Violent engine shakes at low temps
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MAW31, Mar 14, 2017.
  1. Market05
    Market05 New Member
    27
    Western Maryland
    Had a similar thing happen with a Kia I owned, and turned out to be a coil pack.
  2. MAW31
    MAW31 New Member
    Sarasota
    quick question; would that kick out a code? Thanks.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    It would kick out the misfire codes you got. The Prius has coils on plugs (COPs).
  4. andrewclaus
    993
    326
    Golden, CO
    It may be academic, but I wasn't aware of such a unit on the Gen 2 Prius. It sounds like you're talking about the coolant heat recovery system, and the pump, three-way valve, and temp sensor are separate items, with separate codes. If you're sure it has no bearing on the problem, fine, but it's a minor confusion in a confusing situation.
  5. andrewclaus
    993
    326
    Golden, CO
    Also, what scanner are you reading the codes with?
  6. MAW31
    MAW31 New Member
    Sarasota
    Advanced auto scanner. I'm 1200 miles from home in MA and working with kitchen utensils here...
  7. MAW31
    MAW31 New Member
    Sarasota
    It's cold here, so the car is utilizing the heating system that it never had to do in fla. would make sense that it might have an issue since it was never used for years. However, I believe that is not causal to the shutter issue I'm experiencing.
    I'm headed out to get plugs, a coil pack, some carb and MAF cleaner.
  8. andrewclaus
    993
    326
    Golden, CO
    Again, there is no coil pack. There are four separate coils, and it's doubtful that's the problem in this case, if you're getting multiple misfires. Inspect their condition when you change the plugs.
    Be careful with the TB cleaner--don't flood the TB as you normally would. Wipe it down carefully with a rag.
    edthefox5 likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I agree with Andrew since your getting multiple misfires it would have to be multiple bad cops.Maybe bad gas? Multiple misfires are usually mechanical issue with engine. Lots of sub harmonic vibration that you would feel in the cabin..
    Op you never answered my oil question. How much oil does it eat? And how low did it go on your trip?
  10. Mendel Leisk
    42,253
    Cooling fan cycles on/off somewhat like that. Maybe some connection?
  11. MAW31
    MAW31 New Member
    Sarasota
    Hi Ed, well I probably said it 3 times, but the trip was 1200 miles, and the engine does not eat oil. Was full at the start and was full on arrival. Thanks for your input.
  12. MAW31
    MAW31 New Member
    Sarasota
    I took a video of the engine running but for the life of me couldn't figure out how to get it posted here.
  13. MAW31
    MAW31 New Member
    Sarasota
  14. andrewclaus
    993
    326
    Golden, CO
    I've never witnessed a VVT system failure. I wonder if cold engine oil temps could be causing a problem with that. It might be worth checking the VVT filter, there are threads here about that. Just a SWAG.
  15. edthefox5
    10,096
    4,837
    Clearwater, Florida
    That's a blown bottom end. It's not missing it's banging.
    A 160000 mile g2 that doesn't eat oil especially a lot of oil on a 1200 mile road trip is a miracle.
    What kind of oil are you using and how often?
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    But you say it then goes away so maybe it is a cop There's a YouTube of a g2 with a bad cop making the same sound but sounds pretty bad.. But a bad cop usually doesnt fix itself.
    Maybe there's water in the spark plug well that's pretty common.
    I would only use Toyota oem cops.
  17. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I had this happen and clean and lube the throttle body flap with a copper brush holding open with the spring on the side and you should be able to hold open tbe throttle using the spring. if you can't lube spring and motor
    Also did spark plugs and pcv valve at the same time. then put the car in maintenance mode then pour seafoam down the throttle body avoiding the sensor with a funnel and have somebody floor the gas. it normal to have a lot of smoke out tail pipe and if it throws a error code just drive 5 min power off car drive 5 min power off car both error will clear then you done it would do it up hill too
    I see 1cup seafoam and 1 cup Marvel Mystery Oil in the gas works really good boost mpg too
    #37 Jmack111, Mar 17, 2017
  18. MAW31
    MAW31 New Member
    Sarasota
    Thank you all for your inputs.
    After buying plugs and 1 COP, I started with the leftmost passenger side plug. After observing that plug's black condition, (i have a photo), I replaced the plug and COP and voila, totally smooth running motor. I've driven it for a day now and no misfires. (Yes, I replaced the other plugs too)
    Patrick gets the award for nailing the issue from the start. And I know I fought it from what I was observing. I could not draw a line from what I saw and heard to a cylinder misfire, but that's what it was.
    Thank u all.
    Patrick Wong likes this.
  19. Patrick Wong
    18,210
    6,517
    1. What was the condition of the other three spark plugs?
    2. So would you say the cyl 1 spark igniter was intermittent?
  20. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    VVT Oil Filter? Poor MPG'S?
    https://priuschat.com/index.php?threads/81138/
    VVT Oil Filter? Poor MPG'S? Clean the vvt sensor and filter under it. Remove air box left side 1st Cylinder On front of engine Sensor with wire Side mounting book remove bolt twist and pull out Clean oil off and lube with light oil right below that there is a hex bolt Behind that is a filter that's attached to it made of wire clean with copper brush and carburetor cleaner reassemble had a 50% power boost Ticking when cold when away or pinging when cold no power ip hills 5min fix
