Very stiff brake pedal, very little brake action
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dan T, May 13, 2022.
  1. Dan T
    Dan T New Member
    Coudersport, PA
    Noob here, grateful for this forum.
    2 days ago, the wife parked our 2010 Prius in the driveway and mentioned an odd sound from the brakes.
    Next day I go to run an errand and find that the brake pedal is hard, very hard to depress and there's almost no braking action, it barely stops.
    So I had it towed to a local dealership in Bradford, PA.
    They're diagnosing a failed actuator and a break line leak.
    They want to charge $3500 to replace the actuator (which was replaced in 2013 under a recall), $350 to do the brake line.
    I've researched the average cost to replace this and they run from $1500 to $2000. SO we really think the dealership is trying to gouge us on this repair.
    Who else has had this issue and how much did repairs cost?
    49,358
    i have read around $2,500. typically. have you checked other dealers?
    it's hard to believe there is a brake line leak, how is the level in the reservoir?
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Seems expensive as said above I would try another dealer of better yet find a mom and pop hybrid shop.
    I would file a complaint with NHTSA. This is a major safety problem and should be covered by Toyota especially if it’s a repeat fail point.
    Dan T likes this.
  4. Dan T
    Dan T New Member
    Coudersport, PA
    Anyone done the CG jumper trick? Put in the jumper, start the car, let it run it's diags then hit the brakes 8 times in rapid succession to reset the brake system.
  5. ChapmanF
    15,402
    That isn't a reset, it just clears trouble codes. But getting the car to forget what it knows about a brake problem isn't the same as fixing the brake problem.
    Dan T, Tombukt2, CR94 and 2 others like this.
  6. Tombukt2
    Tombukt2 Senior Member
    8,877
    1,549
    Durham NC
    Pennsylvania is not a state where you want to be messing with Toyota dealerships or having to go to court with your kids believe me
    Dan T likes this.
