very bad prius mileage
Discussion in 'Newbie Forum' started by MAYA17, Jan 21, 2009.
  1. richard schumacher
    7,682
    1,063
    United States
    Are you giving us the MPGs reported by the car's display? Or are you calculating them manually? In a Prius the display is accurate to within a few percent, but manual calculation for a single tank can be off by a factor of 2.
    You can safely go up to the cold pressure given on the side of the tire (44 PSI for the original tires). But you will notice a change in handling, so if you do this be alert.
    If you use grill blocking and don't have a scangauge for monitoring engine temperatures, don't forget to remove the blocking in the late spring. It would be bad to improve your MPGs now only to burn up the engine valves later.
  2. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    But your SUV probably costs you more than $12 to fill up ;) My Land Rover used to get 300 miles on a tank, but took 23 gallons (of premium) to fill. Thats 13mpg, using almost exactly 4 times more gas than my Prius. Its important to remember that higher mpg = lower cost = fewer pounds of CO2 = less air pollution = less money going to terrorists. Miles per tank is at most an inconvenience, and fairly trivial by comparison.
    You probably don't want to be doing much coasting/gliding when its cold. With the engine shut off, it will cool down very quickly particularly with no grill block. That means it will have to run longer the next time it starts to warm itself back up. In cold temps your best bet is to accelerate up to a reasonable speed fairly quickly, and then just hold it there and back off the pedal as much as you can and still maintain speed. Accelerating like a granny actually uses more gas. You don't want to floor it, the engine shouldn't really rev up much, but about 1/2 way down on the pedal is good. If you can watch the instantaneous mpg, it should be about half your speed while you are accelerating, 15mpg at 30mph, 20 mpg at 40mph etc. That should get you going quick enough to keep up with traffic, and get you up to speed using as little gas as possible. Driving 55 is a good idea though. On surface streets I find 35-45 to be a very efficient speed range. Slower than that and the engine will cycle on and off, causing the same cooling problem as above.
    I'd also be careful about trying to top off too much. The cold bladder will only stretch so much, and overfilling can lead to expensive damage to the vapor recovery system. Its also important to keep things in perspective. In the cold my Land Rover would drop to about 10mpg instead of 13mpg. While 3mpg doesn't sound like much, thats 23%. On a Prius, the same 23% is the difference between 47mpg and 36mpg, an 11mpg difference! Because the Prius uses much less fuel, these kind of changes are greatly exaggerated. There doesn't seem to be any one thing that works for everybody. The best thing seems to be to try lots of different suggestions, and see what works best for you.
    Good luck,
    Rob
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    When I don't carpool my commute is ~30 miles. Except for rare occasions I lose up to .5mpg on the current tank's average over the 1st half of the trip. First, it has to warm up. (Today I saw 190F coolant temp for the 1st time in ages.) Second, traffic lights disrupt steady driving. When it is warmer I can recover the day's loss and add a bit as there are fewer lights and smoother traffic. The home stretch is a tour of the company's parking lot on electricity and a green battery to my parking space.
    When I carpool the ride is ~15 miles. Losing the 2nd half of the trip is causing the tank's average to slide. Sometimes I can break even on the day but it is usually 1 or 2 tenths down.
    The worst fuel economy I ever got resulted from the car sitting with the AC on in the blazing sun which ran the traction battery down before running on the autocross course. I couldn't have asked for the car to be in worse condition for the competition. With all due respect I don't believe your SUV's FE is that high.
  4. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Are you referring to 'amount of gas purchased" each fillup rather than the "miles per gallon" ? Your Prius computer will be your best guide for general use (especially with the bladder fillup issues) and if your SUV has a "regular" gas tank manual calculations are OK (miles driven divided by gallons used).
    I have found it easier to work real hard to get the tank full one time and then regularly refill by half a tank used, which usually means 4 or 5 gallons and approx 220 miles driven. You also may want to research bladder concerrns and filling techniques on PC.
    If you've followed suggestions from other posters and are getting worse "miles per gallon" than an SUV please take the Prius to a dealer for evaluation, something is wrong.
