Vehicle Proximity Notification System
Discussion in 'Gen 4 Prius Accessories and Modifications' started by randomwalk101, Mar 15, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    269
    texas
    Hi all,
    I just purchased my first 2016 Prius Three, not III because only 2010 Prius used uppercase Roman Numerals for model designation, today. I'm trying to locate that VPNS and disconnect the speaker...That buzz is driving me insane. There are threads of its location on previous generation (2010 and 2012). However, for the 2016, looks like Toyota had moved it. Any idea where it is located on the 4th gen? Thanks.
    image.jpg The VPNS sounds like it's in the driver side so I pulled the driver's wheel cover...nothing there.
    I think Toyota put the speaker inside the sensor now? This is the sensor I'm talking about. I can't find anything else that remotely looks like speaker other than the horn and this thing.
    49,490
    if you have the sensor out, there shouldn't be anymore sound?
    someone else posted a thread asking the same thing. i never saw a conclusion.
  3. randomwalk101
    532
    269
    texas
    Yeah. I already used techstream to turn off the driver/pass seat belt reminder, reverse beeping so the only useless noise left is this VPNS
    49,490
    i'm not following. you have the sensor out, is it still making noise?
  5. randomwalk101
    532
    269
    texas
    No noise with sensor out but it throws a code (Proximity sensor malfunctioned, see dealer) error message so you have to plug it back to clear the code....so noise is back. Lol
  6. randomwalk101
    532
    269
    texas
  7. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I can confirm that is just a plain o speaker
    Its located at
    I was able to pull the front off, and it looks like this
    I measured i'ts resistance, and it's 7.56 ohms, speaker territory.
    I wanna pull the blue back off, so that I can disconnect one of the speaker wires, and solder in a 3 watt 8 ohm resistor.
    But it won't come off, must be glued. I also cannot get the metal bracket off.
    I's like to put the resistor in the housing, and put everything back the way it looks originally, and retaining the connector and the housing weather profuseness (is that a word)
    dacoobob, thatoneraccoon and bisco like this.
  8. randomwalk101
    532
    269
    texas
    Thanks for the info ImJP
    Can we just cut up the speaker diaphragm so everything is still in place but it doesn't make noise?
  9. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I would think that you would have to pull the coil all the way out of the magnetic field made by the pm.
    Otherwise, it could get very noisy.
    merged
    Just confirmed that by plugging in a 10.0 ohm resistor directly in the connector with out the speaker, does not trigger a fault with the car.
    #9 I'mJp, Mar 17, 2016
  10. randomwalk101
    532
    269
    texas
    Awesome news. Btw I think you want a 10 ohm big resistor because the small resistor may get hot.
  11. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Did it! No more noise.
    I opened up the front part of the speaker, located the wires that go to the voices coil
    I then cut out a part of the plastic cone, and cut the wires at the cone, and pulled them out front.
    I verified that there was a open condition on the connector.
    The I soldered a 10.0 ohm 3 watt resistor.
    Then I glued the resistor down, because those wires are just too tiny.
    I tested with an ohm meter to make sure I had my 10 ohms.
    Put it all together, and no more generated noise !!!
    I can now hear my real engine / motor without the extra noise.
    alexatie and bisco like this.
  12. bisco
    49,490
    you guys are good! are these things required by law yet?
  13. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    The implementation deadline was announced for 2018, but it seems that the NHTSA has failed to prepare rules and specification by the November 2015 cut off.
    And those are rules requiring the manufacturers to put them in cars.
    I don't see any regulations about testing them.
  14. bisco
    49,490
    good to hear, thanks. no pun intended.
    m.wynn and RCO like this.
  15. krmcg
    2,592
    2,390
    Whittier, CA
    I honestly don't know what noise you are talking about. Have not heard it.
    Frederickdawg likes this.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Oh well, I suppose to each their own.
    When I first got my Prius, I had read about the VPNS here at Prius Chat, and even heard it from linked videos about the system. But to be honest, the noise was so unobtrusive that when I first had my Prius I was afraid mine wasn't working.
    I literally had to roll down the windows and listen very carefully going through a drive-thru just to make sure it was working.
    So anyway, I find it hard to fathom that the noise would bother anyone. I can understand where it might be of value out in the real world.
    Disconnecting it from my perspective seems like a bad idea.
    dacoobob, ftl, glennonrp and 2 others like this.
  17. ucla107
    ucla107 Member
    98
    107
    Four Touring
    Can one just shove a bunch of cotton balls or something in there to mute it? ;)
    kc5dlo and keymusic like this.
  18. randomwalk101
    532
    269
    texas
    You can also use ear plug. Lol
    ucla107 likes this.
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    If you do not pack the cotton properly, it's possible that the voice coil will become miss-aligned and drag on the pm. That could make it louder.
    If the back of the coil has a proper spider, miss-alignment is harder, it might work, but I couldn't open that side of the enclosure to be sure.
  20. ucla107
    ucla107 Member
    98
    107
    Four Touring
    How difficult was it to remove that assembly?
