Very low MPG across two states (38-40 MPG)
Discussion in 'Gen 3 Prius Fuel Economy' started by KyleSTL, Feb 3, 2014.
  1. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    The roof rack will definitely impact the mileage, as will the high speeds and cross/head winds. Still, I think your numbers are awfully awfully low.
  2. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    In my experience, people almost always ignore speed limits to go faster...not slower. That is why I mentioned it. It was very odd to see nearly everyone going slower than the 80MPH freeway limit.
  3. Mendel Leisk
    41,500
    Noticed the same thing here, in zones with limits recently raised to 110~120 kms: a lot of drivers evidently saying "screw this, I'm going a bit slower, thank you".
  4. bwilson4web
    16,224
    And I remember my wife driving a 400 ci, Plymouth Fury wagon trying to use the 'mph' speed for the posted 'kph' signs . . . certainly kept me awake!
  5. CR94
    CR94 Senior Member
    2,696
    1,174
    Northwestern S.C.
    But ignoring the signs means, by definition, just driving the speed one darn well pleases, with no regard to whether the signs show a higher or lower number. "Ignoring" means paying no heed at all to the signs, one way or the other. That's what I think you saw.
    Anthony L Malovrh likes this.
  6. farmecologist
    1,958
    1,799
    Southern MN
    Hmm...I also think some people have a hard time 'ignoring' the need to post a useless response...sigh...
  7. KyleSTL
    KyleSTL Junior Member
    79
    I have not had an opportunity to do the test, but in the meantime here is my all-time graph of mileage.
    Total miles driven since purchase: 23176 miles
    Total gallons filled up: 553.5 gallons (US)
    Lifetime MPG (calc): 41.9 MPG
    A question to other Prius owners with racks (especially Yakima Q-mount, which is likely the most common) -
    Is the drop in MPG usually about 2-3 MPG after adding the rack?
  8. bwilson4web
    16,224
    Comparing the equivalent time periods:
    • before rack: 5 below 45 MPG 29%, 12 above 45 MPGm 71%
    • after rack: 6 below 45 MPG 54%, 5 above 45 MPG 46%
  9. bkborgman
    bkborgman Junior Member
    Interestingly, one time I drove through Missouri I too had very low gas mileage:
    Code:
    Date         Miles     Gal        MPG    MP Tank
    6/26/2015    33638    4.191    52.73    627.51    GA -> NE
    6/27/2015    34091    9.092    49.82    592.91
    6/28/2015    34425    9.464    35.29    419.97    Casey's Store #2888 in Higginsville, MO
    6/28/2015    34759    8.087    41.30    491.48
    7/03/2015    35110    7.640    45.94    546.71    NE -> GA
    7/06/2015    35360    5.328    46.92    558.37
    7/07/2015    35781    9.548    44.09    524.71
    7/07/2015    36168    8.412    46.01    547.47
    My speed was more-or-less the same in both directions (mostly interstate, so about 75 mph). Throwing out this one outlier, I average 46.3 MPG under regular driving conditions and 46.7 on the highway. Thus I suspect the pump in Higgensville cheated me... in fact, if they dispensed 0.8 gal for every 1 gal I was charged, that would take my MPG back up to 41.
    Sure, it could be weather or the hills or something, but this is the only anomalous reading in my MPG record.
  10. bwilson4web
    16,224
    "Casey's Store #2888 in Higginsville, MO"
    • Your route was along the Ozark plateau with numerous altitude changes
    • On that day, the local airport reported gusty, head-quartering winds
    • The temperatures were in the mid-80s so the AC was turned on
      • More so because you were driving into the sun, making cabin hotter
    You were actually traveling faster than 75 mph:
    kenoarto likes this.
  11. KyleSTL
    79
    I am currently working on what will be my first tank with an average over 50 MPG (computer). About two more days left, and it will be my first range over 500 miles. Only took 26 months of ownership and almost 31000 miles to hit that milestone.
  12. Steve Lee
    Steve Lee Member
    135
    88
    Houston
    I drove prius from Houston Texas to Los Angeles, I averaged 43 MPG, two children, two children car seats, two adults(driver & passenger), snacks, and luggage. What I noticed big negative fuel impact was driving through the hills and average 78 MPH. I would go insane if I had to drive 55-65 MPH, I have patience but no patience to drive 65 MPH for long period of time..
  13. fuzzy1
    10,474
    Not bad :) It took me 11 years and 140,000 miles to get my first Subaru significantly above its EPA rating. That was a surprise because the prior Accord was easily beating its EPA Highway from the very first tank.
    Though I should admit that the effort lagged until gasoline jumped to $4.50 / gallon, pushing me to try much harder.
  14. KyleSTL
    79
    Thanks, but for the number of people around here that do it frequently and relatively easily, I feel like my disciplined driving should have been rewarded years ago. I still need to do an out-and-back loop (suggested by Bob on a previous page) to see if I am returning lower gas mileage than expected.
    Edit: My expected MPG will be in the 50.0-50.2 range, which I would not call significantly above the rated mileage.
    #74 KyleSTL, Mar 23, 2016
  15. KyleSTL
    79
    Seems reasonable, better than my experiences with similar loads and speeds.
  16. sw1tch
    sw1tch Junior Member
    Midwest
    Something to keep in mind is that in some of those regions, you might have gotten a tank of E10-87 as well which would only make your MPG worse - if you previously filled up with regular 87 octane the mpg hit would be noticeable afterwards.
    Anyway, my point is if all driving conditions stay the same and you get a tankful of E10 your mileage will take a hit afterward. Anything else (such as crosswinds, temperature, hills, etc) will just add to it.
  17. KyleSTL
    79
    Goal acheived! Trip mileage was 500.5 miles @ 50.5 MPG average (calculated @ 48.0 MPG). Here's the updated graph (text added to the lowest 4 fillups):
    It's surprising that this winter's mileage was so bad, considering it was fairly mild here in St Louis.
  18. Steve terry
    Steve terry Member
    217
    Oklahoma
    That is what lowered mine down. Used to get 100% gas at SAMs club then they switched to E10. Plus after the recall on power inverter. Not to mention that Oklahoma is always windy. That kills the mpg to around 35
  19. trip1027
    trip1027 Member
    106
    27
    wyoming
    Hey just like to point out that the gas in Missouri and Montana us usually drop my mpg in any of my vehicles... so if you do trips through them try to get the bare minimum gas from them
    SM-N920V ?
  20. fuzzy1
    10,474
    I normally do better in Montana than down here at sea level, due to the higher elevation and thinner air.
    But you are in an even higher place, so your results will be poorer almost anywhere else you travel.
