Voice activation question
Discussion in 'Gen 2 Prius Main Forum' started by kente777, Dec 23, 2005.
  1. kente777
    kente777 New Member
    194
    NW Florida
    Can you have the stereo on to give voice commands? I usually have music going all the time and was wondering if the volume had to be turned down before giving voice commands.
    thanks.
    Ken
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yes, the system mutes the stereo when you hit the voice button.
  3. kente777
    kente777 New Member
    194
    NW Florida
    does the steering wheel have a voice button?
    Ken
  4. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    If you press the voice activiation button with the stereo on, it will reply with:
    "Setting temperature to 102.3."
    or perhaps
    "Now dislaying low low prices at the matress megamart."
    or maybe
    "Setting destination as home of today's best music."
    :D
  5. JeffHart
    JeffHart New Member
    83
    Washington, DC
    Yes, it's on the right hand side of the steering wheel, below the map/info toggle and above the phone call/hang up toggle.
    Cheers,
    Jeff
  6. tessar
    tessar Member
    103
    Silicon Vallley, CA
    On a related note, is there a way to disable the voice prompt, "After the beep, please say a command." I just want the beep because I'm impatient. ;)
  7. efusco
    19,891
    1,192
    Nixa, MO
    Look at the image HERE and look at the buttons on the right side of the wheel...it's the one just below "INFO" button---face with 'sound' symbols from the mouth.
  8. efusco
    19,891
    1,192
    Nixa, MO
    you can just give a command after the beep...unless you have an '06 and something's changed. Or else I've just blanked on the voice. :unsure: Anyway, I'm pretty sure I just hit the button, wait for the beep, give the command and it happens. If you don't say anything she talks depending upon if it heard something or nothing.
  9. aaf709
    3,862
    2022 Prius Prime
    Even with the stereo off it may do that. :p
    Saying "P-O-I Off" seems to work best for me. Otherwise I've gotten Ski Lodges, Gas Stations and National Parks when I'm asking for a temperature change. :lol:
  10. tessar
    tessar Member
    103
    Silicon Vallley, CA
    I have a 2006. When I hit the voice command button on the steering wheel, the voice prompt, "After the beep, please say a command," is played, then the beep is played. It would be great if the beep occurred immediately after hitting the button (no voice prompt). Can I just give the command immediately after hitting the button (before the voice prompt and beep?
  11. brandon
    brandon Member
    771
    Manhattan, KS
    Huh, interesting. My '05 does not have the voice prompt, just the beep. There is about a 1-second delay from the time I press the button on the steering wheel and the the time I hear the beep. Configurable, or just a different version of the software?
    *EDIT* Ah, wait. It's all coming back to me now. Evan's right; if you don't say anything after the beep, then there is a voice prompt like you described.
  12. tessar
    tessar Member
    103
    Silicon Vallley, CA
    Okay, I went out for lunch and experimented. After hitting the voice command button, I immediately gave a voice command. It did not execute. Then the voice prompted played followed by the beep. I gave the voice command again and it executed. This is the behavior on a 2006. This sounds like a change from 2004/2005.
    The process takes too long. It's faster to find and hit the buttons on the steering wheel, console, or touch screen. <_<
  13. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    You may not be waiting for the little microphone to show before talking. You must speak Priusese in order to get the system to respond to you. I am currently learning both Italian and Priusese. I find the Italian coming along a bit better....
    Ciao!
  14. tessar
    tessar Member
    103
    Silicon Vallley, CA
    In my car, the voice command input is not accepted at anytime before the beep, which plays after the voice prompt. I am using commands documented in the help system.
  15. flynz4
    flynz4 Member
    329
    Portland, OR
    2015 Prius v wagon
    Tessar,
    I think that it must be a change made to the '06 model because mine works exactly the same way. I drove it today for the first time using voice recognition... and it drove me nuts having to wait for the voice promt to finish before giving the beep. I sure hope this voice promt can be turned off.
    /Jim
  16. mjc243
    mjc243 New Member
    The '06 definately requires that you listen to the speech before giving a command. I thought I saw a menu setting to turn that off, though... the manual seems to include very little on the topic, but maybe I'll experiment tomorrow.
  17. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    Can anyone tell me where to find or just tell me how to increase the volume of the microphone? I found it earlier and attempted to commit the instructions to memory but, ummm, it didn't take. Now I can't find it.
    Thanks!
