1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Venting... bladder and pulse/glide
Discussion in 'Gen 2 Prius Main Forum' started by Prius904, Oct 3, 2013.
  1. Prius904
    Prius904 Junior Member
    48
    So I love when its time to fill up the tank and calculate the MPG I achieve... I did a favor and gave some rides to people and got 10 bucks cash towards my next fill up. For Fuelly to work accurately they recommend filling up the tank. I went in and paid for 10 bucks worth with the cash, filled it in the car, then used my card at the pump to fill up the rest of way. The gas wouldn't pump in, it kept auto shutting off every couple dimes worth. Even if I did it manually. Im guessing the bladder is at fault? I waited a couple minutes, started up the car, let the bars on gas gauge fill up (went to half tank) and tried a different pump. Still same issue, the gas pump acts as if the gas tank is full and wont let me pump gas. So I had to leave gas station and now my mpg calculations are going to be messed up :(
    I tried to minimize the damage of the calculations by pulsing/gliding to my college 2 miles down the road. This just increased my frusterations because pulse glide works in theory but is very impractical when you have to juggle the accelerator just right to achieve the ghosting mode. By the time im in ghost mode, I have lost 5 mph from the engine braking, and I have to speed up to avoid slowing traffic down to unacceptable levels in a busy area. Forget a on/off EV button, id rather have a on/off "ghost" button...
    Thanks for letting me vent.
  2. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    Cash and credit? Odd. Sounds like your tank was full. Overfilling after auto cut off is generally a bad idea.
  3. edthefox5
    edthefox5 Senior Member
    10,093
    4,780
    Clearwater, Florida
    Why didn't you just use your card to fill the tank up and pocket the $10?
    Must be new to a Prius as its pretty easy to "juggle" the accelerator. Just let off a little. But its not real easy to consistently hit "ghost mode" anyway.
    Damage to the calculations? Whats the sense of owning a car like this if it makes you crazy? Relax man.
    And the reason it gets silly at fill ups is you need to vent the gas tank a little before fueling to give the bladder time to relax. When under way there's a strong vacuum applied to the bladder and it is sucked tight to the liquid to prevent vapor from forming. When the car gets older the bladder gets stiffer and takes time for the bladder to "open" back up expand and relax. Kinda like you. If not vented your basically filling up a stiff plastic crumpled bag with lots of trapped air pockets. The pump detects this back pressure and will shut off. Much worse in winter as bag is even stiffer.
    I open the gas cap go inside and buy a drink and by the time I come out all good. Haven't had any pump drama in 5 years. Wife either.
    Hope this helps.
    kenoarto likes this.
  4. vskid3
    vskid3 Active Member
    773
    228
    I find it easier to let off all the way and then apply just enough to go into stealth (no arrows). Gives me a chance to "reset" my foot to zero and I can do it quick enough that I usually lose 1MPH at most. Just takes practice.
    You can still have accurate numbers, just add the miles and gallons from this fill to the next one and put it on Fuelly as one fill (or add the gallons and put in the odometer reading of the second fill if you do it that way). If you really messed it up, just put in the next fill and check the "missed a fill" box. It happens.
    P&G isn't the only way you can drive to get good mileage. Its generally the best way, but you have to adapt to the current traffic, terrain, and weather conditions. I love getting 60+MPG, but my number one goal is to arrive at my destination in a safe and timely manner, and to allow others to do the same.
  5. dorunron
    dorunron Senior Member
    3,318
    1,102
    Houston, TX
    If you are having difficulties with pulse and glide, you might want to take some time and study the tips, tricks, and theory thereof. Wayne Gerdes posted a very good article on it which is linked in my signature.
    Some find it easier to lift foot lightly, others like vskid find it is easier to remove foot then reapply with slight pressure. Try both methods to see what works the best for you. I too find it is easier for me to pulse and glide if I remove my foot completely then reapply slight pressure. I have also found that as you slow down during the glide, there are times where you will need to reduce pressure slightly to maintain your glide (no arrows on mfd). And yes, P&G is useful to help you attain very good mileage over the long haul, however it more important to drive safely without impeding traffic. Plan your route accordingly where you can P&G without hindering traffic (don't drive on the main drag). It takes a lot of time and practice to master it, but it can be done.
    Last thing, I agree with Edthefox concerning the bladder in the fuel tank. When you refuel, allow the system to breathe before you fill up. Loosen the cap 1/2 turn, then go inside and prepay. By the time you return, the system should have vented by then. Also fill up with the slowest flow rate on the nozzle. When it clicks off, hang up the pump. If you use a credit card instead of cash, try loosening the cap, then before you fill up pop the hood and check oil, fluids etc. That will give you the time needed to allow the system to vent. If you vent every time and fill at the slowest fill rate, your fill-ups will be more consistent. If you still have trouble, try a different pump.
    Don't let the machine (Prius) frustrate you, rather work with it and understand that it is a little different from the average car. In the end you will be happy, and you will be getting the best MPG out there imo.
    Best of luck to you!
  6. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    Yea this happened the first time I filled my Prius. It was on like 3 pips and at $1.40 it stopped pumping. I slowed down the flow of gasoline and I was able to successfully fill it. Don't always auto-lock the pump handle, as that could be too fast of a flow.
    On a side note, I wish my friends would pay me something whenever I give them a ride. Instead they're more like, "Trololol you have a Prius so you pay like $10 to fill it up," which my $34.32 I spent on a fill-up yesterday simply argues against...
  7. Prius904
    48
    Lol@Englishman
  8. Prius904
    48
    Wth, I wrote a whole lot more than just lol and it didn't post. Another thing to vent about grrr, lol. Well I basically said that I understand how to put the car into stealth mode. Sometimes it just refuses to go into it. I know how both methods are done, but sometimes it just flat out refuses to go stealth. And yes, I try it under 42 mph, with plenty of bars left on battery etc.. I even go barefooted to increase my sensitivity to pedal pressure (still sandals weather here in florida :p) It will go from green arrows to battery, straight to battery/engine to wheels. Thanks for all the feedback everyone, it was much appreciated. I also learned my lesson with filling up with gas. No more splitting the method of payments lol.
  9. dorunron
    3,318
    1,102
    Houston, TX
    Read and study the following, then you will understand why "sometimes it just flat out refuses..."
    http://techno-fandom.org/~hobbit/cars/five-stages.txt
    You can NOT get a true glide (stealth as you say) unless you are in S4 mode. I have seen what you are saying, and I have confirmed until you get into S4 mode, you will have the problem you are stating above. (not being able to go "stealth" all the time...)
Loading...
