Vent Problem
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ninja72, Nov 2, 2024.
  1. Ninja72
    Ninja72 New Member
    2013 Prius v wagon
    Hi everybody, I am having an issue with a 2013 Prius V where the fan vents only blow through the centre vent even when the screen shows it is in defrost mode or on the feet. Ran a HVAC diagnostic and no trouble codes? Any help is appreciated thank you.
    51,937
    sounds ike the vent doors aren't moving. can you hear anything in the dash when changing modes?
  3. Ninja72
    Ninja72 New Member
    2013 Prius v wagon
    Yes I can hear the motor (or whatever controls the air direction) clicking.
    51,937
    there are lots of threads here on the problem. some vent doors can be accessed from the bottom of the dash i think, but most you have to tear the dash apart. i haven't done it myself
  5. bisco
    51,937
  6. Ninja72
    Ninja72 New Member
    2013 Prius v wagon
  7. bisco
    51,937
    all the best!
  8. snick
    snick Junior Member
    29
    Riverside, CA
    Hey Bisco,
    Slightly off-topic, but I'm a bit fuzzy about this rat-nibbled hole above the cabin air filter (Black air filter visible below the hole, with the cover unsnapped) . . . What is it about, or should it even be there at all? (And which damper is just above it?) 2012 Prius V
    #8 snick, Nov 16, 2024
  9. Air_Boss
    Air_Boss Senior Member
    4,198
    1,184
    New Yawk
    The rodent apparently preferred it not be there?
