Voltage...... 13.1
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jolly, Mar 12, 2015.
  1. Mendel Leisk
    41,666
    I like that WrongMart. Also partial to Home Despot. ;)
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    1st time to hear of the orange "Despot." Nice.
    52,101
    for a 1 year old battery that's been run down, thinking you won't have future problems by charging would be poor judgement. you'll have to do some testing to make sure it's holding a charge.
  4. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    I bit the bullet and bought a Schumacher Battery Maintainer. Interestingly, the guy that helped me was a former Toyota mechanic who has recently relocated to the area I live in (no Toyota shops within 60 miles from me) so he was working in the automotive section of a what I would guess you would call a farm supply store. Members from Minnesota will recognize ¨Fleet Farm¨. This guy says there is a negative post under the hood. I absolutely know where the positive post is in the fusebox but don't seem to see a negative terminal. He says there is one and that I should use it but couldn't quite explain to me where it is. I've always just used the strut bolt. This is a semi-permanent install and he recommended I use that terminal. Any help would be appreciated.
  5. bisco
    52,101
    no, there isn't a negative post under the hood. just put the clamp on any good grounding point like a stud or nut or bolt. stopping listening to toyota mechanics, or you'll wind up in hot water. btw, this is all in your manual.
  6. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Thank You. I will refer to the manual; sometimes easy to forget though when a site like this exists. I will try harder in the future to try and find answers in the manual first.
  7. exstudent
    2,214
    905
    Torrance, CA
    Don't forget to read the warranty manual too! Know what is covered and for how long mileage/months.
    There have been two separate postings by individuals who have paid for an HV Battery repair, with a rebuilt/refurbished/used one, WHILE they were still under warranty!
    Obviously we can't verify anything unless they upload supporting documentation, but even that like nearly everything now a days, can be forged, and forged quite well.
  8. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    I'm a little late to the party but...............
    Those readings are not necessarily bad.
    IF the battery is fully charged, 13.1 is plenty to keep it charged under most circumstances.
    AND......how were you getting those readings ?
    If you have a scan gauge attached, some folks with some cars have found that the scan tool itself will tend to run the battery down if left connected for long periods. I don't remember if that applies to the Prii or not.
  9. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    I use DashCommand with my iPhone for the voltage info. Can't afford a scangauge quite yet.
    I charged the battery overnight. Voltage readout was 13.7 - 13.8 for my 5 mile commute today.
  10. Easy Rider 2
    1,584
    258
    Ocala, FL
    Was that DURING your driving time ?
    If so, that's is pretty much meaningless as it is the charging voltage from the inverter and tells you virtually nothing about the battery itself.
  11. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Yes - while driving. The 13.1 was also while driving.
  12. Easy Rider 2
    1,584
    258
    Ocala, FL
    Readings taken while in "ready" mode are meaningless for determining battery health.
  13. bisco
    52,101
    refer to post #2. you don't need a scan gauge, but you do need a $10. voltmeter.
  14. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Can I test it using the jumper post in the fusebox?. I'm really not interested in tearing apart the trunk to get at the battery.
  15. jdenenberg
    jdenenberg EE Professor
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes as well as by using your MFD in diagnostic mode.
    JeffD
  16. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Thanks all!
  17. Easy Rider 2
    1,584
    258
    Ocala, FL
    But it's kind of hard to get a reading with everything off.......if the MFD is ON (and probably other things too.)
  18. bisco
    52,101
    someone said even opening the drivers door to pull the hood latch decreases the reading.
  19. Easy Rider 2
    1,584
    258
    Ocala, FL
    That is because opening the door makes things happen.......and the only good way to get a true resting reading is to leave the hood latch ajar so you can read the voltage at the jump points.
