Vibration and noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michaelz, Sep 30, 2025.
  1. Michaelz
    Michaelz New Member
    Netherlands
    Hi all! Hope you guys can help me identify a vibration and noise coming from the front. The noise started a few weeks back and sounds a bit like the AC compressor, but louder (AC is not on btw). I think it's coming from the front-left side. The noise changes with speed and has some points where it is more noticeable, like 54km/h, 80 km/h and 100km/h. The noise doesn't really change with loads like turning, accelerating or braking. The vibration is weirdly only really noticeable through the gas paddle. I can't really feel it through the steering wheel, mayyyybe when I squeeze the steering wheel real hard. The sound and vibration is the same with the ICE on or off. The electric motors sound healthy when accelerating and regen braking.
    I swapped wheels left to right and front to back, also tried another set of wheels, but the issue doesn't change. Checked all the nuts and bolts, but nothing seems loose. I tried listening for wheel bearing noise, but it's hard to tell when the drive shafts and all are still connected (no obvious weird noises). I first noticed the noise and vibration shortly after I removed the front bumper and bumper-bar to get access to the AC condensor, but can't think of a reason this could result in this noise and vibration, but thought I'll mention this.
    I'm somewhat concerned this has something to do with the inverter, but hopefully it's something like a wheel bearing. Do you guys have some suggestions?
    52,706
    how many miles/km, and how old are the bearings? sometimes you can jack it up and feel some play when moving the tyre up and down or left and right by pulling on it from the back.
    if it is a bearing, the sound will eventually get worse.
    could something on the bumper cover or aero cover underneath be loose and vibrating from the wind?
    Michaelz likes this.
  3. Michaelz
    Michaelz New Member
    Netherlands
    Here's un update. The sound weirdly became a bit milder, so gave it less attention. Eventually the car needed to go for it's yearly inspection and turned out the front-right wheel bearing was the issues. Changed it myself (wowww, that thing was STUCK in there) and now the car is whisper-quiet again. Funny how noise can seem to come from another corner than it actually comes from. Problem solved :)
    bisco and Brian1954 like this.
    52,706
    congrats, well done!
