Vent mount for iPhone 5?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by alokeprasad, Nov 18, 2012.
  1. alokeprasad
    alokeprasad Member
    162
    Ohio
    What is the best way to mount an iPhone5, attached to the vent in the Prius Gen III? Most generic vent mounts work with vents that have horizontal slits. The Prius vent is different.
    I already have a case for my iPhone 5. But is a very snug case (Seidio Surface). The mount will need to have somewhat adjustable way to hold the (slightly larger) iPhone 5.
    Thanks.
  2. texnet
    texnet Junior Member
    30
    Houston
    Tetrax mounts strong and looks nice. The cleverly designed magnets do not mess with your iPhone compass. See the YouTube demos.
  3. Aquos
    Aquos Junior Member
    49
    17
    houston tx
    proclip has some iphone 5 mounts. I have had the iphone 4s mount and my dad has the galaxy s3 mount. I have a iphone 5 now so will be getting a mount sooon form proclip. they are great quality.
  4. alokeprasad
    alokeprasad Member
    162
    Ohio
    Does the Tetrax system require the use of their case?
    I am already using a different non-metallic case and holster.
  5. alokeprasad
    alokeprasad Member
    162
    Ohio
    Which specific mount from them is fitting the Prius vents?
    Could you post a URL or some pictures of the mount attached to the vent?
  6. alokeprasad
    alokeprasad Member
    162
    Ohio
    Thanks. Very helpful.
    Tetrax is good too, although I'm not sure how well the base holder will be attached to the vent by the two prongs (unless the prongs hook to the back of the vent fins).
  7. Frank Perkins
    Frank Perkins Member
    129
    64
    Fairfield, Connecticut
    Does anyone know if the left vent pops out? I'm thinking of running the USB cable through there.
  8. alokeprasad
    alokeprasad Member
    162
    Ohio
    ProClip is Expensive!!
    $80 for the base and the device holder ...
  9. RCDrifter
    RCDrifter Junior Member
    Southern California
  10. texnet
    30
    Houston
    I used the smallest disc and stuck it to the back of my case. It holds my iphone 5 firmly.
  11. texnet
    30
    Houston
    If you put the prongs over the vent an screw the top to the right the prongs clamp down as hard as you twist. It's metal and very sturdy. I use the Geo for $25 on Amazon. But I may try the Xway.
  12. ewxlt66
    ewxlt66 Active Member
    535
    184
    Dana Point, CA
    I know the Rokform cases have an adaptor to mount your phone anywhere, you may want to check them out.
  13. sbddude
    sbddude Junior Member
    62
    Bay Area, California
    2013 Prius v wagon
    I got a panavise mount that attaches to the area near the shifter...under $30 shipped. Much more steady than a vent mount.
  14. pkscout
    pkscout Junior Member
    Honolulu, HI
    I put together one using a large binder clip, a rubber band, and some gaffers tape. Works great on the center vents with my iPhone5 and looks fine when the phone is in it (a little cheesy when the phone is out). I got the instructions from LifeHacker. Total cost was about $7, and I ended up with enough clips and rubber bands to make like 20 of them.
  15. alokeprasad
    alokeprasad Member
    162
    Ohio
    Ingenious!! It is worth a try.
Loading...
