Volta Charging Stations in OC, CA
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jkingsley1026, Jul 31, 2018.
  1. jkingsley1026
    jkingsley1026 New Member
    Hey All,
    I just bought a 2013 PiP (today, actually), and have been driving around checking out the charging stations in Huntington Beach, CA, where I live. I’ve been trying the Volta stations, cause they’re free...I tried 5 of them, and 2 worked. Is this an issue with my car, or is it a charging station thing? Is this common?
    Thanks!
    John
    HPrimeAdvanced likes this.
    52,679
    congrats and welcome!
    if two worked, i'd say your car is fine. never heard of volta, is it a private enterprise?
    found 5 in boston, but can't find locations.
    #2 bisco, Aug 5, 2018
  3. Twoodstream
    Twoodstream New Member
    Fontana
    2015 Prius Plug-in
    It might be a charging station thing. The Volta charging station worked for me in Fontana. If you check Plugshare, sometimes there are user-submitted reports when a station is down.
  4. fourpotfury
    fourpotfury Junior Member
    San Jose, CA
    2013 Prius Plug-in
    I'm pretty sure it's a problem work the charging stations. I've tried to use Volta before and they didn't work nearly as well as Chargepoint or any others.
  5. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    I've been using Volta charging station at the mall and so far the ones that I use are all working.
  6. markabele
    5,084
    1,782
    Nebraska
    What are charging speeds like?
  7. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    it is an L2 charging station. So far the longest time I charge my car there is 40 mins to fully charged my battery from 65%.
  8. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I hadn't heard of the Volta charge stations before. Where in Huntington Beach are they located. How did you locate them yourself.
    I've noticed quite a bit of charging problems with Chargepoint chargers in the Orange County Costa Mesa area. Several of the chargers I've used at CCC which are accessible to the public, will give you 3.27 or 3.06 kwh initially, then they drop down to 1.5 or 2.05 or some other low value, which makes the charging experience miserable. Yet Chargepoint chargers a few miles away will give me 3.26 continuously. I always file a report with ChargePoint, so far to no avail. Apparently the charger owners don't care, or don't have the budget to fix them.
    AChoiredTaste.com
  9. markabele
    5,084
    1,782
    Nebraska
    They aren't owned by ChargePoint. ChargePoint simply sells them to the owner. Are you sure the drop down in power isn't the stepping down when it is somewhat close to getting full?
  10. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Positive; the defective chargers start out with over 3 kWh and then in about 10 minutes or less, drop down substantially. The car is usually less than 1/3 charged. Nearby chargers work perfectly; it's got to be a configuration problem.
    AChoiredTaste.com
  11. markabele
    5,084
    1,782
    Nebraska
    To be fair I notice it sometimes as well on my PiP, but never on my Leaf. Potentially a Toyota problem.
  12. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    It's possible, but why only particular ChargePoint locations (and not every time), and never at others. Maybe some stations aren't "communicating" with the Prime as well as others. I've never had a problem with the Broadcom ChargePoint location, for example.
    I always sit in the car while I do my charging top off, so I check charge progress periodically.
    AChoiredTaste.com
  13. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Is this only with Advanced model where you can check your charging progress using your phone?
  14. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I guess; mine is an Advanced, and I use both the Entune App, and the ChargePoint App to monitor the charging. Every so often I start the car to compare charge level attained. I also periodically go to the meter to see the energy flow rate. I make business calls and read. I don't leave the car.
    AChoiredTaste.com
  15. markabele
    5,084
    1,782
    Nebraska
    With ChargePoint the app has most details you'd need to know, except total percent charge and range.
  16. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    This morning I calculated that the Volta charging station is giving 2.12 kwh. From 64% it fully charged in 1 hr and 10 mins.
    Edit: Actually its only 1.98 kwh.
    #16 utsug, Aug 24, 2018
    Data Daedalus likes this.
  17. PlugmeInplz
    PlugmeInplz New Member
    22
    24
    LA
    2013 Prius Plug-in
    In my PIP the display shows 1.9 KWH until about 95% charged. After that it tapers to .5KWH. You can hold the brake and power on the car to see the charging info.
    I have used Volta stations in OC and most work. Sometimes the plug is damaged, but you can get them to work by jiggling the charger handle to get a good contact. That is if there is not a Volt camping there.
    If you car charges fine with the stock charger its not your PIP problem.
  18. markabele
    5,084
    1,782
    Nebraska
    Please don't forget that kWh is a unit of energy whereas kW is a unit of power. I believe you meant to use kW regarding 1.9 and .5.
