vent cover removal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by volcano, Feb 7, 2022.
  1. volcano
    volcano Junior Member
    ok i have an 2008 prius, the vent cover to the right of the steering wheel covering the drive shifter is cracked and want to buy a replacement part on ebay and replace it. problem is i dont know how to remove it. on the vent to the left of the steering wheel it looks like you can pry it off but the one to the right of the steering wheel the new part doesn't look like you can just pull it off. does anyone know how to do this?
  2. JC91006
    16,933
    8,643
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Remove the left vent.
    Remove the upper and lower steering cover trim pieces..
    Remove the center left vent. (most likely in several pieces)
    As mentioned, there are many videos. Look for Gen 2 prius MFD replacement videos. There's one out there that shows how to replace an MFD in about 10 minutes. It does a good job showing how to remove the vents and trim pieces.
    ydpplqbd likes this.
  4. volcano
    thank you I found a video. I was looking at videos for vent removal and did not find one that removed just the power button vent. I dont need to remove MFD screen though.
  5. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Might help everyone if you posted link to video
  6. ChapmanF
    18,950
    Because of the way pieces overlap, you have to start with the one on the left. Then you just work your way across.
  7. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    To access Prius dash center stack (MFD, speedo, radio etc) requires removal of vents and power button panel as in this video to remove speedo cluster.
    TMR-JWAP has a better video below.
    #7 alftoy, Feb 8, 2022
  8. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    As mentioned previously, this video provides a very good procedure for vent and trim removal for these pieces. You don't need to perform any extra steps after the desired vent is removed.
    ydpplqbd and alftoy like this.
  9. PriusCamper
    PriusCamper Senior Member
    13,401
    5,412
    Pacific Northwest, USA
    Just find a Prius at a wrecking yard and practice removing it there first. If you remove it without damaging it then buy it and take it home and swap it.
  10. JahT
    JahT Member
    145
    77
    The one to the right of the steering wheel is super fragile at the top, don't lift the bottom like he does in the video, try to pull vent straight out from top and bottom. All tabs are parallel with the floor and the vent insert is too, so pulling straight should avoid breakage at the top part.
