but in a Gen 2, I believe VSC codes are among those you can get by counting the blinks of the light after jumpering TC to CG at the diagnostic connector. It blinks out 2-digit codes, which are sometimes less specific than the 5-character codes available to the scantool, but at least they will point in a direction, which is the necessary next step.
    -Chap
