VIN Decoder Resource
Discussion in 'Knowledge Base Articles Discussion' started by BreakingPrius, Sep 17, 2013.
  1. BreakingPrius
    BreakingPrius Junior Member
    35
    Dylan Doxey likes this.
  2. Bohica
    Bohica Junior Member
    I think this is useful. Thanks
  3. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Try this example VIN-decomposition description:
    J = (WMI), World Source: J = Japan
    T = (WMI), Manufacturer: T = Toyota
    D = (WMI), Vehicle Type: D = Passenger Vehicle
    K = (VDS), Body Type/Drive Type: K = 4Dr HB 2WD
    N = (VDS), Engine Family: N = 1.8L (2ZR-FXE) Atkinson
    3 = (VDS), Series: 3 = Chassis Code ZWV30
    D = (VDS), Restraint System/Grade: D = Manual Belts w/2 Airbags, Side Airbags, Three-Row Curtain Shield Airbags, and Knee Airbag
    U = (VDS), Car Line: U = Prius
    3 = (CkD), Check Digit(computer generated)
    E = (VIS), Model Year: E = 2014 (F = 2015, G = 2016, etc.)
    1 = (VIS), Plant Code: 0 = Tsutsumi plant, line#1; 1 = Tsutsumi plant, line#2; 5 = Fugimatsu plant
    X = (VIS), Serial Number: XXXXXX (most significant digit)
    X = (VIS), Serial Number: XXXXXX (least significant digit)
    • Where:
    WMI = World Manufacturer Identifier
    VDS = Vehicle Description Section
    CkD = Check Digit (Internal use only. Used by Toyota and FBI computers to verify the VIN)
    VIS = Vehicle Indicator Section
    • also: Vehicle Identification Numbers (VIN codes)/Toyota/VIN Codes - Wikibooks, open books for an open world
  4. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    It doesn't work. It just spins forever after typing in any VIN.
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
  6. PearlJammer
    PearlJammer Member
    112
    23
    Georgia
    2018 Prius
    Info is wrong. Says my car is black When it was born silver.
    Zero info about service history. Incorrect number of previous owners.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
