Vibration at 68mph in 2010 Prius?
Discussion in 'Gen 3 Prius Technical Discussion' started by splais, Nov 18, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If it turns out to be the tires please let us know the exact make and model. I know some people were having trouble with the Goodyear Fuel Max tires.
  2. splais
    splais Junior Member
    17
    Yuma, AZ
    I'm taking it in Monday to both have the tires rotated and get them Road Force Balanced while I watch and not having it done at toyota. going to a tire shop.
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Our freeways are speed limited at 110 kms/h(68mph). I drive at the limit all the time. My 2010 gen III feels rock solid and smooth at that speed. :)
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Good. Make sure the tire shop's technician understands how to utilize ALL of the functions on the GSP9700 machine. I would do some research on your own on the operation procedure of the machine so you can see that the road force balance was done properly. Chances are, some or all of the tires will need repositioning on the rim.
  5. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    None. Like I said this is not normal.
  6. splais
    17
    Yuma, AZ
    Well I had the tires Road Force Balanced and rotated at Big O tires. The tires were Michelin Destiny's by the way. The tire guy said the tires 'were not' balanced properly. he also said I needed to take them out on the freeway at speed for a good bit because they had flat spots on them and getting them hot may let them round out again. Anyway, the vibration is pretty much completely gone.
    2 people like this.
  7. frodoz737
    4,795
    2,560
    33
    I doubt your warranty will cover this cost reinbersment, but you have an opportunity here. Go back to the Dealership and discuss this with the Service and General Managers together, politely. My guess is if they want your continued business, they will hook you up somehow.
  8. splais
    17
    Yuma, AZ
    I am in a quantry. Don't know where I will go for serious work. this dealership s***s. I took my 2010 Camry in because a tire was leaking slowly. They couldn't find it! Big O tire found it in about 30 seconds. it was an old plug leaking. I know a gentlemen who worked there for awhile. He stated it was routine for a couple of the service writers to pad the work sheets with unneeded work they talked customers into. It's no wonder. This dealership pays their service writers no base salary; just a paultry 6% commission. Problem is there are not a lot of independant shops that I believe are qualified to work on hybrids; at least not around here. it's a sad thing, but my feeling is that all dealerships are crooks and will screw you every time if you let your guard down even for a moment. I sure as hell will never let this dealership do anything related to tires and wheels on my car again.
  9. frodoz737
    4,795
    2,560
    33
    A 100 mile dealer search for Yuma on Toyota.com only shows 2, Alexander and Rogers & Rogers (50 miles away). Neither is considered an award winner, even by Toyotas standards. Your best tool then is stay educated about your vehicle and try and establish a respectful relationship with your service dept. Oil changes, wheel rotate and balance, and tires can be done outside the Dealership, other things can not.
    You still have great car. Take care of it and it will take care of you. ;)
  10. copymark
    copymark New Member
    AZ
    My first post here. I just happened to buy a new 2011 Prius II at Alexander of Yuma myself. Have 3500 miles on it so far. The gauge says I'm getting 52.8 MPG and I haven't heard a rattle or vibration yet going as fast as 72 on I-8. Feels like a luxury car to me so far and I absolutely love it.
    The desert heat out here can be awfully rough on tires at times. I'm counting on the extended service warranty to keep this investment in top shape.
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    :welcome: Welcome to Prius ownership; here's hoping you have many happy trouble free miles.
  12. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    If the vibration goes away at higher or lower speeds, it is wheel balance.
    If the vibration is noticed on the front seat. this is a rear balance issue
    Buying used is ( I wonder ?) The rims or rim could be damaged from pot holes or accident. This can be seen on a tire balance machine and the tire will hop or as it rotates you will see the tire move up and down on the flat tread area.ie the tire will conform to the rim. This will happen more often with aluminum rims. If you can feel it in the front seat that point to a balance or out of round rim in the rear. They will have to be replaced. Another thing you can try is to rotate the tires and see if the problem is changed.
    It just takes one bent rim to cause this. You can narrow this down by a visual on a balancing machine.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I just drove home from work in my 2010. I set cruise control at 66, 67, 68 and 69 to see if I could get any shaking, but I couldn't. I'm glad I read about the procedure for torquing the lug nuts while the car's jacked up.
  14. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    As long as you know what someone, or an organization, is capable of, you can deal with them accordingly.