    Good luck, I hope you can fix the problem so you can enjoy your Prius as much as I do.
  5. bac
    bac Active Member
    863
    52
    Pennsylvania
    Bullshit. :)
    ... Brad
  6. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    For most people on this board....
    Mileage = Miles Per Gallon (MPG)
    Range = Miles driven between fill-ups.
    I'm assuming when you say you get better "mileage" with your SUV, you mean longer range. (300 miles per tank vs 250 miles per tank).
    Increasing tire pressure is easy to do with quick, measurable results. Don't let the "service guys" fool you. Max tire pressure is the way to go. Many studies demonstrate that and under inflated tire is very dangerous. Do a google search and you will find recommendations saying that filling to max sidewall psi is safe.
  7. MAYA17
    MAYA17 New Member
    NEW JERSEY
    wow! thanks for everybody's comments an suggestions but okay-just to make myself clear, here's what's been happening---ive noticed that i've been paying less when filling up so i checked to see how many gallons it is and that's when consistently its been bouncing between 6 to about 7.5 or so... around october or so, after getting used to getting about 400-430 a tank(i'm assuming i filled up to 11.9 capacity) i looked at the screen and saw that i had about 280 miles and i figured i have about 120+ left, also at this time there were about 3 pips left..i decided to fill up-arrived at the gas station which was a mile away from my house when the 3 pips went to 2 to just 1 then lights shut off and the car died.. i still did not connect how many gallons i'm putting in the car vs. miles... anyway i googled a bit-learned about the bladder and noticed that during the fill ups i only get 6 or 7 ish--at this time i went from 400+ to 300+ to now 220----i think that comparing an 11.9 to a 7.5 fill up and the miles i get is too much of a difference even with the bladder issue....
    fyi i did go to dealer, explained everything and told me after all the tests that nothing's wrong with the car and that it needs to be broken in and the 220 that i'm getting is normal...
    btw, the mileage info i get from the screen.. each time i fill up-it resets ---yesterday after asking the gas attendant to top off slowly -i got about 8.5 and lost just the first pip today at 57 miles-----ive increased tp to 42 front 40 rear-----will try to get the strips this weekend.....
    im still learning all this and hope that i've explained it well in my own prius lingo :)
    p.s BRAD
    i get about 250 in my 98 pathfinder-no b.s. ;)
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Each and everytime continue to try and strech the bladder. Its only a problem if gasoline is forced into the tank when gasoline burps back out. It wii be easier in summer.
  9. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Thank you, very much, for asking questions, listening to the responses and attempting to incorporate some of the suggested changes. Too many people in your position have simply complained and whined and not tried to make adjustments.
    I'm certain you will continue to learn more about your Prius and how you'll be able to enjoy it even more by increasing its fuel economy.
    Even so, I think there may yet be some misunderstandings going on here.
    I live in a cold-weather climate, and I've experienced some pretty low mileage in very cold weather. I can't recall the lowest number of miles on a tank, but I can remember the lowest MPGs -- 35.0. I also remember the high MPGs -- 61.3. The lowest was in a very cold December; the highest in August. Temperature does make a big difference.
    Here are some questions I have for you:
    1. Do you keep a record of your gas purchases, the miles you've driven and any other information (price, temp, type of gas, station, etc.)?
    2. Do you record the information from the MFD?
    3. Have you kept records for your SUV?
    I understand you don't like the fact you are getting more miles per tank out of the SUV than from the Prius. Still, have you compared how much you spend per tank or per mile? Have you added up all the miles you've driven and divided by the gallons of gas you've purchased? The MFD display is much more reliable than a tank-by-tank record, but when you look at the ratio of total miles driven to total purchases of gasoline, the MPG you find should be fairly close to the MFD readings.
    If you need help getting this data to give you good readable information, there are several folks who have offered very usable spreadsheets that will report the results to you if you input as little information as what shows up on your purchase receipt and the MFD at the time you stop to fill up.
    Please let me know if there is anything else we (meaning other PC members) can offer.
