Very low MPG across two states (38-40 MPG)
Discussion in 'Gen 3 Prius Fuel Economy' started by KyleSTL, Feb 3, 2014.
  1. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    I suppose there are many ways to look at this issue. In the end, it's a no-brainer, the faster you drive the more gas you're going to use. Period. Can't fight physics/chemistry. Just the way it is.
    #41 Oskar, Oct 10, 2014
  2. KyleSTL
    KyleSTL Junior Member
    79
    I never got around to doing the controlled test Bob suggested, but I have gone on several more roadtrips, most of which at slightly lower speeds (some by choice, some by contruction). I still have never had a single fillup where the HSI read more than 50 MPG (it is recorded and reset at every fillup in my log book). I have also never been close to a 500 mile tank. We have owned this car since brand new in Jan [edit: 2014]
    and now have over 22K miles.
    The trip my wife, son and I went on over the weekend resulted in the worst mileage I've ever seen (a result of a desire to set cruise control at 77 MPH when possible, and fairly strong headwinds and crosswinds). There were many stretches with construction zones of 55 and 45 MPH which brought my average speed down to 58 MPH and even so, between St Louis, MO and Gilman, IL (SSW of Chicago) our mileage was a paltry 33.1 MPG (displayed).
    Caveat: We have a Yakima rails (48" crossbars, Q towers) and a wind deflector installed on the car. For this trip there was nothing up on the rack.
    I feel like Jeremy Clarkson with such low mileage. Our usual fillup mileage is 43-48 MPG displayed (41-47 calculated).
    #42 KyleSTL, Oct 5, 2015
  3. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    That's pretty low I do not see what is going on. Usually I do not see huge MPG hit with roof rack until I am carrying something up top. We do not get 500 mi/tank unless we are doing 100% highway in which case our record is about 485 miles ...we were able to do that this summer a couple times.
  4. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    Bingo! Now you tell us!
    I've never seen the HSI "CONS." number near 50 for a whole tank, either. It practically always lands in the 56-64 range, winter or summer, local or long-distance travel. (Actual mpg is 95% of what it claims.)
  5. KyleSTL
    79
    I think you misread. The highest CONS on a tank we have ever had is 49.7 MPG. Do you really think a couple of rails and a deflector can account for such a monumental hit to our MPG? Most of my driving is around St Louis, my commute is about 15 miles each way, mostly surface streets with very little stop and go. City, highway, mixed - we have never acheived the rated MPG for a single tank in 22600 miles of driving. I do practice pulse and glide and warp stealth and have dabbled in super highway mode. I have watched all the videos, and fully understand the science and execution of the techniques of hybrid driving.
  6. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    15 miles commute should get you about 45-50 MPG. Something is wrong. We averaged 47 MPG when my wife was commuting 12 miles to work (24 mi round trip). We are lower MPG now with all local driving.
    Have Toyota take a look? Rent or get a loaner Prius to test another vehicle on your commute? Check to make sure actual MPG (by hand calc of gallons pumped) is similar to display (display usually over-optimistic).
  7. KyleSTL
    79
    I have kept a log of fillups since the car drove off the lot, the hand calc is consistently 2 MPG lower than the CONS displays.
  8. vskid3
    vskid3 Active Member
    773
    228
    Have you ever driven it without the rails? If not, I would remove them for a few tanks (if you won't be needing them) and see what happens. If its still/has been low without them, it might be worth it to test drive another from the dealer on a loop and drive your car on the same loop to see if there's a significant difference.
    kenoarto likes this.
  9. KyleSTL
    79
    We drove the car between Jan 2014 and July 2014 without rails or rack. Since then the mileage has been slightly down (~2-3 MPG). We haven't taken it off in quite a while, since the Q mounts are not the easiest to remove and reinstall.
  10. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    I do not have the wind deflector, but my bars by themselves do not seem to hurt MPG too much. My rack comes off easily so I do not use them often. Keep in mind the wind deflector could be adding quite a lot of drag and frontal surface area. I definitely see -10MPG with my box on top, and your wind deflector could conceivably add as much surface area as my box.
    #50 wjtracy, Oct 6, 2015
  11. KyleSTL
    79
    Maybe I'll take off the deflector and see if the wind noise is bearable. Last time I tried it on my old car (Volvo V50) it just about drove me insane.
  12. bwilson4web
    16,201
    First post photos, front, side, and top. Let us see what you have.
  13. KyleSTL
    79
    Pictures of the Prius with rack and deflector:
  14. bwilson4web
    16,201
    You need to do a tuff test. Use blue masking tape that pulls off without leaving a sticky spot. Use gift wrapping tape 3 inch, long, 1/4 inch, along the top about every foot or so, at least a foot from side all the way to rear spoiler. Include the rear glass. Then drive at least 50 mph and have a friend make some MPEGs or rig a camera to take photos.
    You will see a huge amount of energy wasting, reverse flow turbulence that is drag. Without the air.dam and rack, the air would follow the body taper and actually provide a little push, reducing the drag.
    I understand the desire for more cargo. First choice is a trailer hitch and platform. Stacked no higher than rear spoiler, drag free. As for roof racks, the ones that go front to back are the next best and alleviate the need for an air dam when not loaded.
    Good luck!
    #54 bwilson4web, Oct 7, 2015
    fuzzy1 likes this.
  15. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    No, I didn't misread or misunderstand at all. I was trying to make the point that you're getting lousy mileage for a Prius. Do Bob's steady-speed test without the aerodynamic impediments, report the results, and then we'll know whether you actually have a car problem, or only unreasonable expectations.
    That deflector looks to me like might be angled too high. You'd have to test to find the optimum angle.
  16. bwilson4web
    16,201
    Many years ago, I tested vortex generators on our 2003 Prius to see if they might improve highway mileage:
    Before vortex generators a lot of evidence of flow reversal.
    With the vortex generators:
    Now the flow is attached with some separation on the passenger side but not as severe. But I did not stop here.
    I ran my standard, high-speed benchmarks and could not find evidence of a significant MPG improvement. Not enough to justify the maintenance hassle of dealing with car wash systems.
    A 'blown' plexiglass cover could be formed that would keep the flow attacked down to the spoiler. But then we got a 2010 Prius and it is our cross-country car. The 2003 Prius is used for city driving.
  17. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    We took a trip fro Minnesota to Yellowstone this summer.
    South Dakota recently changed it's freeway limit to 80MPH. Wyoming also has an 80MPH limit. Add that limit to any headwind and *any* car/truck will have difficulty getting decent mileage. Needless to say, I did notice a drop while going through those states.
    The funny thing is...hardly *anyone* was going 80...much less going over. I'd estimate that, on average, trucks were going in the low 70s and most cars were going 75 or so at the most. I frankly didn't expect that at all.
  18. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    In other words, the same speeds they go on Interstates with 65 or 70 mph limits, proving most people ignore the limit signs, whatever they say.
  19. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Luv Yellowstone...last time we went we had a room in Old Faithful lodge directly with Old Faithful out the window.
  20. KyleSTL
    79
    I am going to adjust the brackets so that the angle of the deflector closely resembles the angle of the windshield. Hopefully that reduces some drag without causing excessive wind noise. I'll do the controlled test at some point with or without the deflector and report the results.
