Vibration at 68mph in 2010 Prius?
Discussion in 'Gen 3 Prius Technical Discussion' started by splais, Nov 18, 2011.
  1. splais
    splais Junior Member
    17
    Yuma, AZ
    I just purchased a 2010 Prius III with 47,000 miles on. I love the car except for one thing. it has a vibration I can feel in the steering wheel and seat at around 68-69mph. The dealer says it is normal. I did test drive another 2010 Prius and it did seem to have the same vibration. So can anyone tell me this is something I'm going to have to live with or any possible fixes? Have you heard of this before? thanks.
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I have read about some people complaining about rattles and vibration issues in the Prius. My Prius does not have any rattles currently, though I suppose it could develop in the future.
  3. tv4fish
    tv4fish Member
    202
    46
    What's the history of your front tires and front brakes? First thing I would do is make sure the front tires are balanced properly.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    No it is not normal. I agree with tv4fish, probably a tire balance problem on the front. But as long as you are going to have it done I would have all 4 balanced, and rotated if needed.
  5. splais
    17
    Yuma, AZ
    Yes, I'm getting the tires balanced tomorrow. It bothers me when a toyota dealer says it's 'normal' for there to be a vibration right in the middle of the prime driving range.
  6. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    You might need a Hunter Road Force balancer to solve the problem.
    But if these are the original tires that have never been dismounted, then they were already road force balanced at the factory.
    MB860 ?
  7. splais
    17
    Yuma, AZ
    Well I just found out the tires had been balanced at the dealership when they were checking it out. So I'm at an impass it looks like.
  8. davesrose
    davesrose Active Member
    767
    164
    Atlanta
    When I first joined this site, I had read all sorts of issues about rattling or vibrations with the 2010 Prius. I have occasionally heard rattling with my car...but it's always shown itself to be a seatbelt or buckles with my pet cover. I have yet to have my car develop any rattles or vibrations while going 70+ on the highway.
  9. The Critic
    3,193
    2,333
    CA
    But was it done using a Hunter Road Force Balancer? That makes a difference.
  10. splais
    17
    Yuma, AZ
    Don't know I'll check
  11. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    This is not nornal. The dealer that sold it to you, says this is normal and denies your claim, is full of sh-t. Go to a quality independant shop, or another Dealer, discribe the issue, ask for a mechanic ride along (if allowed), but "do not" tell them where you bought the car or your experience with them. Have them check the wheel ballance, alignment, suspension components, wheel bearings, drive axles, and anything else they may consider suspect. Remember this is a used car out of "full" warranty and a non-vested Mechanic is better under these circumstances.
  12. splais
    17
    Yuma, AZ
    Not exactly out of warrenty. It is a Toyota Certified used car with a comprehensive 12/12000 warrenty. Of course, if the dealer just states this is normal kind of puts and end to discussion. I may take this directly to Toyota and see what they say. But it looks like "I" have to figure this out because they sure aren't.
  13. frodoz737
    4,699
    2,497
    33
    Or don't want to. Remember your Service Agent ultimately has the same Boss your Sales person has at this Dealership. It is hard enough fixing these problems under new car warranties. No profit. A document stating repair is needed from somewhere else gives some leverage. Be firm, but polite. Elevate your claim and document everything (names, times, dates, ect...). Good luck.
  14. splais
    17
    Yuma, AZ
    frodoz737, I just noticed you have a 2010 Prius. Do you feel any kind of vibration in your steering wheel and seat at around 65mph and above that you do not feel at slower speeds. I haven't tried to see if the vibration goes away above 75mph. Thanks
  15. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    I have a 2010 V, no vibrations at any speed, good luck with the dealer you'll need it
  16. tumbleweed
    4,067
    692
    Eastern Oregon
    Try rotating the tires front to back and see if it goes away or changes. That may tell you if is a wheel/tire or something else.
    I just had a similar problem with my car and it went away when I rotated the tires. I never found out what it was for sure (wheel or tire) because I was offered a deal I couldn't refuse on a new set of tires. When I rotate them I should find out if it was a wheel or a tire, I suspect a tire.
  17. bac
    bac Active Member
    863
    52
    Pennsylvania
    Is this is the same dealership that told you that it's normal for a car to vibrate @ 68mph? Call me silly, but I'd get all 4 tires balanced somewhere else and see if your issue improves.
    Good luck!
    -Brad
  18. tumbleweed
    4,067
    692
    Eastern Oregon
  19. Pfcardwell
    Pfcardwell New Member
    39
    St. Louis
    i had this problem on my 2000 Toyota Van after a brake job, went back a couple of times complaining, drove me nuts, then started really looking and it turned out that the rear wheel was not on the hub correctly, you could tell because the threads on the luggs were different than the other side. Bottom line look at the wheels in the rear for any problems.
  20. tumbleweed
    4,067
    692
    Eastern Oregon
    I agree, it is a good thing to check especially on cars with "lug centric" vs "hub centric" wheels. With our cars the lug nuts are used to center up the wheel instead of a hub in the middle. Tire Rack says it is critical to torque the wheel lugs with the wheels still off the ground with lug centric wheels.
    http://www.tirerack.com/wheels/tech/techpage.jsp?techid=91&affiliate=TX4