  10. MAYA17
    MAYA17 New Member
    NEW JERSEY
    Okay-id like for someone to correct me if I'm wrong about this-i get my miles info based on the display-i.e. Last fill-up - had about 220 with 6.9 gallons in receipt-screen said 220 with 36.2 mpg- but if i divide my accumulated miles 220 by 6.9 it gives me roughly 28 mpg-is that right?? Or do I divide it by 11.9 even though I haven't filled to that capacity since summer? How and where is the 36.2 calculated from?
  11. snead_c
    667
    58
    Hendersonville
    You can not rely on the 6.9 gallons you pumped to have made a full tank of gas...6.9 is just what the "incredibly shrinking" gas tank bladder will allow into the tank on that particular occasion. On a colder day or with a faster running pump it may be less than 6.9 or on a real hot day and a slow pump 8.9 gallons ;)
    What the screen says is what MPG you got for the gas that actually went through the gas engine.
    When considering your MPG do NOT pay any attention to the gas pump reading. I think this bladder thing is causing you a lot of unnecessary distress.
  12. Gray Runner
    Gray Runner Junior Member
    24
    Framingham, Massachusetts
    In the winter snow I wouldn't go too high on the tire pressure
    As for the the MPG do not keep your accelerator in one position, let up and allow the car to get to more electric then gas
  13. BigDeal
    BigDeal Junior Member
    95
    Arizona
    2021 Prius
    I would have to agree that I don't think there is anything wrong with the OP's car other than cold weather. I'm getting much lower gas mileage now with the cold weather too. Yesterday I took a trip to Bismarck and my mileage was about 35mpg, :( when in warmer weather I average mid 40 mpgs on the same trip. Yesterday the temp was about -5F. I do have my grill blocked too.
  14. a priori
    3,083
    408
    23
    Chicagoland (West)
    Alright. I'll give a go to your questions, but I'm certain you'll find more complete responses coming later.
    Where do you get the miles from? Two (well, three really) options. The first is the odometer (you also could use a trip odometer to give you miles to the tenth of a mile), and the second is the MFD. The miles reported on the MFD will be slightly more correct, fill-to-fill, because it zeros out. For the long run, I suggest you write down the odometer mileage as well.
    How do you determine MPGs? Use all of the information available to keep mileage in two forms. The first is what is reported on the MFD. The second is what you calculate using the amount of gasoline you purchase.
    For the first method (MFD info) you should track the miles driven and the reported MPG. If the screen (MFD) reports, for example, 220 miles and 36.2 MPG, write it down. Also, write down the calculated gasoline used. This number is calculated by dividing the miles (220) by the MPG (36.2) to give you 6.08 or 6.1 gallons. If the next fill-up comes after 240 miles and shows 35.4 MPG, then you put in that information, as well as the calculated gallons of gasoline as 6.78 gallons (or 6.8). This lets you figure out your combined mileage for those two tanks: 460 miles (220 + 240) divided by 12.86 gallons (6.08 + 6.78) for mileage of 35.8 MPG. If the next tank comes in at 180 miles at 28.4MPG (6.34 gallons), then the combined mileage goes to 640 miles/19.2 gallons or 33.3 MPG.
    For the second method (purchased gallons) you should track miles (odometer reading) and gallons purchased. Your first purchase was was at odometer mile 5,220 (starting at 5,000, for example) and included 6.9 gallons (31.9 MPG - I don't know how you got to 28). The second purchase was at 5,460 and included 6.0 gallons, for which you calculate mileage of 240 miles/6.0 gallons or 40.0 MPG. The third purchase was at 5,640 for 7.3 gallons (you were getting nervous by now!) for mileage of 180 miles/7.3 gallons or 24.7 MPG.
    You'll notice significant differences between the MFD and your gas purchases. This is very common (expected) during the winter when you have a non-expanding bladder. Don't worry about it.
    If you look at the overall gas use by the second method, you'll find that you traveled 640 total miles and purchased 20.2 gallons. This calculates to 31.7 MPG. It isn't the same as the MFD, but then it covers only three tanks (full?). The 31.7 makes much more sense than the variation from 24.7 to 40.0 MPGs. You'll notice the MFD doesn't typically have such wide fluctuation, unless you are driving under different conditions.
