Visor extender
Discussion in 'Gen 4 Prius Main Forum' started by Smaug1, Aug 20, 2018.
  1. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I just received a pair of visor extenders I ordered from Amazon.
    After looking at it, I thought: "Couldn't I just make my own like that with a piece of cardboard/plastic and a couple of the right size rubber bands?" Yes, I could, but it would look ghetto. So I ponied up the money and bought these from some entrepreneur. Installed the driver's side one this morning. Looks like it will do the trick.
    It's a nice durable piece of plastic, cut to size. The seller will ask what car you have. Shipping is not fast, it took about a week, all told. The elastic bands are of course more classy than rubber bands and will last longer. That's how I justified it to myself, anyway. :)
    The only downside I can see is that in order to get full extension of them, one of the bands has to go over the round pin with which the visor latches to the roof. One can either leave the visor floating when not in use or keep them a bit further over, which will limit the extension a bit.
    The elastic bands are nice and wide, and will also be a great place to store parking stubs and such. I'll post a couple pix later of it installed.
    Cap'n and RCO like this.
  2. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Am I the only one the pic didn't load for? Do you have a link to where you bought them from?
  3. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    No pix yet, but there's a link to the item at Amazon, which has pix. (that's not an ad...)
  4. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    If you're not seeing the link just go to Amazon and search Visormates
    RCO likes this.
  5. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Pix. 20180820_174134_HDR.jpeg 20180820_174254_HDR~2.jpeg 20180820_174127_HDR~2.jpeg 20180820_174450_HDR~2.jpeg
  6. bisco
    52,469
    i got a cheesy plastic extender on amazon. held on by strapping tape, it has a tinted pull down riser, and sliding side to side visor for inner or outer.
    it rattles a bit, but works well.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
  8. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    No, you put it on the other side of the visor.
    alanclarkeau likes this.
  9. ASRDogman
    ASRDogman Senior Member
    7,877
    4,011
    I was looking in walfart for something like that. But saw a visor cd holder.
    $3.00. Bought one. Works GREAT! So I went back and bought another one before they realized
    I liked it and wanted it. The only downside is it's black and doesn't match.
    But I have thought about getting some cloth, cardboard or plastic, elastic, and make some to match.
    AAA likes this.
  10. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I have one of those CD holders, though it's Case Logic. I can't see how it would work well as a shade. Got pix?
  11. audiodave
    audiodave Active Member
    800
    272
    US
    I think Velcro would stick to the visor cloth for other ways of attaching something.
  12. ASRDogman
    7,877
    4,011
    I just use one of the two elastic straps. When it gets worn and loose, I'll flip it over and use the other one. When that wears out, I'll either look for more, or will probably have to make my own. I'm certain there won't be anymore in the store. Maybe a thrift store or garage sale....
    AAA and Smaug1 like this.
  13. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Not if I install it on the front side of the visor. I would install it on the front anyway, so that it will close flush when not in use.
    You could put it on either side.
  14. ASRDogman
    7,877
    4,011
    The velcro would probably damage the cloth, and then it would start to tear.
    And it probably wouldn't stick very well, or long.
    Smaug1 likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I made my own with a heat gun, some plastic, felt, and spray on adhesive. I used a small button head bolt and a nut for the pull handle and covered the bare end of the bolt with a plastic cap for the ends of wire shelving.
    audiodave and Smaug1 like this.
  16. ASRDogman
    7,877
    4,011
    Their ya go! The color is a super close match too!
    Do you have a patent on that yet? :)
    #16 ASRDogman, Aug 21, 2018
  17. ASRDogman
    7,877
    4,011
  18. jerrymildred
    11,517
    14,158
    Tampa, FL
    Thanks. No patent. It was actually inspired by something someone else did here on PC about a year or so ago. It took quite a bit of massaging to finally get it to the right shape. IIRC, the knob was my own invention. The felt was at a hobby store and I thought it was close in color. When I got it out to the car, it was almost perfect.
    I started making one for my wife's '07, which naturally has a different shape to it. I need to get a better heat gun and get back to it.
    Smaug1 likes this.
  19. ASRDogman
    7,877
    4,011
    Well it's a good idea. A little bit of work and parts and you have a good looking and working part!
    jerrymildred likes this.
  20. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Or NO work, no parts and $27. ;)
    I used the visor extender today and it was Just the Thing. Highly recommended.
    If I had opted to make one myself, I'd still be chasing down and fabricating parts now.
