Vibration at high speeds
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fifen, Sep 29, 2023.
  1. Fifen
    Fifen Member
    77
    33
    Utah
    I have posted about this in the past. I'm back with the same issue.
    I'm exhausted trying to fix this issue. For the last 6 months my car starts shaking at speeds of 70 mph and gets worse the faster I go. Around 80mph my steering wheel feels loose. It's the front of the car that shakes. I'm pretty mechanical. Backyard mechanic. So I replaced all of the suspension except the outer/inner tie rods. I got a wheel balance, rotation, and alignment. Still happens but I can go 70mph safer now. My wheel hubs were bad so I changed those out for new mevotech ones. It still happens. I replaced my tires. At this point I don't know what could be causing it.
    I hit 85mph to see if the shake would go away after a certain speed. It got really bad and remained shaking until I dropped down to 67mph. It happens when accelerating and when not accelerating.
    Car is 2010 Prius with 160k miles.
    SM-N986U ?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Possibly worn inner cv joints. Does acceleration improve or worse the vibration?
  3. Fifen
    Fifen Member
    77
    33
    Utah
    The cv axle was replaced. I don't think acceleration has an impact. I can try to coast down a mountain and see if it happens. If I let off the gas the shaking remains until I get low enough
    SM-N986U ?
  4. PriusCamper
    PriusCamper Senior Member
    13,427
    5,421
    Pacific Northwest, USA
    Maybe try a different shop for alignment, as well as rotate and balance of tires? In recent years, we've seen an increase in dishonest alignment shops not doing the work and still charging you for it.
  5. bdc101
    bdc101 Member
    250
    usa
    Why didn't you replace tie rods?
    Like PriusCamper said, alignment shops are inconsistent, rushed, and even dishonest. I wouldn't be surprised if you had it aligned and they didn't notice bad tie rods. They could cause this problem.
  6. Fifen
    Fifen Member
    77
    33
    Utah
    I have new ones. I'm just so burnt out working on the car. Every time is 5x harder than what I expect. I might just pay a shop to put them on and do an alignment
    SM-N986U ?
    bdc101 likes this.
  7. The Critic
    3,193
    2,333
    CA
    Genuine Toyota axle or aftermarket? Aftermarket axles tend to be a significant driver of vibration issues.
  8. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    Have you checked the brake pads and rotors? Maybe a bad spot of the rotor?
  9. The Critic
    3,193
    2,333
    CA
    Rotors will not cause vibration during cruise.
  10. ASRDogman
    8,053
    4,083
    Yes, they will. If they are out of round, warped, or the pad has embeded itself into it.
    Either from sitting for long periods, or getting hot then driving in the rain and cooling off quickly.
  11. The Critic
    3,193
    2,333
    CA
    Pads do not contact rotors during cruise. Even if there was excessive LRO or DTV, this feedback can only be transmitted when the pads are in contact.
  12. Fifen
    Fifen Member
    77
    33
    Utah
    I have looked at the rotors. If there is something wrong with them it's not visible. They are about 5 years old and I got very high quality ones. To be fair I live in the mountains and use them more than your average Prius owner. The caliper isn't stuck in any capacity. I'm well aware of what that feels like.
    Today I was carrying a heavy load in the rear. I got to 90mph on the freeway before the shake started. So it didn't get bad with more weight in the car.
    SM-N986U ?
  13. bdc101
    bdc101 Member
    250
    usa
    Once I had a rotor turned that was slightly warped. The shop turned it and never checked whether they got rid of the warp. However, that only caused vibration during braking. My money is on tie rods, OP
  14. Fifen
    Fifen Member
    77
    33
    Utah
    I'll update once they are replaced
    SM-N986U ?
  15. Fifen
    Fifen Member
    77
    33
    Utah
    It's fixed. It was the tie rods. And the tires were slightly out of balance. That stressor is gone. But I noticed a new concern. When I accelerate I feel a slight thunk in the peddle. It's very slight and I think it was happened before these issues. I'm thinking it's my calipers releasing. Like they are being a bit sticky and when they open fully they make a clunk
    SM-N986U ?
    ColoradoBoo and bdc101 like this.
  16. bdc101
    bdc101 Member
    250
    usa
    Glad to hear you got it fixed!
    Brake problems don't usually cause a clunk problem like that, when taking off from a stop. Usually a clunk when taking off from a stop is caused by an engine mount wearing out. But it can also be other things. Does it only happen when taking off from a stop or do you notice it other times as well?
  17. Fifen
    Fifen Member
    77
    33
    Utah
    Mainly happens when starting from stopped. Or if I'm going really slow. It doesn't happen every time. I was thinking the brakes. But it also kinda feels like it's right below me. I almost wonder if a rock is stuck in the skid plate and is sliding around.
    SM-N986U ?
  18. Fifen
    Fifen Member
    77
    33
    Utah
    Just did a short drive today. It does happen while moving. But only when going slow. So applying brakes. Or sometimes when turning sharply and moving slowly. I can't imagine it's my cv cause it's brand new.
    SM-N986U ?
  19. bdc101
    bdc101 Member
    250
    usa
    I would bet the rear engine mount. Or it could be a CV possibly. If your mechanic used a cheap CV axle, the cheap ones can wear out really fast sometimes. One reason why I always used quality halfshaft.
    The rear engine mount failing would cause a clunk when starting off from a stop, or at low speeds when stepping on the gas. As the vehicle speeds up, the engine/trans combo produces less torque going to the halfshafts, just because of gearing. So the clunking will become lesser and lesser in magnitude.
