Very specific situation question (about heat and charge level)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Nov 23, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    Michael,
    No it goes up well after I have stopped. John also confirmed that it can store the extra energy the ICE is producing.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Agree here.
    Simple test: stop the car while HV battery shows, say, 5 bars. While stopping, request cabin heating, you will see battery charging while ICE is on.
  3. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The battery indicator is solid in color while EV range is possible. Once the EV range is gone, the indicator is segmented like it is in a non-plug-in Prius.
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The only time I've ever seen EV range replenished is after some heavy regenerative braking on a long downhill stretch of highway. The ICE, by itself under normal conditions, has never added any range to EV.
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    This is not exactly true.
    You have EV range with 8 and 7 bars of the "segmented" indicator. At this stage, even short downhill or ICE operating while stopping will replenish some tenths of an EV mile. Zero EV is when the charge is going down to 6 bars (and then EV mode switches to HV mode), I think this represents about 23% SOC. However, it will go back (long downhill) to EV mode at about 26% SOC (however, you can manually change to EV mode earlier - after indicator changes from 8 bars to solid battery indicator and EV miles will re-appear).
  6. markabele
    5,084
    1,782
    Nebraska
    So you think this extremely efficient car just wastes the energy while the ICE is running and not providing any propulsion?
  7. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Maybe in Israel you have that, but in mine bought in the US, the EV range remains solid and becomes segmented after the EV range has been depleted.
  8. markabele
    5,084
    1,782
    Nebraska
    I think you guys are talking about the same thing just describing it in very different ways.
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Your words, not mine. The ICE does not charge up the EV range when idling or running normally once it's depleted. The only time I've ever had an EV range added was on a long downhill where I was using regenerative braking. Never at a stop light, stop sign, in the driveway or on the highway just driving along with traffic.
  10. markabele
    5,084
    1,782
    Nebraska
    We are talking about while you are still in EV mode with EV range left correct?
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I am out:)
  12. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Yes, with EV range still available, it will regen additional miles. Once it's depleted and in HV mode, I've never been able to get any more EV range except as noted earlier.
  13. markabele
    5,084
    1,782
    Nebraska
    OK...I was talking about when there was EV range still left.
    Ya, when you deplete EV and the car becomes a regular Prius you really have to regen a lot to get any sort of range back on there.
  14. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Don't run off, it could be the US version is different from those models produced for other countries.
  15. markabele
    5,084
    1,782
    Nebraska
    haha...you are hard to argue with though. You have had two different arguments in this thread...but essentially you were agreeing with both of them, although in a different way of saying it.
    giora likes this.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Do not think so, the situations I was describing were already described by others in this forum, they can also be found in the manual.
    Try it, when going down from 'solid' battery icon to 8 bars segmented, you are still in EV mode and you have EV range (about 1 mile?).
  17. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I would charge up to full. I don't think the ICE recharges much EV except when you first switch to HV from a cold engine. The infographic clearly shows there is some charging but it is so incremental that you only see the charge level rise when the meter switches to bars. So unless you head downhill from the start of the trip, I think you would have plenty of battery capacity to absorb leftover ICE energy.
    Turn off signatures in Tapatalk Tapatalk
  18. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Page 268 in my manual clearly shows the hybrid battery status indicator displayed solid and not segmented when in EV mode. In HV mode, the display becomes segmented.
    Perhaps we're discussing something else and I've gone off track. I'm really not trying to be disagreeable though looking back it would appear to be so :confused:
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Manual has graphic description of all situation with explanations. Its page 75 of my (European) manual. Try to locate it (Hybrid battery (traction battery) status)
  20. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Yes, it's on page 59 in my manual.
