Vin needed for new 2010 hybrid battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PilgrimNed, Mar 16, 2025.
  1. PilgrimNed
    PilgrimNed New Member
    Louisiana
    Hello,
    I’m looking to save $1200 or so by providing my own battery to my mechanic. My quote for them getting the battery and changing it was around $3,800 - only $400 is labor / that’s all they would charge if I bring one in.
    - I’m trying to find an oem one but the only one I’ve found online says 2011-15.
    - I called some local dealers about buying one and they said there are two different ones for 2010 and you need the last numbers of your vin to figure out which one.
    - one dealer looked up my vin and said the battery would be 4400+ the core charge which brought it to over $6k…
    Is this vin thing accurate?
    And if so, how do I find which I need?
    And does anyone have a rec on a site to get the OEM battery?
    Thank you!
  2. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    You'll only find a "new" pack from Toyota. You don't really know if they are new or "rebuilt".
    Though some say they sell new blocks.
    And they're expensive.
    You should get the Sodium pack from Jack. It will cost less, and work better.
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,407
    5,413
    Pacific Northwest, USA
    There's no difference in battery packs, but there's obviously something different in their system.
    My guess is it would be the battery vent tubes because Toyota discontinued using the tubes on top of the pack in early 2010's because the hybrid cooling system provided more than enough ventilation for venting already.
    So one vin# would be a pack with vent tubes and the other vin # would be one that didn't have tubes and it won't make any difference if you have them or not.
    As a side note, it's a bummer that Toyota raised the prices so high on a battery pack recently . It was nice when all the Toyota Stealerships consistently sold them at $2K after you get your core deposit back.
    On the bright side at least you found an install price that is reasonable. Of course if you lived near me I'd charge you 2 hours to do the install at $48 per hour. :)
    More importantly, I agree with @ASRDogman you should consider having the mechanic install the newest most advance sodium-Ion packs which improves your car's overall performance in many different ways for a much lower price.
  4. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
  5. bbrages
    bbrages Member
    169
    47
    St. Louis
    You could try getting a battery from amayama - I believe the site is legit and the price for a battery is pretty good.
