Video: Toyota demonstrates "Safely Stopping Your Toyota Hybrid Vehicle"
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Mar 12, 2010.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Over 62mph, shifting to N can over manage MG1 (transaxle). I think that's why they put it in the manual not to do that.
  2. gbarry
    gbarry Junior Member
    79
    16
    S. California
    So now I'm a little concerned the computers might refuse to go into N at those speeds. Anyone have the source code?;) Anyone dumb enough to try it? I've done it at 40, but I ain't doing it at 70:eek:
  3. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    I thought I read not to be in neutral above some numbers in the 40s with the gen 3. I can't remember the number. I have not tested it above 35. I don't like to practice potentiallye unsafe things on a new car based on forum advice. I'm sure someone else has done the test at 90s I'm not willing to do that.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes and at 100mph. The engine stopped reving and I started to slow down. Shifted back into drive at 65mph and continued on my way.
    At 100mph and full throttle the brakes will work and slow you down also.... QUICKLY!
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    One point here is that ClownBoy was in an '08 Prius, and the
    excerpt is from the *2010* manual. So he wouldn't have read it.
    The larger point is that it *shouldn't be*. The 2010 transaxle
    and shifting stuff works just the same as the generation prior,
    and that big hairy warning is in the manual IN ERROR. There is
    absolutely no harm shifting into N, as has been reaffirmed hundreds
    of times in other threads. At a minimum the section should be
    removed, or for more clarity rewritten [in the other section that
    talks about shifting] to simply list some caveats about N and
    braking and timeouts. Do *NOT* interpret what I quoted as any huge
    caveat about the 2010 or any other year of Prius -- it's largely
    WRONG. I just don't recall anyone pointing it out on the forums
    until now [but could easily have missed a mention].
    The only real hazard of Park would be in the *first-gen* car,
    where it's still a mechanical linkage. N is safe there too.
    _H*
  6. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Is the max deceleration rate limited by the max rpm of the MG1 ?
    The ICE rpm cannot be dropped to 0 at a higher rate than allowed by the MG1. In fact, the higher the speed, the slower the ICE's deceleration has to be or equivalently, the earlier MG1 hits its max rpm.
    Interesting stuff.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    No. All drive power can be removed at any speed.
    At higher speeds, the ICE must keep turning to avoid overspeed for MG1, but the ICE does not have to produce power in this mode. It can spin without fuel or spark.
    All of this talk about the dangers of N at high speed come down to one very specific and unlikely scenario: shifting to N at lower speed and then costing to a very high speed. At lower speeds the ICE physically stops when you shift to N. If you were to coast down an incredibly steep hill, the Prius would gain speed without being able to restart the ICE (not allowed in N). At some point, if the coasting speed gets high enough, MG1 will overspeed.
    It takes a *lot* of energy to overcome drag at high speed. Very few grades are steep enough to do this. This situation is not likely to ever happen in the real world. In the event of an emergency, you shouldn't even consider the risk of hurting MG1. It's not going to happen, and even if it did, it's just a piece of machinery.
    Tom
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Back to the extra credit - Not every Gen II Prius had SKS, thus putting it into the slot may be appropriate.
    The model's hands aren't exactly "hand model quality".
    The give-away, though is the lack of ANY other keys on the FOB. How many others keep JUST the fob w/o any other keys attached?
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I have tried it above 62mph. The car is smart enough to keep the ICE going at RPM to prevent MG1 from over-revving.
    Tom's post is accurate about the only danger in N. That's if you shift to N at 55 mph (ICE RPM=0) and let the car coast in N above 62 mph (hill has to be very steep and long). It has been said that ICE will remain at 0 RPM even when the car goes above 62 mph and MG1 rev above 10k RPM.
    Toyota may have closed that loop hole in gen3 Prius. Can anyone with gen3 and scangaugeII confirm it?
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    My 2009 manual, p.126 has the warnings you first posted about not shifting into R, N or P while moving ... damage to transmission may occur.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Putting the car in N or, if that doesn't work, powering off, is covered in the 04 -09 floor mat recall letter.
  12. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    How low does the ICE rpm goes before the ECU considers it "physically stopped" ? I would think it is somewhat higher than 0 rpm.
    Can the wheels drive the ICE ?
  13. qbee42
    18,058
    3,079
    Northern Michigan
    Physically stopped is stationary. Not only does it stop completely, but the Prius parks the ICE at a particular point to make restarting more efficient.
    Yes, as long as MG1 provides back torque to prevent freewheeling.
    Tom
  14. hill
    8,794
    Wow that's too bad you didn't read all the warnings splashed ALL over the video to (before playing) BEWARE ... due to foul language. This is exactly why folks can't stop their cars ... no one seems to bother reading the instructions. What do you want a bet ... back 70-80 years ago when the 1st key ignition/starters were installed ... and mechanical throttles stuck open ... no one read up on how to turn a KEY off. As it was written thousands of years ago, "... there is nothing new under the sun ..."
    :rolleyes:
  15. qbee42
    18,058
    3,079
    Northern Michigan
    Could you please repost this, but use smaller words?
    Tom
  16. hill
    8,794
    :lol:
  17. jendbbay
    jendbbay Member
    223
    oh you guys. I want to be as smart as you, but I'm too nervous about the consequences of making any assumptions. I went out and tried using the P button while accelerating. It worked perfectly. Car went into neutral and it beeped, I guess to warn me. I was able to shift it back into D with no problem. Showed my teenager how to do it and was quite content. Then I come back to Prius Chat, which I feel I must do now in order to be absolutely sure I understand everything about this situation.
    I did not read enough times that it is perfectly fine to just push the P button to put the car into Neutral and that I can do this at any speed without destroying my car, my transmission, etc. I do grasp the exception case about pressing P or shifting into Neutral using the joy stick before coasting down a long, steep hill. I actually know of exactly such a hill, so I'll try not to have a big problem right before the top of it.
    At any rate, here's what I want from you all.
    Please state again that Pressing P is just the same as moving the shifter to N, except that it is easier, because the button is so accessible and you don't have to hold the button in to gain the shifting into N result.
  18. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Is this car actually training its owners on improving their button pressing skills ?
    Wow.
    Perhaps none of these buttons do anything except reward the subject with what he/she thinks she wants.
  19. gbarry
    79
    16
    S. California
    "Pressing P is [effectively] the same as [holding] the shifter to N". It's the same, if you only want to consider the results. Inside its little brain, it quite a different story. But for your purposes, P will get you N.
  20. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Isn't the ICE stoppage achieved simply by disabling the spark or is there another mechanism used (MG1 perhaps) to park the ICE correctly ?
    That goes back to by original question : how does the ICE keep turning except by fuel and spark , in order to prevent overspeed ?