    You had another question: How and from where does the MFD mileage (MPGs) derive? I don't know the particulars, but a computer uses the same miles as shown on the odometer and divides that by the amount of gasoline calculated to have entered into the ICE's cylinders on a near-instantaneous method. Believe me: it is much, much more accurate than the assumption you are able to fill your tank to the exact same place, tank after tank!
    I'm sorry if this is too convoluted, but I hope it helps you better understand the actual gas usage of your car. If you track this over the long haul, you will notice the difference between gas pump volume vs. calculated gallons used will shrink to a consistent variation (long term) of somewhere between 1 MPG and 1.5 MPG.
    Keep up with the questions!
  15. shkaroo
    shkaroo New Member
    Chicago NW suburbs
    maya The screen that shows your milage in 5 minute stages and that bar that runs up the right side. Where is it when you are driving? I like to watch the screen that shows where the power is going and then toggle to the other to see how I'm doing. We took a 2500 mile trip from chicago to virginia beach 2 weeks after getting the car and the total trip was milage was 54mpg. I hardly knew how to turn on the wipers it was so new to me but watching that screen I think made the difference.
  16. MAYA17
    MAYA17 New Member
    NEW JERSEY
    thank u again for all the comments and suggestions-- though I understand the mileage explanation-still wish that my mpg is what others get-but I've always been grateful that its not 13 mpg like the suv---anyway just wanted to report that the slow top off worked!!!! I have 3 pips left with about 260+miles at 36.8 mpg wohoo!!!! Yes I watched how I drive-watched the screen while I was driving being conscious of the arrows and all that---im just happy that it seems like I'm gonna make it over 300+for the first time in months!! Maybe after I get the grille block and the other stuff ill get better mileage...thanks guys!!!!!!:)
  17. JimN
    7,028
    1,117
    South Jersey
    Maya, it's called the "Guess Gauge" for good reason and this is your initiation. Generally I find the MFD is optimistic and it's FE calculation within a couple percent of my numbers. However, at times there can be a 20% difference which is most likely during the winter but can happen any time. If you experience a very low FE tank next to a very high FE tank then you just experienced a fueling issue and it averaged out. So, don't get too excited on 1 tank.
    I know how it feels to come here and read about "everyone" getting 50+ when you're stuck in the mid or high 40's. Improve what you can, accept what you can't, and learn to discern the difference. We can't change the climate or the terrain. We can experiment with routes and speeds. We can make small and inexpensive adjustments to the car that produce "huge" improvements. In my case the biggest adjustment needed to be done to the "nut behind the wheel". The Prius will teach you how to drive more efficiently. I listen to those who do better and adapt what I can. I may not be able to do as well as John, or Hobbit, or Evan but that's not the point. The competition is within. Now that I have x mpg what can I do to get x.2? I am sure that with your attitute and enough experience you'll get the lifetime average up to 50.
    BTW, do you buy one brand of gas regularly?
  18. MAYA17
    MAYA17 New Member
    NEW JERSEY
  19. MAYA17
    MAYA17 New Member
    NEW JERSEY
    Sorry for the double posts! Using my blackberry and must've double clicked but forgot to address two things--when I did the slow top-off it was only an extra gallon so from 7.5 to about 8.5-also I generally bounce between exxon and hess--and even though it seems like its getting better- I'm not going to expect heaven-just a small change for the better is great..
  20. JimN
    7,028
    1,117
    South Jersey
    Maya, "Patience, Grasshopper." I filled up tonight at 1 pip and 394 miles seeing 52.2 on the MFD & expecting 41. The car took 7.475 gallons at automatic shutoff for a calculated 52.7 on Sunoco. The previous tank was 48.8mpg and lifetime is 52.9. If I can hold 50 through the freezing winter I'll be happy.
    I keep the climate control off for the 1st 5 minutes unless I can't see. Turn off the cc at a stop if the ICE (internal combustion engine) runs. Temp set at 72 and fan speed low on manual gets the cabin comfortable.
    Different gas formulas and different pump sensitivity also have an effect. You just have to discover what works best for you.
    Keep us posted.
