Very Loud Engine Sound
Discussion in 'Gen 2 Prius Main Forum' started by Metrolens, Apr 18, 2019.
  1. Metrolens
    Metrolens Member
    215
    Hi all, I started my 2005 Gen 2 today, and when the ICE kicked in, out of the blue there was a horrible sound - like a car without a muffler, or a car modded to sound extremely loud. Actually some would probably say this is a wonderful sound - like a muscle car on steroids. But I digress.
    The sound originates from under the hood, driver's side near the ICE, not from the muffler in the rear.
    My OBDII + Torque showed no error codes. There is no Main't Required light.
    Yesterday the car was driving perfectly, and there was no pothole or anything which would have obviously jarred something loose. My layman's guess is a hose or something popped off, and now we are hearing the raw sound of the ICE?
    Thoughts? Obviously I have to take this in to be repaired, but first and foremost, is the car DANGEROUS to drive even a few miles to the mechanic?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    someone cut out your catalytic converter? Take a look under the car and see if the exhaust pipe is missing between the engine and muffler. Seems to be happening a lot.
    Or donut gasket blew out between exhaust manifold and pipe
    Data Daedalus likes this.
  3. Metrolens
    Metrolens Member
    215
    The car has been parked on the street in LA; I imagine cutting out the cat converter would make a bunch of noise and/or take some time, and require getting underneath the car. Interesting theory, but seems unlikely?
    If it's the donut gasket, is that dangerous to drive, or just super loud?
  4. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Really....you should read some of the recent posts here about this exact scenario...come and gone in just 2 minutes.....manymany posts about it
    As for the donut gasket, no danger, just loud and a bit of carbon monoxide.
    Assuming it's the exhaust and not something else.
    Maybe the O2 sensor or AF ratio sensor fell off the exhaust?
  5. Metrolens
    Metrolens Member
    215
    What would it look like if the cat converter had been stolen?
  6. bisco
    52,823
    a big empty space between the exhaust pipe and the muffler. LA and london are hotspots. they steal them for the precious metals.
  7. Metrolens
    Metrolens Member
    215
    Would there be wires cut, hanging down?
  8. bisco
    52,823
    no, just the gap in the exhaust. they use a cutter wheel, make two cuts in the 2" pipe and walk away with it.
    jforpics, see the 'stolen catalytic converter' threads here.
    if you can't see under there, drive it to a local mech or muffler shop
  9. Metrolens
    Metrolens Member
    215
    In this youtube video, a news report from yesterday, at 45 seconds they show the undercarriage of a Gen2. You can see the wires to the right. Is the car in this video missing its cat converter? Is the space where the cat converter should be the shiny corrugated metal section at 45 secs? I'm not sure what the undercarraige would look like with/without the converter. Thx.
  10. Metrolens
    Metrolens Member
    215
    (Actually you don't even need to watch the video - the YouTube still image shows exactly what I describe at the 45 second mark.)
  11. Leadfoot J. McCoalroller
    8,283
    7,794
    Pennsylvania
    2018 Prius c
    Depending on where the cuts are made they will also be taking one of your oxygen sensors. Doing so would necessitate cutting the wires connecting the sensor to the engine ECU. This is common and likely in Prius converter thefts.
    #11 Leadfoot J. McCoalroller, Apr 18, 2019
  12. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    You’ve just had your catalytic converter stolen. The Prius 2 is such an over engineered vehicle, no other mechanical failure fits this profile.
    You’ll need a new cat installed, and will need to see about getting protection installed on it too.....or they’ll be back for it.
    Happened to me in London November 2018.
    Over 1,000 Prii have been attacked in London alone.
    The local law enforcement consider the matter a victimless crime, so have allowed the thieves to run riot in London over the last 10 months, much to the dismay of us Prius owners there.
    Hope you can get your Prius fixed.
    iPhone 6s +
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Really bad news is its a carb state so they will not accept an aftermarket cheapo cat. Must be the factory cat. $$$$$$$.
    Which is why they steal it.
  14. oil_burner
    oil_burner Active Member
    249
    126
    Just about every muffler repair shop offers free inspection. Drive it there they will tell you what's wrong in 15 minutes
  15. Tharbeard
    Tharbeard New Member
    Portland, OR
    So, I got in my car and it sounds like I'm surrounded by motorcycles. I'm assuming I'm in the same boat and the OP: either stolen catalytic converter or a blown donut gasket?
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    stolen cat. sucks. cant let the car out of your sight. Just look under the car if you see dangling wires.....
    Go on youtube and search
    Prius Stolen
    Lots of info about it.
  17. gui
    gui New Member
    I
    there is a good chance that it's a stolen cat
  18. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    That was four years ago.
  19. ChapmanF
    19,008
    Ok, there's a good chance it was a stolen cat.
