Voice Recognition
Discussion in 'Gen 4 Prius Audio and Electronics' started by Gen 2 Tom, Sep 11, 2016.
  1. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    When I got the new Prius a few months ago, I spent some time training and using the voice recognition. I couldn't get much reliable operation. Suri on the other hand finds my contacts perfectly. I thought I got it to respond to the command for a radio station number. But I'm in two different area's so I have 30 stations programed, and haven't memorized all the station numbers. So for now I'm manually scrolling up and down from the steering wheel.
    Is there any voice commands that work well? Any tricks you can share?
  2. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Nobody finding anything the voice can do reliable? Not surprising, I couldn't.
    FF/Medic likes this.
  3. FF/Medic
    FF/Medic Member
    74
    29
    Ann Arbor
    I have a similar problem that you described with my 2016 Prius Four. I called Toyota who said to visit a Toyota dealer. The dealer has no resolution and refuses to put anything in writing that they are unable to repair this issue. More info on this and other 2016 Gen 4 electronic issues posted here: Did Toyota delete the mph/kph selection in the speedometer of your US 2016 Prius?
  4. grape808
    grape808 Active Member
    150
    153
    Hawaii
    I only tried "Play Album" and that worked fine. I like scrolling through my usb manually before I start driving though so I only used it once to see if it worked. It would be handy if the album I pick before I drive runs out of songs but that hasn't happened yet.
  5. nb01
    nb01 New Member
    Cincinnati, OH
    I made the mistake of using it to dial once. Even if it recognized words well, it takes so long to get through the menus that it is far less distracting to use Google Assistant. Yes, it is pretty awful.
    RCO likes this.
  6. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I just say e.g. "call jim mobile" and it works a treat. I think using Siri to take the commands is a bit quicker however.
    RCO likes this.
  7. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    I found more success with voice recognition when I spoke rather softly as opposed to hollering like you're trying to speak to somebody on the phone.
    RCO likes this.
  8. aforkosh
    aforkosh Active Member
    412
    272
    Oakland, CA
    2023 Prius
    I only use it to change Radio Stations and Sources. I have found it to be quite reliable for that. My standard phrase is "Tune to [Source] [Channel or Frequency]".
    krmcg and RCO like this.
