Vent connection question
Discussion in 'Gen 4 Prius Technical Discussion' started by Rubdubb, Jul 3, 2019.
  1. Rubdubb
    Rubdubb Junior Member
    On the Gen 4 engine valve cover, passenger side of the engine, there is a hose barb on top of the valve cover. Can someone tell me where this connects? It has to just be vented back to the intake but I have no clue where.
    I'm doing a Gen 3 to Gen 4 engine swap and this isn't on the Gen 3. It's my last challenge to overcome.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    542
    Cow-lee-fornia
    2023 Prius
    Its probably the PCV. That usually goes back into the intake after the air filter box. Somewhere...
  3. Mendel Leisk
    42,037
  4. Rubdubb
    Not that one actually, the one I am referring to be doesn't seem to do anything with. If you watch from 16:00 on you'll see the small open barb sticking straight up on the left.
    I did watch his videos before going this route but I took an entire (easier) approach to the swap. By that I mean I pulled the engine with everything still on it except the water pump. So much easier to swap all the manifolds and components that way. I also routed a few things differently, for example I tapped the radiator pipe and installed a hose barb so it functions identical to stock rather than tying in to another line. But I never wouldn't have attempted this without those fantastic videos to assure me it would work.
    Ragingfit and Mendel Leisk like this.
  5. Mendel Leisk
    42,037
    Ok, I see, the vertical spigot at the passenger side end of the valve cover.
    Did you check if it actually is a pass-through hole there, in that spigot? I'm just wondering: could it be an attachment point for the ornamental cover?
    #5 Mendel Leisk, Jul 5, 2019
    Ragingfit and jerrymildred like this.
  6. Tande
    Tande Active Member
    550
    337
    Mich.
    Bingo! .....we have a winner! ......
  7. Mendel Leisk
    42,037
    Ah good, you checked yours?
  8. Tande
    Tande Active Member
    550
    337
    Mich.
    Yup!.......changing oil today & I thought....."Guess I'll See If I Can Figure/Out What These Guys Are Talking About"......
  9. Rubdubb
    Now see... This is funny... I successfully retrofit an engine to fit where it wasn't meant to but I need help figuring out that what looks like a hose connection is really just a cover mount... Awesome
    Thanks guys for the help and the laugh (at myself)
    Tande likes this.
