Very low mileage. To service or not to service?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by schja01, Jul 4, 2020.
  1. schja01
    schja01 One of very few in Chicagoland
    1,748
    1,164
    Chicagoland
    2018 Prius
    My Prime is almost 2 years old with 4K miles. That's right 4K not 40K.
    Of that 4K, 3.5K are EV miles. Those 500 miles were to just burn fuel so I can add some to keep it from going stale. My dealer says I should bring it in for the final Toyota Care but with the COVID-19 and all and the fact I am in a higher risk category due to my age I am hesitant. My dealer said I am allowed to defer things by 4 months as the COVID accommodation but who's to say things will be any better then.
    My primary concern is that if I neglect the annual maintenance am I in danger of voiding the warranty if something should happen down the road?
    For those who care, I got the car primarily for the technology geewiz factor, not that I actually need the second car.
    Any insight appreciated.
    Liz Waters likes this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Yes. Possible.
    The recommendation likely is an oil change once a year regardless of mileage.
    If so, you are about 10 months PAST DUE already.
    And as for the virus thing.......you should be able to take it in and have little or no close human contact in the process.
    It is the close human contact that is the problem.
    Just the fact that you are going out of your house is NOT a problem.
    mr88cet likes this.
  3. Mendel Leisk
    38,763
    Have you got a charger for the 12 volt battery? Look for one that's "smart", ie: assesses the battery, goes through a charging regimen, rated 5 amps max, and can be left on indefinitely. That's assuming you're parked securely, have a 120 volt outlet.
    A second car, clocking 4K miles iin 2 years? Maybe sell it?
    #3 Mendel Leisk, Jul 4, 2020
  4. AzusaPrius
    AzusaPrius Senior Member
    1,900
    826
    Get the oil change, the inside of engine has metal shavings and the first oil is the worst.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    You sure about that:whistle:?
    We like data and credible sources;).
    I changed the oil in our 2019 Prime at 4K miles and there were no metallic parts found:).
    Same with the trans fluid, as I did both at the same time(y).
  6. schja01
    1,748
    1,164
    Chicagoland
    2018 Prius
    As the OP I neglected to say that I did have the first Toyota care service performed at 12 months so I’m good on that. It’s the current one the second service that I was concerned about strictly because of the Covid thing.
    I have a battery maintainer that I leave on so the battery is kept charged at all times.
  7. sam spade 2
    7,035
    2,790
    2017 Prius c
    To repeat:
    The "Covid thing" should NOT prevent you from servicing your car......IF the shop is open.
    YOu should be able to do that with little or NO human contact.
  8. bisco
    49,542
    i would take a pass. there's nothing more important than your life. and nothing important, even if you follow the time schedule instead of miles.
  9. sam spade 2
    7,035
    2,790
    2017 Prius c
    And what if this continues to be rampant for another 6 months.....or a year.....or two years ??
    And what about other dangers to your life ?
    Guns are proliferating like wild fire.
    Are you going to stay home because you might get hit with a stray bullet if you venture out ??
    If you are CAREFUL and follow what the health car professionals are saying, you are about as likely to be injured in a car crash.
    Common sense is not so common after all, it seems.
  10. jerrymildred
    jerrymildred Senior Member
    11,518
    14,121
    Tampa, FL
    I know I sure don't want to get this virus. But I know I almost certainly will, as will nearly everyone on the planet. Just like any kind of flu. This unreasoning fear that has paralyzed us is just amazing and I think it's the result of years of having it beat into our brains that the main goal in life is to be safe and happy.
    You're in way greater danger of getting in an accident (or shot, if you're actually in Chicago) than getting COVID by getting your car serviced. If you're concerned, wipe down the surfaces with disinfectant before you drive home in the unlikely case that the tech was working sick, the sickness was COVID, and he sneezed or coughed while in the car. AFAIK, I have never gotten a cold or anything else from having a car serviced. But wiping it down might be smart, COVID or no COVID. And a lot of dealer service departments will come get your car and bring it back to you, so you don't even have to walk into their nasty building that's teeming with viruses.
    Even staying inside has risk to it. Most heart attacks happen in the morning, so just getting out of bed has some risk to it.
  11. bisco
    49,542
    with age and underlying conditions, my primary care advises to shelter in place, not go out to get a car serviced that has nothing wrong with it.
    Raytheeagle likes this.
  12. schja01
    1,748
    1,164
    Chicagoland
    2018 Prius
    Thanks group. I will find out what options are available to me when I talk to my service dept Monday by phone.
    I do live in Chicagoland although not in the city proper. No shootings in the neighborhood but I was a victim of a battery (long story) while waiting in line for my service department to open. Fortunately the gentleman in line behind me was an off duty Chicago police officer who witnessed the whole thing and came to my assistance (gun drawn) and defused the situation in short order. No excessive force was used. But I digress.
  13. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Nice new avatar;).
    Been working on those while sheltering:whistle:?
    If so, a good hobby (y).
  14. bisco
    49,542
    drone was getting boring. this thing is a challenge, but it doesn't handle any wind. one gust, and it's off to europe. i try to keep it low and in between the trees. definitely takes skill.
    jerrymildred and Raytheeagle like this.
  15. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    We've had my sons drone out a bit recently:).
    But it is a small, inexpensive one and is similar in winds:eek:.
    Where we live in the Bay Area, those winds are somewhat constant:cool:.
    But it is a good time when we have the opportunity(y).
  16. Salamander_King
    Salamander_King Senior Member
    10,975
    8,870
    New England
    If you did oil and lube at 12mo and now due for the second oil and lube and if you are afraid of going to the dealer due to virus concern, why not DIY at the comfort of your own home? You can order oil and filter online, or ask someone to pick them up locally. If you don't have a jack, you can improvise a ramp with a piece of 2x8. I would not worry about other things on a 2year service which is basically tire rotation and visual inspections.
    #16 Salamander_King, Jul 4, 2020
    jerrymildred likes this.
  17. sam spade 2
    7,035
    2,790
    2017 Prius c
    Based on wrenching on all kinds of vehicles and machines for about 50 years:
    There is nothing "comfortable" about changing your own oil. It usually ends up being a big MESS.
    AND....improvising any kind of ramp with wood IS NOT A SAFE THING TO DO.
    Overall bad advice for most people.
  18. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    I was able to take ours in with indeed very little direct contact, but I bet you could arrange to hand the car over outside the dealership, then hang out outdoors.
    Oils do gradually degrade some, via oxidation, just sitting around. It is pretty gradual for the most part , though.
  19. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Ask your service advisor what protocols they have in place.
    Let them know you are high risk and concerned.
    My Toyota dealership was advertising that they were taking very special precautions and having
    least amount of contact with the interior of car, low or even no contact with customer,
    and where also disinfecting interior of car a couple of months ago.
    I dont see that advertising/notice anymore for some reason tho.
    Raytheeagle and jerrymildred like this.
  20. jerrymildred
    11,518
    14,121
    Tampa, FL
    Same here. The notices are no longer on the website. (But they have been mailing me coupons for $10 oil changes with synthetic & filter. )
    dig4dirt likes this.
