Volkswagen Launches 261 mpg XL1 Plug-in Hybrid, World’s Most Efficient Production Car
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by eheath, Feb 21, 2013.
  1. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Recall that old statement, believe half of what you see and none of what you read.
    Does not seem like a big production run, could be a lack of confidence. Step in the right direction though.
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    I clearly should have applied that aphorism to your post.
    JMD likes this.
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I don't believe it can get 261 mpg, the origin Insight can only get ~70 mpg.
    Assuming the diesel can double this, still only 140 mpg.
    I think it is missing the "e', 261 MPGe may be.
    JMD likes this.
  4. austingreen
    austingreen Senior Member
    13,676
    4,214
    Austin, TX, USA
    We do have one figure for 100 kph. It takes 8.3 kwh to go 62 miles without climate controls. That's 133 wh at the motor, figure for charging losses and battery we get about 174 wh from the plug. It will ofcourse be more efficient at lower speeds, and if you need a lot of heat, you are going to have to fire up that ice.
    The volt was built to be mainly an ev with an ice generator for longer trips. This is chiefly a extremely efficient diesel highway car, optimized for low drag and highway effieincy. They added the hybrid parts to down size the engine and add city effieciency. It needed a big battery for all that, so why not add a plug. This is an evolution of the super car idea, with size sacrificed for efficiency. VW pulled out all the stops for high efficiency, except made it a little larger for side by side seating.
    Would you really pay that much more for this than a volt.
  5. El Dobro
    El Dobro A Member
    7,088
    3,270
    Yea, but it's a VW.
    cwerdna and JMD like this.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    By my arithmetic that works out to 118 MPG, or 190 Km per gallon.
    They must be using imperial gallons to have the numbers at least be close.
    No doubt though, 1L/100 Km is an awesome result for hybrid mode at 100 kph. This car is the plug-in version descendant of the original Honda insight. And like the insight, it pretty much shows the same thing: Exceptional fuel economy is possible with trade-offs few people will accept. Too bad it has the VW frankenstein transmission and costs so much.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    Using the power and efficiency numbers AG posted:
    A US gallon of diesel has about 33.4*1.15 = 38.5 kwh of heat energy
    If 42% makes it to the wheels, that is 16.17 kwh
    A km requires 83 wh (8.3 kw at 100 kph)
    So one gallon moves the car (16.17kwh/0.083 kwh/km) = ~ 195 km
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  9. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
    I don't care that this thing is "underpowered;" the sad thing is that it most likely won't be coming here to the U.S.
    Corwyn likes this.
  10. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
    Also, it has a power to weight ratio close to that of the Prius, so it probably won't be any slower than what you're currently driving. I wouldn't worry about performance too much, and the target customer is not looking for speed if they decide to drive one of these.
  11. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
  12. JMD
    3,779
    1,282
    Well if the mountain does not come to you, you go to the mountain.
  13. Sergiospl
    3,938
    1,351
    28
  14. JMD
    3,779
    1,282
    Just saying If all the car companies went away and all that was left was VW I would walk or take a Train to work.
  15. Sergiospl
    3,938
    1,351
    28
  16. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I'm thinking the claims from VW are based on the European "combined and weighted" estimates. On the same system, the Volt gets 1.2l/100km (196 mpg US), 83km (52 miles) EV range at 16.9kWh/100km and 27g/km. The new VW is about 50km EV range at about (just under) 10kWh/100km.
    The Volt numbers look great even though the gas-only fuel consumption is separately estimated as 5.0l/100km. The trick is that longer battery range reduces the ratio of gas or diesel in the final combined and weighted number and the CO2 is calculated off of that.
    I wouldn't be surprised if the diesel-only fuel consumption rate of the VW engine is more like 2.5l/100km rather than .91l/100km that is being reported.
    Update: Wikipedia says the basic diesel consumption rate is 2.0l/100km or about 120 mpg (US).
    Volkswagen 1-litre car - Wikipedia, the free encyclopedia
    cwerdna and SageBrush like this.
  17. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
  18. JMD
    3,779
    1,282
    Sergiospl likes this.
  19. austingreen
    13,676
    4,214
    Austin, TX, USA
    I stand corrected. I read it from a different source, but now looking at that its 8.3 hp and my power dixlexia switched it to kw. Its even lower than my statement.
  20. Sergiospl
    3,938
    1,351
    28
