Very cold weather driving observations.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Jan 24, 2026.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    Was -10f when I left yesterday morning. Never driven it in such cold temperatures.
    Started right up, although for the first couple minutes letting it warm up, it was vibrating terribly. Not a vibration from misfiring, it's like the normal engine vibration was more easily transmitted through the steering column. I can't explain what caused this. Have you ever used a gas weed trimmer? It felt similar to that.
    The ride was...quite rough. I imagine the viscosity of the hydraulic fluid in the struts/shocks was much thicker than normal. So you didn't have much dampening, at all.
    I noticed the regenerative braking system was not working on the way to my destination 20 minutes away, stopping distance was increased roughly 30% as a result. I know it was not operating because not only was the distance increased, the regen braking system emits a whine when it kicks on, which I didn't hear. It did work on the way back.
    Now here is where it gets interesting.
    When I got onto the highway to merge, and floored it, the engine would rev up, then back down, in sort of a loop. I'm not sure if the gen2 has a rev limiter? If it does, I've floored it before during normal driving and never noticed it.
    The battery gauge acted normal. When the engine was "looping", it wasn't low or anything.
    No extra lights came on. I've started vehicles before when it was this cold and usually it throws up an error or two.
  2. Prius92
    595
    122
    Iowa
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    The engineers decide how much power can go in or out of the HV battery and program limits into the ecu. When everything is crazy cold, they likely have very conservative limits that reduce powertrain performance but also won't damage the battery.
    Brian1954 likes this.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,034
    942
    Southern California
    I wonder if the rubber in the engine mounts and other suspension components becomes so much stiffer that there is a noticeable increase in vibration transmission.
  5. Tideland Prius
    16,675
    I’ve never driven a Gen 2 in those temps but I have the Gen 3. Only once did I have a really rough idle but that was after it sat outside in the cold (-30°C) over Christmas holidays.
    As for the suspension, in theory, it would be a bit rougher due to the bushings getting cold but I can’t remember anything notable in my Gen 3. I probably wrote about my experiences somewhere on the site when the car was new. Perhaps, it’s a sign that your car may need new bushings soon?
