Very Strange Lexus Crash
Discussion in 'Fred's House of Pancakes' started by Tickwood, Aug 29, 2009.
  1. fuzzy1
    10,707
    Many people state the first line as if all steering will be lost. The Edmunds article is partially correct in that only the assist stops, not the steering itself.
    But I spent my first decade of driving in two cars that stalled anywhere and anytime they wanted, no matter how inconvenient it was for me. The first did so frequently, the second much less so, but still often enough to be annoying.
    Sure, it takes considerably more force to steer when stalled. But I remember having difficulty steering only at parking lot speed, not street speed. Is my memory faulty from age, or are modern power steering systems that much harder to steer when stalled, compared to '63 and '78 Fords?
    This case seems strange enough that I must wonder aloud whether it was intentional. That is the reason for the domestic violence question. If a big city police chief near here (Tacoma) can do it, so can anyone else.
  2. 71Corolla
    71Corolla New Member
    17
    At freeway speeds, the power steering is not doing a whole lot regardless of the age of the car, so you're memory is not failing you. The only limitation would probably be if you tried sudden wheel movements at speed, then the lack of assist would result in slower turn in and having to use much greater force. But you can still steer.
    Something is indeed strange about the whole incident. I am nearly 100% certain that either the act was intentional, or the driver simply lost it and was unable to think with any clarity. The chances of the vehicle itself being to blame are incredibly low, nearly impossible. That goes for any modern vehicle not just this one.
  3. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Re: Very Strange Lexus Crash- follow-up
    Preliminary reports are that the crash was do to jamed all-weather floor mats. Reportedly the brakes were on to the degree there were flames coming from the front wheels, yet the car continued to accelerate (it was on a downhill slope). Apparently to turn off the Lexus you needed to hold down the power button for three seconds. Does the Prius require anything like that?
    The 911 tapes have also been released:
    911 call from car crash that killed CHP officer, family released - San Diego, California News Station - KFMB Channel 8 - cbs8.com
    911 Call Released In Fatal Santee Crash - San Diego News Story - KGTV San Diego
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Improper floor mats have been implicated in many crashes. There have been TSB's issued that deal with that, and even my FJ Cruiser has a warning about improper floor mats leading to a loss of control and a crash
    At highway speeds, if you press in the power button and keep it depressed, after about 3 secs the Prius will power down, shift into N. Folks who operate a car with a push button start system MUST know the proper procedure to kill the car, in an emergency
    Of course, in a conventional vehicle, you turn the key to off, except most folks turn it too far to Lock, and the steering column locks up. That can also cause a crash
  5. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Isnt the Prius steering electric?
    What happens if the power is turned off while driving?
    Can it be steered?
    Also about brake fluid boiling.
    Isnt the emergency brake fully mechanical not hydraulic?
  6. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Power steering generally has variable assist depending on what gear you're in or how fast you're going, with maximum assist at low speeds and less assist the faster you're travelling. You don't need much assist to change lanes, and indeed you don't want assist because an overreaction from the driver would just spin the car out.
    "Directions and amount of assisting power are determined by signals from the torque sensor built into the steering column assembly and by the power steering ECU, and controlled in accordance with
    vehicle speed. As a result, steering effort is controlled to be light during low speed driving and moderately high during high speed driving."
    -- Gen 2 Prius service manual, section PS - Power Steering.
    The Prius power steering control ECU gets its speed information from the Skid Control ECU, which reads it from the wheel speed sensors. (The same information drives the speedometer.)
    So you don't notice a failed power steering at high speeds because it's not providing much assistance at those speeds when it is working.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Electric assist, same as the new Corolla. The brakes are electric assist, same as the FJ Cruiser
    Yes, it can be steered, but the wheel effort may be a lot higher
    If you don't maintain your braking system, old brake fluid can boil fairly easily. With vehicles I had pre-Prius, I'd flush the brake fluid every 2 years. You'd be surprised at the condition of brake fluid after sitting for 2 years
    Otherwise, for brake fluid in good condition, you're really have to smoke the brakes before the fluid boiled. That is, the pads would probably melt first
    The parking brake on a 2004-2009 Prius works off the rear drum brakes, and is fully mechanical
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    I should clarify: with my Prius I also had the brake fluid flushed every 2 years, but at the dealership. With the Prius, a brake fluid flush and bleed is clearly not a DIY task
