Very specific situation question (about heat and charge level)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Nov 23, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    If the following variables are true:
    -Extremely cold day out (highs in the single digits)
    -Will be hauling around people that like a very warm car
    -Will be in a lot of stop and go traffic
    Is the best practice to charge only to about 2/3 or 3/4 of the way full (according to the battery graphic on the HSI)?
    My thinking is the ICE will be running a lot while stopped at stop lights and waiting in traffic. And I might as well have somewhere for all that extra energy to go.
    I know we are kind of splitting hairs here, but I wanted to think about this situation before it actually came up.
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Just thinking out loud, but as soon as you turn on the heater fan, you'll loose enough charge to not worry about an overcharge. I'd charge up as usual and just drive. You'll get the benefit of EV-Boost to help with the poor mpg while the ICE is constantly trying to heat up the coolant.
  3. markabele
    5,084
    1,782
    Nebraska
    The fan requires very little energy, though.
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Agreed but the EV range drops when you turn on the fan.
  5. markabele
    5,084
    1,782
    Nebraska
    But the EV range has nothing to do with how much energy is actually left in the battery. At least in that regard.
  6. bisco
    52,863
    i would fully charge it. the software will use the battery for propulsion whilst the ice is warming. by the time it starts using the ice, the battery will be so low in that kind of weather, you'll wish you had completely charged it.
  7. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Your concern appeared to be overcharging the battery while stopped which you mitigate by partially charging the car before driving. If you fully charge the car, turning on the heat to keep those passengers warm will prevent the ICE from overcharging the battery while sitting at stop lights.
    And I still think you're better off using the EV-Boost to improve the mileage, especially in NE where temps will be single diget or less in the coming weeks.
  8. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    The ICE will not recharge EV miles, so go ahead and fully charge the car. The only time you ever recharge EV miles, except from the wall, is through braking regeneration, so the only time you would want to charge less than full is if you start your trip from the top of a big hill or mountain.
  9. markabele
    5,084
    1,782
    Nebraska
    Huh? I've been at a stop light and seen my EV go up. I can't imagine it not charging some. Where are you getting that info from?
    XT1060 ?
  10. bisco
    52,863
    right, the ice does recharge the battery when it's running and the software decides it won't use gas to do it. except when you hit hv and it uses the ice to make up the lost ev miles while ice was warming up.
  11. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:What happens in that scenario with a full charge and additional regenerative braking?
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    The ICE starts to burn off some electric, no room to store it.
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Actually, it will. When the engine runs for heat, there's excess power. That energy is directed to the generator to create electricity. EV-BOOST consumes the electricity though, which is used during engine warm-up and while you drive. So, there's no worry about exceeding the "full" level.
    Just turn on the heater and don't worry about it.
    Also, keep in mind that the coolant threshold for the heater adjusts with the temperature you set. A higher cabin setting will result in a higher threshold... which could use more gas than what's needed. It depends upon outside conditions and speed of travel.
    65 works well for providing heat. You'd be surprised. If that's not enough, try 72. With an aftermarket gauge, you can fine tune your preference.
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    The comment about the ICE not recharging the battery refers to the general policy in the software that the ICE will not be run for the specific purpose of increasing the battery charge. There are several cases where the battery will be charged, but only as an alternative to wasting energy. For example, regenerative braking, and while warming up the ICE.
    Ken Blake and markabele like this.
  15. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Is there a variation in how warm your passengers want it? If there is try putting the one who wants the hottest in the front passenger seat with the seat warmer. You might be able to cut the heat setting.
  16. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    90 miles drive from Jersey Shore to Norh Jersey, heat on, 23 degrees out side 25 mph winds gusting to 40 mpg, only averaged 45 mpg, in stead of normal 57-60 mpg.head wind all the way!
  17. bisco
    52,863
    going up a mountain, and coming down the other side, i find all the passengers colder on the second leg. not sure if it's the wind or the altitude change.
  18. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Its simply fear that make them cold, shear fear...
    retired4999 likes this.
  19. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
  20. bisco
    52,863
    what is the hv battery level? my car does not have that. did they add it to the '13?
